Re: ADJUSTABLE STRUT RODS - different designs
[Re: Mopar Mitch]
#1949464
11/11/15 04:36 PM
11/11/15 04:36 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I appreciate these comments, opinions and ideas. I don't, unfortunately, have the luxury of comparing any of all these struts side-by-side.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: autoxcuda]
#1949766
11/12/15 01:58 AM
11/12/15 01:58 AM
Posts: 259 n.c.
geo.
n.c.
Wonder how the Nichels stock car arrangement would compare. They welded a sleeve into the k-member, screwed in what looked like a typical Mopar ball joint, and joined it to a shortened two piece strut rod, with a threaded collar. A tie rod type adjustment was used to change the length as needed. Would work like the Mustang ones that nstgl1970 posted about. In other words, perfectly fine and with more resistance to wear than a spherical rod end. Yes! I missed the mustang pic, how 'bout a mustang Mopar hybrid, with a protective boot. Might be best of all.
[Re: TC@HP2]
#1949770
11/12/15 02:05 AM
11/12/15 02:05 AM
Posts: 259 n.c.
geo.
n.c.
Wonder how the Nichels stock car arrangement would compare. They welded a sleeve into the k-member, screwed in what looked like a typical Mopar ball joint, and joined it to a shortened two piece strut rod, with a threaded collar. A tie rod type adjustment was used to change the length as needed. That's similar to what I proposed, only I'm saying don't bother with the welding and screwing in the ball joint. You'll eventually fatigue the threads and have to replace the sleeve. Instead, use a bolt in ball joint. Yea that would be good too, especially if you can't or don't want to weld anything to your K member. I'd think any ball joint would be more wear resistant than a heim. Not sure I'd agree on the threads wearing out though, have you seen any worn out upper control arm threads?
[Re: geo.]
#1949771
11/12/15 02:08 AM
11/12/15 02:08 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Wonder how the Nichels stock car arrangement would compare. They welded a sleeve into the k-member, screwed in what looked like a typical Mopar ball joint, and joined it to a shortened two piece strut rod, with a threaded collar. A tie rod type adjustment was used to change the length as needed. That's similar to what I proposed, only I'm saying don't bother with the welding and screwing in the ball joint. You'll eventually fatigue the threads and have to replace the sleeve. Instead, use a bolt in ball joint. Yea that would be good too, especially if you can't or don't want to weld anything to your K member. I'd think any ball joint would be more wear resistant than a heim. Not sure I'd agree on the threads wearing out though, have you seen any worn out upper control arm threads? You gave me an idea. http://www.speedwaymotors.com/Steel-Upper-Ball-Joint-Sleeve-K772-Style,2126.html
Mopar to the bone!!!
[Re: geo.]
#1949945
11/12/15 01:23 PM
11/12/15 01:23 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
Not sure I'd agree on the threads wearing out though, have you seen any worn out upper control arm threads? Yup, and it is occasionally posted here as well when some one can get a ball joint into the control arm but not get it to torque to spec. Solution from way back was to put 3-4 tack welds on the ball joint to hold it in the control arm.
[Re: TC@HP2]
#1949996
11/12/15 03:02 PM
11/12/15 03:02 PM
Posts: 259 n.c.
geo.
n.c.
Not sure I'd agree on the threads wearing out though, have you seen any worn out upper control arm threads? Yup, and it is occasionally posted here as well when some one can get a ball joint into the control arm but not get it to torque to spec. Solution from way back was to put 3-4 tack welds on the ball joint to hold it in the control arm. Now that you mention it I've done that myself a looooong time ago, and it worked!
