Re: Car sitting 30 years. What to do before starting the engine?
[Re: Alaskan_TA]
#1955407
11/21/15 04:18 PM
11/21/15 04:18 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
You can also remove the rocker shafts / arms while the stems are soaking. After they sit a while, gently tap each valve with a mallet. If any valves are stuck, they will sound different & you can concentrate on them. Do not be too surprised if you tap one or more & they move but do not come back up right away. Just add more oil. While they soak you can take photos for us. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) But if I do that won't it hurt it's found in barn survivor status? Lol
Chris from New Jersey
[Re: fig426]
#1955409
11/21/15 04:22 PM
11/21/15 04:22 PM
RapidRobert
that's easy, take some pics before you pull it out of the barn (just the way it sits/dust/debris everything). it'll be a good selling point & (likely) put more money in your pocket
[Re: fig426]
#1955584
11/21/15 10:36 PM
11/21/15 10:36 PM
fig426
East Coast, NJ
I like the hair dye bottle trick. Beats a 5 gallon can being poured out the vent hole.
[Re: mikemee1331]
#1956900
11/24/15 02:05 AM
11/24/15 02:05 AM
Posts: 15,536 Omaha Ne
TJP
Omaha Ne
Here we go, pretty soon this will have escalated to a full rebuild before it ever gets on the road. It's so easy to spend someone else's time and money. Pull the plugs out if you must and spin it with the starter to preoil. Squirting a little Diesel oil in the cylinders before you spin it will probably help too, if you want to go that far. Why not squirt a little gasoline in and see if you can get it to fire.
Believe it or not, after 30 years sitting in a barn there will still be a little oil between the bearing shells and the crank journals.
Literally millions of 318s have run with whatever the stock oil filter plate was with no main bearing problems whatsoever. I repeat, start out with the easiest things first. My '71 318 donor truck sat under a big spruce tree for 20 years and with a little prodding ran well enough to get it onto the trailer, then off and into its final resting place.
R. And will add, Change the oil and filter, change the points, plugs etc. Change the head gaskets, drain and flush the cooling system, Replace the radiator, change the belts and hoses. Replace the ENTIRE fuel system. Service the transmission, Rebuild the brakes and ??? OMG what else???? Sorry but, if it turns over with a battery, bottle feed the carb with fresh fuel, turn the key, and go from there.
[Re: NANKET]
#1957008
11/24/15 11:55 AM
11/24/15 11:55 AM
fig426
East Coast, NJ
Prime the oil pump, run a line from a gas can to the fuel pump, fill the carb bowl and start it.
OR, overthink everything, spend lots of money and time rebuilding it down to the muffler bearings. Does anyone repop muffler bearings? Or am I stuck trying to find NOS ones?
[Re: TJP]
#1957305
11/24/15 08:33 PM
11/24/15 08:33 PM
fig426
East Coast, NJ
I have a couple of pair of NOS "CANADIAN" muffler bearings. The Canadian ones are a direct replacement but were built to a much higher standard. They ARE NOT CHEAP ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Pm me for info. LOL As long as they are stamped MADE IN CANADA. That's the only way to tell if they are real.
[Re: fig426]
#1957310
11/24/15 08:46 PM
11/24/15 08:46 PM
Posts: 10,763 North Dakota
6PakBee
North Dakota
I just did this with a '69 GTS that had sat for about 20 years. I'm not saying this is what you should do, just what I did. 1) It was full of oil, I left it. My thought is that old oil with a lot of zinc is better than the new stuff without. 2) I agree with using compressed air to blow out around the plugs, it's amazing what deposits in there. 3) I pulled out all the plugs and hosed the cylinders down with Marvel Mystery Oil and a syphon gun. About $25 at NAPA. 4) Turned the motor over 4 times by hand with a breaker bar on the damper bolt. That checks the stuck valve potential. 5) I hosed the cylinders down again with MMO and spun it over with the starter. I used a GOOD battery so I got oil pressure quickly. 6) I gapped the points and reset the timing with a test lamp. 7) Filled the carb with gas through the bowl vents, put 5 gallons of premium in tank with a can of SeaFoam. 8) Put the plugs back in, squirted some gas in the carb, and rolled it over. Started right up. It took about five times before it would stay running but once it did I ran it on the fast idle cam for about 20 minutes to get it good and warm. Pulled the plugs again and checked compression, all between 140 and 150 psig. Again, I'm not saying that's how anybody should do it, just how I did. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: 6PakBee]
#1957375
11/24/15 10:49 PM
11/24/15 10:49 PM
fig426
East Coast, NJ
I just did this with a '69 GTS that had sat for about 20 years. I'm not saying this is what you should do, just what I did. 1) It was full of oil, I left it. My thought is that old oil with a lot of zinc is better than the new stuff without. 2) I agree with using compressed air to blow out around the plugs, it's amazing what deposits in there. 3) I pulled out all the plugs and hosed the cylinders down with Marvel Mystery Oil and a syphon gun. About $25 at NAPA. 4) Turned the motor over 4 times by hand with a breaker bar on the damper bolt. That checks the stuck valve potential. 5) I hosed the cylinders down again with MMO and spun it over with the starter. I used a GOOD battery so I got oil pressure quickly. 6) I gapped the points and reset the timing with a test lamp. 7) Filled the carb with gas through the bowl vents, put 5 gallons of premium in tank with a can of SeaFoam. 8) Put the plugs back in, squirted some gas in the carb, and rolled it over. Started right up. It took about five times before it would stay running but once it did I ran it on the fast idle cam for about 20 minutes to get it good and warm. Pulled the plugs again and checked compression, all between 140 and 150 psig. Again, I'm not saying that's how anybody should do it, just how I did. Did you pull the valve covers to see if no valves were stuck, or just count on it binding up when turning over with the breaker bar?
[Re: fig426]
#1957424
11/25/15 12:15 AM
11/25/15 12:15 AM
6PakBee
North Dakota
Did you pull the valve covers to see if no valves were stuck, or just count on it binding up when turning over with the breaker bar? I did not. I've only had stuck valves one time and I could feel that. But there's nothing wrong with pulling the covers and making sure. Sometimes you have to do things just to sleep well at night. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: fig426]
#1957459
11/25/15 01:35 AM
11/25/15 01:35 AM
TJP
Omaha Ne
I have a couple of pair of NOS "CANADIAN" muffler bearings. The Canadian ones are a direct replacement but were built to a much higher standard. They ARE NOT CHEAP ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Pm me for info. LOL As long as they are stamped MADE IN CANADA. That's the only way to tell if they are real. yes they are stamped "MADE In CANADA" The included "NOS" instructions say to use grease made in TURKEY before the 1980 Coup or the warranty will be void. BTW I also have some 1970 TURKEY grease available. It's been in CLIMATE CONTROLLED storage along with the MUFFLER BEARINGS. Some say the grease is not critical but I will not warranty the bearings unless you buy the SPECIAL TURKEY grease. PM me for more information on these SPECIAL track tested Tom hoover / Richard Petty/ Dick Landy approved bearings. ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif)
