Re: Trick Flow heads
[Re: AndyF]
#1946869
11/07/15 12:32 PM
11/07/15 12:32 PM
BradH
Andy - How's the sweep pattern look w/ the Hughes rockers on the TF heads? I'm going to take a s.w.a.g. they're a little long for those heads w/o trying something like a B3RE relocation kit. Oh, and your picture of the RAS setup makes me (once again) regret having sold mine years ago. I wonder how the new COMP Pro Magnum (?) bushed stainless-steel rockers would work on the TFs? Too bad they only offer a 1.5 ratio.
[Re: AndyF]
#1946987
11/07/15 03:43 PM
11/07/15 03:43 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
Andy, what hold downs are you using in the picture with TF and Hughes rockers?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: Cudajon]
#1947234
11/07/15 10:55 PM
11/07/15 10:55 PM
Posts: 725 Southern Alberta
Uberpube
Southern Alberta
Has anyone got these heads on a running engine yet? If so whats the verdict. Yeah, dying to see some running motor results with these, even OOTB results.
[Re: fast68plymouth]
#1947266
11/07/15 11:42 PM
11/07/15 11:42 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Just info, Andy I run those Huges rockers on my 528, I rate them as the best rockers Ive ever had.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: mopardamo]
#1947321
11/08/15 12:58 AM
11/08/15 12:58 AM
Posts: 31,077 Oregon
AndyF
Hey Andy,
I have the RAS also. How was the sweep pattern across the tip?
Thanks Damon The sweep pattern looks good with the RAS rocker arms up to about .750 lift. If you're going to run more than .750 lift then I'd suggest some Jesel rocker arms.
[Re: Uberpube]
#1947322
11/08/15 01:01 AM
11/08/15 01:01 AM
AndyF
Has anyone got these heads on a running engine yet? If so whats the verdict. Yeah, dying to see some running motor results with these, even OOTB results. IMM has an engine going together with TF heads and so do I. Not sure who will get on the dyno first. I'm sure there are some other guys with engines going together.
[Re: dart games]
#1951444
11/15/15 06:38 AM
11/15/15 06:38 AM
Posts: 126 Oregon
Jamie McGrath
Just a guess, easier too adjust cam adv/ret, less spinning weight and harmonics.
