Page 8 of 45 1 2 6 7 8 9 10 44 45
Re: Trick Flow heads [Re: AndyF] #1946869
11/07/15 12:32 PM
11/07/15 12:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Andy - How's the sweep pattern look w/ the Hughes rockers on the TF heads? I'm going to take a s.w.a.g. they're a little long for those heads w/o trying something like a B3RE relocation kit.
Oh, and your picture of the RAS setup makes me (once again) regret having sold mine years ago. realcrazy
I wonder how the new COMP Pro Magnum (?) bushed stainless-steel rockers would work on the TFs? Too bad they only offer a 1.5 ratio.
Re: Trick Flow heads [Re: fast68plymouth] #1946931
11/07/15 02:34 PM
11/07/15 02:34 PM
AndyF Online content
AndyF  Online Content
The sweep looked okay to me in a quicky test but I need to order new pushrods before I really know for sure. The TF heads require pushrods that are about .600 longer than usual so nothing in my large drawer of pushrods was a match. I usually have something that fits but not this time.
Re: Trick Flow heads [Re: AndyF] #1946987
11/07/15 03:43 PM
11/07/15 03:43 PM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
Andy, what hold downs are you using in the picture with TF and Hughes rockers?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Trick Flow heads [Re: fast68plymouth] #1947028
11/07/15 05:12 PM
11/07/15 05:12 PM
Those are the Hughes hold downs. (which are a copy of the original heavy duty hold downs that RAS used to make) I don't think RAS makes the hold downs anymore so Hughes started to make them. They are really nice hold downs machined from hex bar stock. They provide a nice wide area for the rocker arm to ride on.
Re: Trick Flow heads [Re: AndyF] #1947221
11/07/15 10:27 PM
11/07/15 10:27 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hey Andy,
I have the RAS also. How was the sweep pattern across the tip?
Damon
Re: Trick Flow heads [Re: Cudajon] #1947234
11/07/15 10:55 PM
11/07/15 10:55 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Originally Posted By Cudajon
Has anyone got these heads on a running engine yet? If so whats the verdict.
Yeah, dying to see some running motor results with these, even OOTB results.
Re: Trick Flow heads [Re: fast68plymouth] #1947256
11/07/15 11:27 PM
11/07/15 11:27 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Just an fyi; I had rocker arms unlimited (RAS) bush a set or Isky rockers for me this year and I bought their shafts with banana groves and their hold downs as pictured above in AndyF's picture. Gary mentioned that they've discussed making their own rocker arms again for Mopars. The shafts were the biggest hold up in getting everything back as the business that chromes the shafts for them took awhile; Gary told me that they just don't send enough to the business for a fast turn around. It sounds like they wait until they have a big enough order to do them all at once; I could be wrong though.
Re: Trick Flow heads [Re: fast68plymouth] #1947266
11/07/15 11:42 PM
11/07/15 11:42 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Just info, Andy I run those Huges rockers on my 528, I rate them as the best rockers Ive ever had.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: mopardamo] #1947321
11/08/15 12:58 AM
11/08/15 12:58 AM
Originally Posted By mopardamo
Hey Andy,
Damon
The sweep pattern looks good with the RAS rocker arms up to about .750 lift. If you're going to run more than .750 lift then I'd suggest some Jesel rocker arms.
Re: Trick Flow heads [Re: Uberpube] #1947322
11/08/15 01:01 AM
11/08/15 01:01 AM
IMM has an engine going together with TF heads and so do I. Not sure who will get on the dyno first. I'm sure there are some other guys with engines going together.
Re: Trick Flow heads [Re: fast68plymouth] #1947643
11/08/15 07:08 PM
11/08/15 07:08 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Has anyone heard a date that the intake is going to be available?
Re: Trick Flow heads [Re: fast68plymouth] #1951316
11/15/15 12:31 AM
11/15/15 12:31 AM
making some progress
Re: Trick Flow heads [Re: AndyF] #1951329
11/15/15 12:46 AM
11/15/15 12:46 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Subscribed..............
Curator at Adams County Speed Shop
Re: Trick Flow heads [Re: fast68plymouth] #1951441
11/15/15 06:00 AM
11/15/15 06:00 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
andy f,what would be the advantage of a belt drive over gear and chain drives,i know the belt would have to be changed every year
Re: Trick Flow heads [Re: dart games] #1951444
11/15/15 06:38 AM
11/15/15 06:38 AM
Jamie McGrath Offline
Just a guess, easier too adjust cam adv/ret, less spinning weight and harmonics.
Re: Trick Flow heads [Re: fast68plymouth] #1951608
11/15/15 01:45 PM
11/15/15 01:45 PM
The belt drive provides a thrust bearing for the camshaft and it allows for easy centerline adjustments. It is also really easy to work with in terms of other accessories such as the crank trigger, dry sump, belt driven distributor etc.
Re: Trick Flow heads [Re: fast68plymouth] #1951610
11/15/15 01:46 PM
11/15/15 01:46 PM
Heads come out of the box ready for .700 lift so I'm going to use it.
Re: Trick Flow heads [Re: AndyF] #1952145
11/16/15 02:41 AM
11/16/15 02:41 AM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
Subscribed!! looks sweet!!
Re: Trick Flow heads [Re: fast68plymouth] #1952186
11/16/15 06:17 AM
11/16/15 06:17 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
thanks andy f
Re: Trick Flow heads [Re: fast68plymouth] #1952675
11/17/15 12:19 AM
11/17/15 12:19 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
popcorn
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
