Re: Hemi super stock dart Windows
[Re: dvw]
#1957050
11/24/15 12:32 PM
11/24/15 12:32 PM
Posts: 8,833 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
The snaps work well. One at the top so the strap doesn't fall in, and one at the bottom the material stretches (very little) but mine holds the window up tight. I put it down on the return road every pass, 300 passes. You can see the left side is down, the right side is up. The shiny spot on the right between the door handle and vent is the down snap. Doug Do you have a full pic of your car? Just trying to see how that color looks over the whole car,not sure on the color on my 64 and not saying I would do your color,love it, but just getting ideas of shades because some just don't work on a Savoy. Hope that came out right. LOL
[Re: cudaman1969]
#1957276
11/24/15 06:52 PM
11/24/15 06:52 PM
Posts: 10,051 MI, usa
dvw
MI, usa
The snaps work well. One at the top so the strap doesn't fall in, and one at the bottom the material stretches (very little) but mine holds the window up tight. I put it down on the return road every pass, 300 passes. You can see the left side is down, the right side is up. The shiny spot on the right between the door handle and vent is the down snap. Doug Do you have a full pic of your car? Just trying to see how that color looks over the whole car,not sure on the color on my 64 and not saying I would do your color,love it, but just getting ideas of shades because some just don't work on a Savoy. Hope that came out right. LOL Here you go. As you see it depends on if it's in the sun. Doug
[Re: dvw]
#1957535
11/25/15 03:30 AM
11/25/15 03:30 AM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
The snaps work well. One at the top so the strap doesn't fall in, and one at the bottom the material stretches (very little) but mine holds the window up tight. I put it down on the return road every pass, 300 passes. You can see the left side is down, the right side is up. The shiny spot on the right between the door handle and vent is the down snap. Doug Do you have a full pic of your car? Just trying to see how that color looks over the whole car,not sure on the color on my 64 and not saying I would do your color,love it, but just getting ideas of shades because some just don't work on a Savoy. Hope that came out right. LOL Here you go. As you see it depends on if it's in the sun. Doug Very nice, you got the wheels right too. The hook molding separates top and bottom nicely. I have the regular Hemi scoop but with my Hogan cross ram, which is taller, I think I'll need one like yours. I think the carbs will be real close to hood.
[Re: DaveRS23]
#1957619
11/25/15 11:16 AM
11/25/15 11:16 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
While I am no expert, I don't believe that the original 68 SS cars had buckles on the window lift belts. Here is a link to Mancini's old car that is at Mecum now. There are a couple of pics of the interior there. No buckles on the window lift belts on that Dart.
Besides, I tried the buckle. First, it really doesn't do a good job of pulling the window up after the belt goes around all those corners. Second, it is hard on the paint where the belt rubs. And lastly,that buckle flopping around the top of the door when the window is down, isn't cool.
The elastic and a snap is just a better way to go, in my opinion. On my Dart which has the original set up uses a button style snap to hold the window up.On the window it is attached to the press in plastic insert.
