Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950011
11/12/15 03:24 PM
11/12/15 03:24 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'd be curious as to what the thrust bearing surfaces look like. could the converter be balloning and seriously screwing up the end play? something definitely chewed the engine outside/tranny side of the bearing.
Re: Small block 360 bearings look bad.................... [Re: slantzilla] #1950122
11/12/15 08:06 PM
11/12/15 08:06 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
Originally Posted By slantzilla
What does the crank look like? It is rough or discolored? That really looks to me like it was run out of oil. shruggy
Crank is perfect, it wasn't run out of oil.
Think we figured it out with more investigating...the bearing caps weren't sitting correctly. High spots in the bearing saddles.
Thanks guys. It will all be torn down and re-machined anyway.
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950149
11/12/15 09:15 PM
11/12/15 09:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Well look at it this way. At least you caught it before things turned ugly and thank God it's Winter. Lots of time to fix it right
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950563
11/13/15 04:00 PM
11/13/15 04:00 PM
Washington
madscientist Offline
Washington
When bearings are egged shaped, it usually means detonation. Unless you are running really thin oil, .002 MEASURED clearance is too little for that big main bearing. I would use nothing less than .0025 and would go to .003 if you are using anything heavier than a 40 grade oil.
A high volume oil pump WILL NOT, NOR CAN IT, pump the pan dry any faster than a standard volume pump. Sort of like the long tube/short tube header thing...who determines what is long and wht is short? If you up the engine speed past OEM (which is generally a sustained speed [RPM] of over 4500 because the factory considered most people never twist them up for long periods of time) then you should have the "high" volume oil pump.
If you want to talk to some one who can explain this to you, call Kevin Johnson. Just google crank scrapers and you will find Ishihara-Johnson crank scrapers. Call him up. Take notes.He is a smart man who doesn't bull crap you around.
You have more issues than you think IMO.
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950581
11/13/15 04:33 PM
11/13/15 04:33 PM
P
Porter67 Offline
Porter67  Offline
P
Can you explain this a bit more...Id like to learn more and im sure others would as well.
"Think we figured it out with more investigating...the bearing caps weren't sitting correctly. High spots in the bearing saddles."
Was this a junkyard block? How did you set the clearances?
Upon assembly with the caps set on the register other then maybe a tap with a very small screwdriver sized rubber mallet they either fit correctly or they dont.
Id think you should of been able to pick up on something upon assembly.
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950583
11/13/15 04:37 PM
11/13/15 04:37 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Maybe I missed it, but I haven't seen or heard what the rods look like. I've dealt with enough oil issues in stock crank, high RPM 360s to find it hard to believe a main could get to that point without the rods coming out of it first.
6k is not a lot of RPM and it shouldn't take radical oil system mods to keep it happy. There are some basic things that would be helpful though. You can take it apart and fix it, but I'd want to know why that happened rather than just hope it doesn't happen again.
ETA...I'm with Porter67 in that I'm not sure what that statement means. But I'm curious.
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950592
11/13/15 04:52 PM
11/13/15 04:52 PM
Washington
Washington
The only thing I can think of is there was something on the bore of the main bearing. Don't know if its metal or what. I'd like to know what they found.
I guess it's possible there wasn't any press fit between the cap and register and it let the cap move on the bolts.
Just guessing though.
Re: Small block 360 bearings look bad.................... [Re: madscientist] #1950609
11/13/15 05:33 PM
11/13/15 05:33 PM
PA.
"Little"John
"Little"John
PA.
In my 40 years of building and tearing apart engines I've seen a lot of things that are put together poorly. I tore apart a small block 360 one time that was still running and raced (hydraulic cam and sounded like dog-poop till reved up) that had 3 oil galley plugs missing. I tore one apart with the bearing installed with the oil feed hole installed in the cap instead of the block. one had .010 bearing instead of the needed standard size. Engines put together straight from the machine shop without the proper cleaning. ZERO thrust bearing clearance and many others.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small block 360 bearings look bad.................... [Re: Porter67] #1950621
11/13/15 05:59 PM
11/13/15 05:59 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Depends on how far it gets taken...
I've 'dressed' more than one main cap before assembly...
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950625
11/13/15 06:11 PM
11/13/15 06:11 PM
P
Porter67 Offline
Porter67  Offline
P
That was about oem blocks and caps, now my race blocks the register is much tighter and I thump then with a short wooden block and as well need that same block to remove them.
But I have seen shops use a big chisel near the cap to move a bit of material before align hone job...mixed thoughts on that.
But most oem caps seem to just fit snug vs tight, but ive only done 40 or so small blocks over the years, im sure others like John for example have seen the full barrel of monkies.
Id just like to know more on this deal so I can try to avoid it in the future.
Re: Small block 360 bearings look bad.................... [Re: Porter67] #1950662
11/13/15 07:34 PM
11/13/15 07:34 PM
PA.
"Little"John
"Little"John
PA.
The crazy thing about the engine without the 3 pipe plugs is it was in my black Duster when I bought it and ran 11.80's with a 510 lift purple shaft hydraulic cam. Matt raced it the year I bought it till I built another engine for it. While idling in the pits or driving it around it sounded like CRAP. From the water box on when it was reved up the pressure must have been high enough to pump up the lifters. The 3 plugs missing and the one that really surprised me that it had enough pressure not to harm the bearings was the one on the rear driver side oil galley. The other two not so must as they mainly direct oil thru the oil filter. Those were the small vertical one located under the rear main cap and the one under the 90 degree oil filter adaptor.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1950869
11/14/15 01:25 AM
11/14/15 01:25 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The parting line looks like the cap isn't seating right. Possibly a weak bolt or cap flex which would be odd for such a heavy cap (#5). But something looks fishy there.
Re: Small block 360 bearings look bad.................... [Re: moper] #1950985
11/14/15 11:19 AM
11/14/15 11:19 AM
pennsylvania
poboyengineering Offline
pennsylvania
Does the block side bearing look the same? Just wondering if that cap/saddle isn't square.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Small block 360 bearings look bad.................... [Re: moparpollack] #1951018
11/14/15 12:38 PM
11/14/15 12:38 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lets see a picture of the thrust bearing please. both sides.
Re: Small block 360 bearings look bad.................... [Re: dustergirl340] #1951205
11/14/15 07:52 PM
11/14/15 07:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Wheres the pics of the other bearings and crank?
Doug
