Correct sound deadner and wheel well undercoat #195537
01/16/09 08:41 PM
01/16/09 08:41 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
I see some sell an undercoat product but was wondering for the exact product to duplicate the original on the quarter panel insides and wheel wells what is the correct product. I imagine Rick's is correct but just looking for some input as I am ready to coat the quarters before installing and want to be as close as possible to original.
Thanks.
Re: Correct sound deadner and wheel well undercoat [Re: sawdust] #195538
01/16/09 08:44 PM
01/16/09 08:44 PM
California
1970mopar Offline
1970mopar  Offline
California
RESTO RICK or Frank Badalson/Roger Gibson - they both sell what is agreed is the most correct undercoating.
obtaining the correct finish when applying comes down to the application process.
Re: Correct sound deadner and wheel well undercoat [Re: 1970mopar] #195539
01/17/09 07:22 PM
01/17/09 07:22 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Thanks, from what I understand Rick provides the instructions for obtaining the correct finish with a "Schutz" gun. We have such a gun and have sprayed for years using the process, but just want to be sure on this resto it is correct.
Thanks again.
Re: Correct sound deadner and wheel well undercoat [Re: sawdust] #195540
01/17/09 08:42 PM
01/17/09 08:42 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Couple of picture the inside of a original quarter.
Re: Correct sound deadner and wheel well undercoat [Re: Challenger 1] #195541
01/17/09 08:47 PM
01/17/09 08:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
CHALLENGER 1....are you going to undercoat your 74 like that once the bodywork is done? Did you undercoat your gold/yellow car?
Re: Correct sound deadner and wheel well undercoat [Re: burdar] #195542
01/17/09 09:04 PM
01/17/09 09:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes and yes. I applied it alot better than what was original. I used Sem chip guard clear. You can paint over it and apply it over the top coat,I did both in places on the gold car. If you apply it heavy enough it approches what it looks like stock in the inner quarters where it gets painted in the trunk. I kept my wheel wells gold and applied clear chip guard over the paint.
Re: Correct sound deadner and wheel well undercoat [Re: Challenger 1] #195543
01/17/09 09:55 PM
01/17/09 09:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
How about a pic of your results? That kind of thickness and texture out of a spray can sounds amazing.
Re: Correct sound deadner and wheel well undercoat [Re: topside] #195544
01/17/09 10:31 PM
01/17/09 10:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
I said approches, I never said it looked dead on original, that was'nt my goal and it doesn't. Hard to see the texture but it's there. It helps stiffen up the panel just a little I think.
Re: Correct sound deadner and wheel well undercoat [Re: Challenger 1] #195545
01/18/09 12:50 AM
01/18/09 12:50 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I was just curious how closely it approached the factory stuff, that's all. With the "real" stuff at $50/gal, a pic of an alternative might be interesting to people.
Re: Correct sound deadner and wheel well undercoat [Re: topside] #195546
01/18/09 02:21 PM
01/18/09 02:21 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I had a hard time getting that thick build up with a can. With the Resto Rick stuff and a shutz gun the texture is alot better but I used 1 gal on just the wheel wells.
Re: Correct sound deadner and wheel well undercoat [Re: THESHAKERPROJECT] #195547
01/18/09 03:25 PM
01/18/09 03:25 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I used Rick's product too. I redid both sides of the trunk and the rear wheel wells and ran out. I'll need to buy another can to do the front fender aprons.
I like it and think it looks good. It has some definate texture to it unlike anything I have used out of a can.
Re: Correct sound deadner and wheel well undercoat [Re: Neil] #195548
01/18/09 04:01 PM
01/18/09 04:01 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
This is the Resto Rick undercoating. I only needed to do the wheelwells since my quarters were fine. One gallon will get the 4 wheelwells only. That stuff shoots out the Shutz gun really fast. The finished product looks good. I'm happy with it.
68 Hemi Road Runner
Re: Correct sound deadner and wheel well undercoat [Re: 68jim] #195549
01/18/09 04:03 PM
01/18/09 04:03 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Finished product.
Re: Correct sound deadner and wheel well undercoat [Re: 68jim] #195550
01/18/09 04:14 PM
01/18/09 04:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Nice job.
It's suprisingly easy to duplicate the factory undercoating appearance. All it takes is to not care what it looks like and your sure to get it right.
Re: Correct sound deadner and wheel well undercoat [Re: Neil] #195551
01/18/09 04:32 PM
01/18/09 04:32 PM
California
1970mopar Offline
1970mopar  Offline
California
After a few beers its even better!
