BB in early A-body
#1943395
11/02/15 12:40 AM
11/02/15 12:40 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I just got a call from a friend who is wanting to build one of his late father's cars, a 65 Valiant. The plan is for a low deck BB and a 6 speed. What are his header options? He is willing to use fenderwells if absolutely necessary.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: BB in early A-body
[Re: poboyengineering]
#1943448
11/02/15 02:50 AM
11/02/15 02:50 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Probally custom made only now ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) At one time(a long, long time ago 1970/71)Hooker made some small tube chassis headers for that applicatiion, diffently not a race header ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) If he is going to use a stock front suspension with the torsion bars he will find out that the BB in the pre 1967 A bodys is a real chore ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I am building a 1965 Dart 270 two door hartop back half race car with the torsion bars removed and a A arm front suspension from CAP, it will have a set fo custom made race headers, probally 2.0 to 2 1/8 or 2 1/8 to 2 1/4 with four inch collectors for a big C.I. race motor with a set of B1-MC heads on a race Koleno wedge block ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) I bought a bunch of the headers parts I'm going to use from Hedaman, one of thier 2.0, one 2 1/8 and one set of the 2 1/4 prebent mandrel bends and collectors and flanges for my car, that should make it easier on the guy who will make my headers for my car ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Tell your friend Good Luck from me ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
#1943479
11/02/15 04:46 AM
11/02/15 04:46 AM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Custom built headers will probably be the only option, especially with clutch linkage. Fenderwells are about the only header I have seen on an early A/big block with the motor in the stock location.
He will also find the trans tunnel is a touch smaller than late A's too.
[Re: turbo toad]
#1943641
11/02/15 02:06 PM
11/02/15 02:06 PM
RapidRobert
Herb McCandless told me that the later Hooker super comp A body headers will work (#5215-1&7/8). At one time decades ago I mocked it up & the dr side fit but 2 tubes on the pass side needed to be cut/altered. Speedway mtrs has leftover pieces from header building for cheap or call your local ex shop (get the same gauge). Reportedly tire rub is the issue & 14's or low profile 15's are likely needed. An option I am considering is max wedge iron manifolds but they are pricey (but the headers are too) & I'm sure the manis would fit with a B & the 68-70 HP iron manis would for sure would fit & I saw a pic of a '66 A with a 440 (RB) with the max wedge manis & they fit. build tolerances in early A's were the worst ever but they are my fav & in some cases the 68-70 HP manis will even fit with a RB (steering col housing is the issue there) but you can shorten the housing (mock up & go from there). You'll likely need to remove the pinch weld in the sloping trans tunnell and in some case raise the tunnell (the tolerance thing again) & I have a JW ultrabell to adapt a 904 to a big block which will guarantee a no weld tunnell fit. Just need to find another good A body roller to work with & they seem to be gold plated these days. EDIT I have streetmaster spool swap mts (nice pieces) but not sure if they are even still in business
#1943663
11/02/15 02:31 PM
11/02/15 02:31 PM
Posts: 368 michigan
turbo toad
michigan
There was a member on fabo that was selling a custom header set for a early A Im not sure if he sold them or not heres the link http://www.forabodiesonly.com/mopar/showthread.php?t=301912I built my own headers and its tight but mine are a upswept forward facing design
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: J_BODY]
#1943869
11/02/15 07:16 PM
11/02/15 07:16 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I agree. Why create more headaches? Build a stroker smallblock and put a good set of heads on it.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: ozymaxwedge]
#1944015
11/02/15 11:22 PM
11/02/15 11:22 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Thats not even as small compartment as the original poster is talking about, that is the later a body.
Don't bother, it is easier to build a 440 SB than it is to change the plugs on a BB early A.
[Re: AndyF]
#1944022
11/02/15 11:27 PM
11/02/15 11:27 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
These days you can build a 427 or 440 inch SB without too much trouble so I'd go that way. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I see that it can be done, but like a lot of things we do once you reach the "point of no return" the small block looks a lot more attractive
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
#1944065
11/03/15 12:06 AM
11/03/15 12:06 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Advise your buddy to find a good header builder regardless of which way he goes, all the commercially available models leave much to be desired.
Fenderwell exit is pretty much the only option with the torsion bars in place.
I've got two examples of BB early A's near me, one a 65 Valiant, the other a 64 Valiant, and both cars worked extremely well.
Unfortunately, my 62 has even less room (at the firewall) so I'm forced to run a small block, or cut it up more than I'd like.
Don't let these guys fool you, a stroker small block will not fill that BB jonesin' we all get!
I know from 1st hand experience. My little 428 will run all day on pump gas, drive to the track and lay down mid 10's uncorked, then run 9's with a touch of nitrous. It has torque for days, and will slide you back in the seat regardless of what gear you punch it on the street! Give me an instant smile every time I lean on it.
But then you get back to the pits after whipping some rat, and pop the hood, and everyone walks over and say's, "It's only a small block?" Then you have apologize and say, "Yeah, I wish it was a big block too, but this was all that would fit!"
![Name: drag-week-2014-great-bend-kansas-017.jpg
ID: 215038 drag-week-2014-great-bend-kansas-017.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/215038/filename/drag-week-2014-great-bend-kansas-017.jpg)
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: qwkmopardan]
#1946466
11/06/15 06:16 PM
11/06/15 06:16 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
This one used homemade fenderwells made of old expipes! Pics with smallblock but used to run a 498!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
#1946909
11/07/15 01:49 PM
11/07/15 01:49 PM
Posts: 4,213 New York
polyspheric
New York
500 years ago, HRM fit a 383 into a '63 Dart, and had trouble with the firewall at the wiper motor, needed minor surgery.
Boffin Emeritus
