Re: help me build a 440 for a c body
[Re: 1968fury]
#1949196
11/11/15 02:14 AM
11/11/15 02:14 AM
Posts: 10,234 Someplace you aren't
SomeCarGuy
Who cares if it is a "muscle car?" What does that have to do with the price of eggs in Amsterdam?.
I want my fair share
[Re: SomeCarGuy]
#1949202
11/11/15 02:29 AM
11/11/15 02:29 AM
Posts: 35 Livonia,MI
1968fury
Livonia,MI
Who cares if it is a "muscle car?" What does that have to do with the price of eggs in Amsterdam?. Ha exactly
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
[Re: 1968fury]
#1949250
11/11/15 08:10 AM
11/11/15 08:10 AM
Posts: 234 Brisvegas, Australia
Alchemi
Hey its muscle enough - put it side by side with a '68 RR and play spot the difference.... Base model one aint much difference in weight to a "B" either - most of the size difference is air If anything its superior, there is a butt tonne of chassis connecting the upper A-Arms to the rest of the car No its not technically a muscle car, just think of it as having a whole gym Yes I own one too... lols
[Re: 1968fury]
#1949270
11/11/15 10:24 AM
11/11/15 10:24 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I like your cam choice, the 528, but the gears need to be 3.55 or 3.73 for some compromise in getting this car to move. I run 3.55s on the street with a 27.3 inch tall rear tire, and I go to cruise nights sixty miles away, no problem even on the freeway. On the heads, I would do my best to budget for aluminum heads. The 906 castings have weak points, and having cracked a set with a lot of $$ in them , I don't like to see guys putting money into those castings. By building it right with good quench, .050 or closer on piston to head clearance and lower drag 1/16 rings on a flat top piston, you will make a good amount more torque and you need all you can get with what you want to do here.
[Re: 1968fury]
#1951843
11/15/15 08:09 PM
11/15/15 08:09 PM
1968fury
Livonia,MI
Thanks for all the advice
[Re: 1968fury]
#1952195
11/16/15 09:43 AM
11/16/15 09:43 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Our '67 VIP run 10.6's naturally aspirated. Sure it had 4.10 gear, but the tires were 32", and the trans was an automatic, 1.8 first gear. The manual will propably be a challenge with the long gear ratio. Other than that, it shouldn't be very hard. Our old '67 III run 13.8/103 with a smog short block (not much CR), slightly cleaned open chamber heads, MP 280 hydraulic cam, 1 3/4" headers, Torker 2 intake, 3310 Holley, stock torque convertere and 3.23 gears.
Plynouth VIP '67 TT IC EFI
[Re: Bill MeLater]
#1953642
11/18/15 12:55 PM
11/18/15 12:55 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I believe you were told you do not own a muscle car What the hell is your problem?
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: jyrki]
#1953874
11/18/15 07:53 PM
11/18/15 07:53 PM
1968fury
Livonia,MI
Our '67 VIP run 10.6's naturally aspirated. Sure it had 4.10 gear, but the tires were 32", and the trans was an automatic, 1.8 first gear. The manual will propably be a challenge with the long gear ratio. Other than that, it shouldn't be very hard. Our old '67 III run 13.8/103 with a smog short block (not much CR), slightly cleaned open chamber heads, MP 280 hydraulic cam, 1 3/4" headers, Torker 2 intake, 3310 Holley, stock torque convertere and 3.23 gears. Nice do you have any pics of the cars.
