Re: Rear End question about gears and overdrive.
[Re: dogdays]
#1955224
11/21/15 04:06 AM
11/21/15 04:06 AM
Posts: 3,438 Dandridge TN
Dabee
Dandridge TN
(It takes about a second to shift into Overdrive and I think you have to get off the gas a little. On a 0-60 run in 6 seconds, where is the time to shift the overdrive box?)
Wrong! I have a GV behind a 511 stroker. The shift to OD is instant and you do not need to get off the gas a little, keep it to the floor.
(BTW, the internal workings of the GV look very similar to innards of a TorqueFlite, a planetary gear system with a multidisc clutch. The pressure for the clutch is provided by a pump in the casing.)
Yes it is a planetary gear. The clutch isn't multi-disc, it's a cone clutch. Correct the GV has its own internal pump and sump. It's a single piston pump, about 3/8 di.a.
I'm not trying to be a smart a$$, but have you ever driven a car or truck with a GV installed? Have you ever actually opened one up and looked inside?
As far as the split shift goes it's not practical. Since I have a manual reverse valve body I drive mine like a four speed. 1, 2, 3, OD. If I'm getting on it hard, it's 1, 2, OD, 3. I disabled the GV auto feature and manually select OD. The only draw back to disabling the GV auto feature is you have to remember to deselect OD every time you stop.
[Re: Kern Dog]
#1955336
11/21/15 01:53 PM
11/21/15 01:53 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
My week long experience with a Gear Vendors on a 727 with a stockish 440 was that it was not enough overdrive to warrant the expense and the gear splitting was slower than leaving it alone and shifting it into the overdrive in 3rd.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1955998
11/22/15 06:52 PM
11/22/15 06:52 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
My week long experience with a Gear Vendors on a 727 with a stockish 440 was that it was not enough overdrive to warrant the expense and the gear splitting was slower than leaving it alone and shifting it into the overdrive in 3rd. Interesting.. My 67 Coronet has 294 gears in it ( automatic) as I like to drive it places.. They are getting boring though... My research shows a 355 geared car with the GV unit would have an OD comparable to 274 final gears??? Seems pretty perfect to me??? What am I missing??
[Re: minivan]
#1956060
11/22/15 08:30 PM
11/22/15 08:30 PM
Dabee
Dandridge TN
Interesting..
Seems pretty perfect to me??? What am I missing?? My 69 Bee 3.55 gear + GV = 2500rpm @ 80mph. My engine is happy, I'm happy. Was it worth $2600? Yep every penny!
[Re: 2ndopp]
#2000009
01/27/16 09:06 PM
01/27/16 09:06 PM
Posts: 2,920 Calgary, Alberta Canada
a12rag
Sheesh . . . if you are thinking Ford 9 inch, then why not go with Mopar 8.75 ??? There were many made for your car . . . just an FYI . . . as was mentioned before, depends what you want to do with your car. I have a 74 Duster360, original 360, 727 auto. It had original 8.25 rear end with 2.94 gears, thought I would like more, so got 3.55 sure grip installed. However, I like driving long distances . . . so these really didn't seem like what I wanted . . . before going to Carlisle, PA show in 1999 I swapped out complete rear for another 8.25 with 2.45:1 gears ! Much happier !!! The 360 still cranks over the right tire (yes one legger) no problem, travelling down the road at 75mph, engine ticking over at 2600rpm, and mileage around 22/23 mpg all day long ! . . . Just my two cents worth . . . build the car YOU want ! . . .
Cheers
Mark
[Re: 2ndopp]
#2000112
01/27/16 11:28 PM
01/27/16 11:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Wonder if disc brakes would drop the weight more.
[Re: jbc426]
#2000138
01/27/16 11:47 PM
01/27/16 11:47 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My week long experience with a Gear Vendors on a 727 with a stockish 440 was that it was not enough overdrive to warrant the expense and the gear splitting was slower than leaving it alone and shifting it into the overdrive in 3rd. What rear gear were you running and what tire height? I'm at 2650 RPM's at 60 MPH on the highway in my Duster with 3.55's and a 27" tire, I know darn well an overdrive button would make me much happier at around 2100 RPM's.
[Re: a12rag]
#2000140
01/27/16 11:50 PM
01/27/16 11:50 PM
ProSport
Akron, Ohio
Sheesh . . . if you are thinking Ford 9 inch, then why not go with Mopar 8.75 ??? There were many made for your car . Probably because the 9" is about 10 times stronger. There are alot of fast cars with 8.75 rearends but alot of them break too.
[Re: ProSport]
#2000253
01/28/16 02:16 AM
01/28/16 02:16 AM
Supercuda
About to go away
About to go away
up yours
Sheesh . . . if you are thinking Ford 9 inch, then why not go with Mopar 8.75 ??? There were many made for your car . Probably because the 9" is about 10 times stronger. There are alot of fast cars with 8.75 rearends but alot of them break too. Not stock they aren't.
[Re: Supercuda]
#2000268
01/28/16 02:51 AM
01/28/16 02:51 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Sheesh . . . if you are thinking Ford 9 inch, then why not go with Mopar 8.75 ??? There were many made for your car . Probably because the 9" is about 10 times stronger. There are alot of fast cars with 8.75 rearends but alot of them break too. Not stock they aren't. This is a good point. A 9" is a good rear end, but mostly because the aftermarket has offered them a lot of support. In stock form, they are a far cry from a Dana60, which can handle just about anything in bone stock form.
[Re: 2ndopp]
#2000983
01/29/16 03:41 AM
01/29/16 03:41 AM
Posts: 10,586 Freeport IL USA
poorboy
Freeport IL USA
Any over drive trans will produce about the same effect as the Gear Venders unit at a much lower price. The only advantage the GV unit has is it can handle more power. The 727 version of the Mopar overdrive automatic can be as stout as your current 727 or most of the Mopar OD 4, 5 or 6 speeds will work at probably 1/2 the cost of the GV unit, even after converting them to fit your big block.
My 93 Dakota 4x4 pickup has a Magnum V6, 500 auto od, 3:55 8 1/4 rear and 235-75-15 tires. It will roll down the road with the od off (switch on the dash) at about 2600 at 60 mph. Turn the od on, and the rpm drops to about 2100, and when the converter locks up, the rpm drops to about 1800 at 60 mph. The V 6 doesn't have enough balls to pull a long hill at a steady 60 (it does better at 70) without unlocking the lockup converter, and if its a really long hill, it might drop out of od. Out of od, I can gain speed going up nearly any hill. A V8 would probably pull the hills without issues. On the highway, my 4x4 Dakota gets around 20 mpg at 70 mph. Gene
