Re: What sbm stroker to run? Help please
[Re: AndyF]
#1946167
11/06/15 10:32 AM
11/06/15 10:32 AM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Why waste money on new gears if you don't need to. In fact, why build a motor and dyno it to figure out what gear to run? All it takes is a few minutes with a calculator to sort it all out. The car weighs 2850 and he wants to run 9.60 so that tells you how much power is required. He has 4.88 gears and 33 inch tires so that tells you RPM in the lights. He already has ported heads so that tells you the CSA. Once you know RPM in the lights and CSA then you can solve for engine size. Get the sonic results to figure out the bore size and then that tells you what the stroke needs to be.
Sounds great bench racing. Rarely works that way at the track. No way to know exactly what the car will trap at until you make a pass and account for convertor slip, knowing where torque is helps to buy the right convertor product. Yes, you generally aren't going to be far off, every gear is 250 or so rpm and you likely aren't going to be wrong more than 1 gear ratio, but your comment to build the motor around an existing gear ration didn't/ doesn't make sense. Build the motor, dyno it( if you can) take it out and run it. Determine the optimal gear for it, and run that gear. If it happens to be the gear in the car, you got lucky.
[Re: J_BODY]
#1946191
11/06/15 11:44 AM
11/06/15 11:44 AM
B3422W5
Portage,michigan
....and your opinion of the 4.8? You've "been there/done that". I'm just thinking light car, the general outline of the build the op has presented, tire size, 904 trans..... the 4.88 will be in the ball park. I didn't catch the tire size. I ran a 4.30 gear with 28 tire, and it likely would have run as good with a 4.10, but I never tried it . Before I sold it I strongly contemplated the swap, 7500 at the stripe would have been nice to knock back 200-300 rpm for more longetivity . Have to be a tall tire to need that much gear(4.88). I depends too how much steam the motor makes. That small bore isn't going to help it any. Mine made peak power 6800ish.
[Re: MGC340]
#1946606
11/06/15 10:26 PM
11/06/15 10:26 PM
Thumperdart
State of confusion
Here are a few pics of the build so far nice Looks like a really nice car in the works....... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Thumperdart]
#1946608
11/06/15 10:28 PM
11/06/15 10:28 PM
Posts: 127 Sioux Falls, SD
MGC340
Sioux Falls, SD
Here are a few pics of the build so far nice Looks like a really nice car in the works....... Thanks! It's a lot of work! Lol
[Re: MGC340]
#1946609
11/06/15 10:29 PM
11/06/15 10:29 PM
Thumperdart
State of confusion
Old Pro-stock comes to mind w/that body style.......
[Re: MGC340]
#1946615
11/06/15 10:37 PM
11/06/15 10:37 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