Re: Correct sound deadner and wheel well undercoat [Re: 1970mopar] #195552
01/18/09 04:39 PM
01/18/09 04:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I used Rick's stuff on my '63. Not sure if I can get it to look heavy enough on a quarter panel though. Sometimes where it appears one coat overlaps another, there's a thick edge that needs to be reproduced to look correct. I'm thinking if I use the edge of say a piece of cardboard, and build up those edges, the factory spray pattern would be easier to reproduce.
Re: Correct sound deadner and wheel well undercoat [Re: 1970mopar] #195553
01/18/09 04:54 PM
01/18/09 04:54 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
You're absolutely right. The first wheelwell I took my time. Sprayed a little - moved the light - sprayed a little - moved the light...you get the idea. Overspray on the framerails, brakelines, gas tank wasn't so much as intentional it pretty much is a function of how that gun shoots out. The learning curve is quick. By the time I got to the last wheelwell it was pull the trigger once and let-r-rip. That stuff has a nasty smell until it cures. You want a respirator while shooting and plenty of beer afterwards.
Re: Correct sound deadner and wheel well undercoat [Re: 68jim] #195554
01/18/09 05:39 PM
01/18/09 05:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I might add that it's a good idea to wear a throwaway shoot suit or coveralls, and a head sock and some eye protection. You don't wanna know what it was like to learn that the first time I undercoated a car!
Note, as in Jim's photo, that some kind of template was used to keep the stuff out of the alignment access covers. But overspray on the rockers & wheel opening lips (at least on a few of my cars) was apparently within standards!
Re: Correct sound deadner and wheel well undercoat [Re: topside] #195555
01/18/09 06:44 PM
01/18/09 06:44 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
What was recommended to me by others on this forum was to use a piece a cardboard and just hold it in front of the area vice tape it off. You end up with a "misted" edge around the area. The center area I just went around freehand.
A head sock would have been good. I threw away the sweatshirt, and it took a while to clean up the respirator and safety glasses.
Re: Correct sound deadner and wheel well undercoat [Re: 1970mopar] #195556
01/19/09 10:32 AM
01/19/09 10:32 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used Resto Rick's and the shultz gun stuff too. Great results, but still not quit able to get the heavy, super-course build-up look the factory presure fed system left in some spots. The thick portion of the pattern was from when the spray guy moved his hand too slow, or was too close and sprayed too much material. I probably could have sprayer a few more gallons under my car as I attempted to better, perfectly matched the remaining, intact stuff under the car, but I feel Ricks is just a bit too thin. Probably would'nt spray well out of the Shultz gun if it was thicker. Knowing the little I know about Rick, he is probably able to do it perfectly, adn I just didn't have his talent on this job, but I got close enough.
A pressure fed- airless system with a huge tip would probably be able to match it perfectly. The kind they spray elastometric sealants with. The pump I remember was called a Bulldog. I have about 20 years of sraying with an airless in a previous life, and that's what the pattern looks like it was originally applied with, or some kind of a presurized pot pot with little or no air(a Shultz gun hooked up to a 2 gallon presure pot would work). With a system like that, I could have got a dead on match with the over-heavily sprayed areas using a slightly thickend batch of Ricks stuff. I just wasn't willing to invest the time and money to get that last 5% of perfection. If I had a business or several more to do, then maybe I would have gone there.
My fender wells still have the original stuff in them with the super thick texture, but the underside of my car about two feet out on wither side of the transmision tunnel was all softend and scraped up from years of oil mist etc soaking into it. I also added subframe connectors and had to scrape off some of the old stuff out to the door sills.
On a side note: Once I gave up on trying to create a museum piece, and decided to just do the best I can while restoring my car at home, I began to make a lot of progress. Trying to do things perfectly every time was leading to me getting nothing done. Once I gave up trying to have a perfect restoration, this labor of love became a lot more enjoyable and I'm a lot closer to getting it back on the road after 25 years. I've had the thing for 30 years, so it's about time I got to drive it again. Should be done in a few more months.
PICTURE NOTE: The lighter colored texture below the four-speed shifter opening and towards the engine compartment is original. The darker stuff is Rick's product. It's as close to perfect as you can get, unless you're trying to reproduce the super thick texture left here and there when the factory guy screwed up(not pictured). Once I sprayed the remaining original texture black to freshen up the look, it matched extreamly close to Rick's stuff. It's hard for the laymen to tell the diference between the two textures!
