Re: The ongoing quest for MORE caster, 71 Road Runner
[Re: Kern Dog]
#1951462
11/15/15 09:24 AM
11/15/15 09:24 AM
Posts: 5,812 ohio
ruderunner
ohio
A thought about production line tolerances: perhaps it has as much to do with the plant that assembled the unibody? Maybe some had jigs that allowed more performance oriented alignments?
And my thoughts on alignment specs here: for street driving, caster is far more important than camber. The reality is that youre more likely to notice the self centering afforded by caster than the extra grip from the camber. Racing is a different story, especially autocross.
To those that have a hard time achieving caster, is the rear ride height boosted over stock? Changing the angle of the car will affect caster, a lower rear ride height will improve caster.
Has anyone ever done away with the cams and lengthened the slots to allow more adjustment? The cams are strictly to ease adjustment, once the bolts are torqued they dont do squat.
Angry white pureblood male
[Re: Kern Dog]
#1951547
11/15/15 12:46 PM
11/15/15 12:46 PM
Posts: 1,212 Minn
SportF
Minn
Let me re-state my original post above, that is, I have never got more than another .5 degree castor with offset bushings. That's on 4 cars, two mine, two not. I do my own alignments and have done this for friends also. Cars with .5 degree castor seem to drive and ride fine, but we'd like more. If you actually have 5 degrees of castor from factory, that would be extraordinary, but of course entirely possible.
On the aftermarket upper arms I bought, without modification, max castor I could get was 5.5 degrees. That is, one rod arm out as far as safe, the other all the way in. AND, driving around on the street, although not much, you couldn't tell the difference from before. I would do about 95 in the 1/8 mile, and this was done for racing. What I didn't know at the time, is all of this castor was done to fix a car that wouldn't go straight because of rear tire run-out.
Somethings you find out a little too late.
[Re: Kern Dog]
#1951551
11/15/15 12:50 PM
11/15/15 12:50 PM
Posts: 1,212 Minn
SportF
Minn
Also, I have had to grind off the back inside of the upper control arm as with the cam turned all the way in board with offset bushing, the arm would hit the inside of the "shock tower".
[Re: Kern Dog]
#1951682
11/15/15 03:50 PM
11/15/15 03:50 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I'm thinking the deck is stacked against you when you are dealing with sub-par assembly tolerances from the 60's&70's. It doesn't help on the friday or monday cars that were put together by someone who was having issues at work that day and not being able to check fitment before pulling the trigger on the welder. I know even on newer stuff like the 4x rams, the mounts for the upper and lower control arms can be off like 1/4"+ which contributes to the famous "death wobble". You have to resort to adjustable arms to alleviate it as the stock stuff only allows for minimal adjustments. The adjustable arms and strut rods are a big boost for our old cars, but what do you do if you can't get enough adjustment to get you where you need to be? I'm wondering if in those instances, you will have to move the pickup points for the suspension mountings. Also, if you are off only a small amount at the arm or part attachment, with the stack up of other issues and that the defect is magnified the farther out it gets from the pivot or attachment point, you are going to have a fun time fixing things.
Carl Kessel
[Re: ruderunner]
#1951765
11/15/15 05:55 PM
11/15/15 05:55 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Has anyone ever done away with the cams and lengthened the slots to allow more adjustment? The cams are strictly to ease adjustment, once the bolts are torqued they dont do squat. Great questions. I agree that caster is the main goal for a mild street type car. The problem that I am learning is that gaining caster means also gaining positive camber. I am still curious about some possible fixes. The owner called me to say while the rear cam bolts are maxxed out to the inside, the front ones appear to be near the middle of their adjustment range. When I had the car here, I had the fronts cranked to the outside and the camber was WAAAAY positive. This has me wondering if those spacer washers from Mancini would be a way to reduce the excessive positive camber. (In effect, resulting in less than the 2 degrees of NEG camber that they are advertised to provide) The same alignment shop had trouble aligning my FrankenDuster in 2011. I had these same bushings in that car, installed the same way. I chalked it up to a shop being NON Mopar friendly or possibly just unwilling to work on an old car. The Duster was also "Baseline/Bonehead" aligned by me with the front cams out and the rear cams in. It tracked and steered great with no abnormal tire wear.
[Re: cudaman1969]
#1951770
11/15/15 06:00 PM
11/15/15 06:00 PM
Kern Dog
Granite Bay CA
Would some of the problem be with the k-frame to far back? How far moving it forward would it take to help the problem (elongated holes in the k-frame) just thinking out loud here. That is entirely possible. Incorrect positioning either by damage or incorrect placement of the frame mounted captive bolts would certainly affect caster. Incorrect placement of the UCA mounts would too.
[Re: Kern Dog]
#1951790
11/15/15 06:36 PM
11/15/15 06:36 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
If those were the arms out of my car, I got about 6.5 degrees positive caster with .5 negative camber with them with no other modifications but lowered ride height. They should be good to go....
The thing that sucks with doing Mopars is that most alignment places don't want to spend the time to get it really spot on which is why I ended up doing it myself at a friend's shop
I have an alignment gauge if you want to try and do it at home. Let me know and I can bring it to the meeting on Thursday
[Re: Kern Dog]
#1952837
11/17/15 10:15 AM
11/17/15 10:15 AM
Posts: 1,212 Minn
SportF
Minn
This bind or noise is probably the rear part of the A arm rubbing on the shock tower. I mentioned this above that you have to grind/cut off the inside part of the arm to make it work. This will also keep the cams from making a full turn.
In all of this, without going any further, if you have 1 degree, I bet it will drive and ride fine! Try it. If it doesn't, you have loose, worn, or bent "stuff". There may be a ton of ways to compensate, but no need to do so.
[Re: Kern Dog]
#1953905
11/18/15 08:39 PM
11/18/15 08:39 PM
Posts: 8,251 fredericksburg,va
cudaman1969
fredericksburg,va
[quote=Frankenduster]The other day I started thinking that to get where he wants to be, it will take a few tricks, not just the bushings. My current plan is to add the lower ball joint spacers to add negative camber, then adjust the front adjuster cams further out to gain caster. The strut rod bushings are urethane. I can shave 3/16" from the inner strut rod bushing and pull the LCA forward some. This should provide enough to get there. I was either lucky before or the other cars I had were on the other end of the tolerances. I have been able to get the numbers simply with the special bushings. [/quote
just came to me about the spacers... Not the ball joint stud but the bolts that hold it to the spindles, right?
