Re: Slow Motion Shock Tuning Video's
[Re: FastmOp]
#1946938
11/07/15 02:40 PM
11/07/15 02:40 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I have almost all the boost pulled out of it to not blow the tires off. It's only making 2-3 pounds on the break. 1st pass was more boost then the other two. I sat there on the last pass to make sure it built boost before I let go of the button.. the first pass had more boost then the 2nd pass and the 3rd pass had least. I was trying to tame it down to get it past 60 foot. Then I was going to poor the boost to it.
Yes I changed gears. It feels a lot stronger with the new gears. I also put the new motor in it this year.
You had the MOST power on the first run you say......and that is the ONLY one where it was close to going...........what's that tell you
[Re: TheOtherDodge]
#1946944
11/07/15 02:43 PM
11/07/15 02:43 PM
Monte_Smith
North Alabama
Here will be my initial settings. The track will be ok at Houston's Royal Purple Raceway.
Weight: 3,500 lbs with 80 lbs rear ballast for about 53/47 weight dist Front shocks: +5 from full loose Rear shocks compression: +10 from full stiff Rear shocks extension: +15 from full still Rear tire psi: 17 lbs Launch rpm on brake: 3200 lbs Boost controller: 5 lbs at launch progressed to 15 lbs at 40 mph Shift: 6,000
Thoughts? The fronts are probably going to be way loose for a radial at that setting..........and depending on how Mark has your rears valved, that extension may be too tight
[Re: Monte_Smith]
#1946968
11/07/15 03:09 PM
11/07/15 03:09 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
You had the MOST power on the first run you say......and that is the ONLY one where it was close to going...........what's that tell you [/quote] You treed me Monte! Exactly... Needs a bunch more power!
[Re: dizuster]
#1947034
11/07/15 05:27 PM
11/07/15 05:27 PM
Posts: 368 michigan
turbo toad
michigan
I love this thread so much knowledge and insight thanks all for sharing....ive been learning a bunch
FastmOp what size spring are you running in your wastegate?
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: turbo toad]
#1947379
11/08/15 03:49 AM
11/08/15 03:49 AM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Great question. Think it was stuck. Testing soon.
[Re: dizuster]
#1948673
11/10/15 12:22 PM
11/10/15 12:22 PM
dizuster
Oakland, MI
Well I would say yours probably makes similar power at similar boost as mine. Pretty close anyway… So while I am sure that you could get this thing to leave on 5psi, and ramp in within 3 seconds… that will leave a LOT on the table.
On any halfway decent track, (even Wednesday night test and tune with the street cars running), mine will leave on 12~13psi 4,000rpm two step with absolutely no problem. We’re talking 0.02 60ft consistency over MANY runs, and MANY tracks with that tuneup. The boost is all in as fast as I can possibly get it in (boost controller ramp from 12psi to 16psi in 0.1sec, even though it usually takes around 0.3sec to physically do it). 1.41~1.43 60ft all day long.
Even on arguably the worst absolute JUNK unprepped terrible track I have ever been on in the middle of summer, mine would still leave on 8psi/3500rpm ramping to 16psi in 2 seconds. Only went 1.59 60ft… but it got down the track.
If you were honest with Mark about the power, he sets the baseline tuneup at 15R10C. That means EVERY ONE of his customers starts at that value, because he custom tunes the shocks for your car/power level.
That being said, I would do the following…
Put the car on the trans brake with NO 2 step, and see how loose the converter is at full boost (14psi). Whatever the converter stalls to at that power take 1500RPM off that for the 2 step. (say it goes to 5000 RPM, I would take 1500rpm off that number for the 2 step. So 5000-1500rpm = 3500 two step). Now set the boost controller to 10psi, and plug in that 3500 two step number in. Put it on the trans brake at 3500, and see if it will make 10psi at that RPM level.
If it makes the 10psi… you are good to go. If it won’t make that much boost, move the 2 step RPM up 200rpm at a time until it makes the 10psi you’re looking for.
Set the boost controller to go from 10psi to the full 14psi in 0.3sec.
Set the rear shocks at 15R/10C Do you have caltracs? If so, put the bars in the upper holes, with zero gap on the drivers side, and 2 flats of preload on the passenger side). Set the fronts in the middle of the setting to start.
Go up there and let it eat.
Make a few passes to make sure it will hook, but from there start adding boost/RPM on the launch. I have found that adding boost instead of RPM is easier to get the car off the line. Again, if you can’t make more boost without any more RPM, add 200rpm at a time to get the boost up 1~2psi on the launch. If you try to jump from 10psi at 3500rpm to 14psi at 4000RPM you won’t learn anything. Take slow steps… If you get to a point where you’ve added boost/RPM and it spins, don’t lower the power back down… click the Rebound 2 clicks tighter on the rears and try again… It may need the fronts tightened up too, but it’s really hard to say where to go without watching the car on video, or having someone pretty sharp watching the starting line.
The only advice I can give on the front adjustment, is if the truck “leap frogs” forward and spins, that would be an indication to tighten the fronts. If you’re watching on video, I try to get around a full turn of rear tire rotation before the car picks the front tires up off the ground. If you paint a stripe on the tire, and have someone even slow motion with the iphone, you can usually see this pretty easy.
But for the most part, since you’re just trying to get a handle on getting the truck down the track (not fine tuning), I would say the above tuneup guide will get you started.
Good luck!
