rebuilt 496 sounds like a diesel? Updated with video
#1944646
11/03/15 11:07 PM
11/03/15 11:07 PM
Posts: 1,710 Nebraska
70VcodeCoronetRT
Nebraska
Ok finally got the six pack tuned in and running on the idle circuit. But my concern is this 496 sounds like a diesel. I had the short block put together by a local shop. It is a mild .040 496 with a Mr Six Pack cam. Roughly 471 I 490 E hydraulic. Diamond dish pistons, eagle rods and crank. It doesn't sound like it's coming from the rocker area. I even pulled a valve cover and everything looked good. It sounds like from the block area. Under the intake maybe. Sounds like piston slap. Timing is 18 initial. And has 40lbs oil pressure at idle warm. With a standard oil pump. The motor doesn't miss or stumble at all. Seems to run good. Just sounds like it wants to fly apart. Any ideas before I pull it back out? Thanks
Re: rebuilt 496 sounds like a diesel? long
[Re: 70VcodeCoronetRT]
#1944672
11/03/15 11:24 PM
11/03/15 11:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My guess would be piston rock. There's most likely not a whole lot of skirt in the bore relative to the pin at BDC. I've heard a few strokers that sounded like a coffee can full of rocks at idle. Don't know that I would be all that worried, but it's hard to say without actually hearing it in person. The "diesel" description is common with this issue, not necessarily a problem.
[Re: TRENDZ]
#1944674
11/03/15 11:26 PM
11/03/15 11:26 PM
moparpollack
Lil Herman
Lil Herman
85086
Yup sound like BDC piston rock.
#1944699
11/03/15 11:42 PM
11/03/15 11:42 PM
70VcodeCoronetRT
Nebraska
I have to work tomorrow. But I'll try and get a video up Thursday.
#1944854
11/04/15 04:19 AM
11/04/15 04:19 AM
Posts: 4,848 Memphis
HemiRick
Memphis
^^^^^I 2nd the above, a buddy of mine built a 383 w keith black pistons that were too loose and it sounds just like a diesel.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1944917
11/04/15 11:07 AM
11/04/15 11:07 AM
Posts: 3,916 usa
lewtot184
usa
^^^^^I 2nd the above, a buddy of mine built a 383 w keith black pistons that were too loose and it sounds just like a diesel. all those hypers are noisey when cold but if they're a couple thousands too loose then you really need to turn the radio up.
#1945205
11/04/15 08:05 PM
11/04/15 08:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
My Arias pistoned 400 rod, 3.75 stroke 400 sounded like that for 19 yrs. I finally traded it for a 6.1 Hemi. Piston slap ala mode. Goes away with RPM in my experience.
Mopar to the bone!!!
#1946364
11/06/15 04:12 PM
11/06/15 04:12 PM
Posts: 12,433 Kalispell Mt.
HotRodDave
Kalispell Mt.
Streetwize what cam is in that 517? What exhaust? Sounds awesome!
[Re: lewtot184]
#1946967
11/07/15 03:08 PM
11/07/15 03:08 PM
Posts: 996 Queens, New York
Harley
Queens, New York
doesn't sound much different than my 440 solid lifter, light piston, street engine. is some of that noise valve train related? what type of tappet? any oil restrictors? what rockers? Same here.
