I'm impressed
I love the concept and philosophy of the project.
One small detail that I would do and would if my car irritate me severely, I'd have to close off/reshape the open ends of the front spoiler, I suspect with wide fronts your are losing a lot front spoiler effectiveness with this detail.
Thanks jcc!
With the front spoiler you are probably right!
I didn't design it though and is really is just an ABS copy of the fiberglass ones which are a copy of the 1970 TransAm `Cuda spoiler.
It is still somewhat effective because without it installed my hood lifts up at about 70mph.
Replacing front or rear tires with those? Although I guess a set would imply 4 tires while a pair would be 2....
Hey Mike!
I got a set of 4. I always go square for more neutral handling and the ability to rotate tires.
My 295's don't need replacing yet and honestly would rather have that size but they are now discontinued.
Kind of forced to see how 315's fit and it should fit fine with a 10.5" wheel. A wider wheel would give me problems.
I won't know for sure until I get the actual tire so I am doing this for the sake of research.
haha!
