Re: 73 Barracuda race car weight
[Re: cudaman1969]
#1945211
11/04/15 08:17 PM
11/04/15 08:17 PM
KOS
my 70 is all orig except bolt on glass hood,fenders,frt bumper and trunk lid.it also has tubular k-member that retains t-bars. its ladder bar car only minitub all orig interior except front race buckets 10pt cage.its 3500lbs with an all alum indy low deck 727 dana 60 and 215 lbs driver.
[Re: cudaman1969]
#1945229
11/04/15 08:55 PM
11/04/15 08:55 PM
Posts: 142 illinois
evenflow
illinois
73 Barracuda fiberglass fenders and hood steel bumpers and doors with stock glass 8 point cage racing buckets no defroster dana no tubs super stock springs small roller cammed 55 over 440 with cast iron -1s two optima batteries 3100lbs low 10.20s 3100, just car or you in it? 3250 with me in it
[Re: Blues_Cuda]
#1945288
11/04/15 10:39 PM
11/04/15 10:39 PM
Posts: 8,383 fredericksburg,va
cudaman1969
fredericksburg,va
My wife's 70 Barracuda...all steel, full interior, stock stroke 440 with 906 heads, a 727 and a Dana 60. Heater, wipers, and all that remain. 3600lbs without driver in street trim.
Runs 11.30's @ about 119mph. Very nice color combo, first thought it was primer, then made it bigger and got a better look.
[Re: Thumperdart]
#1945352
11/04/15 11:38 PM
11/04/15 11:38 PM
Posts: 12,423 Taxes & Virus's R-US, NY
Dragula
Mine was 3230lbs with an iron block Hemi...We now have an aluminum 605 Hemi.... Standard roll bar, race seats, no back seats, no wipers, no heater box, MF front k-frame, and FG hood, full carpeting....Dana 60 with a spool and leaf springs and Wilwoods on all corners...We are thnking one run in the mid 9's and then we slow it down to 10.0's... Put the 1250 on yet....... No...Drove it with the SV1 the other day, and that is probably one jet size too fat, but very close now. It also needs the transition slightly leaned as well. But I have another problem. Probably won't be driving it again for a long while. Got the other blocks yet?
[Re: cudaman1969]
#1945467
11/05/15 02:48 AM
11/05/15 02:48 AM
Posts: 4,086 Mo.
racerx
Mo.
Mine 3350 give or take,had a few xtra bars installed sense the last time I weigh it ![weld weld](/ubbthreads/images/graemlins/custom/weld.gif) anyway that's race weight stock body,glass hood,stock frame rails,tub back to the frame rails,BB with -1 heads,stock front suspension/ladder bars in the back.Best so far 9.40@142 Are the e-body's aerodynamic at that mph and above? Anything needed as the mph goes up? Not saying I'll be in that territory, but who knows. I'm no expert on this but if a had to say ,the 70-71 had a slight advantage in the grill area ![work work](/ubbthreads/images/graemlins/custom/work.gif) verses the 73 which had the big open grill area.
[Re: Dragula]
#1945713
11/05/15 03:57 PM
11/05/15 03:57 PM
Thumperdart
State of confusion
Mine was 3230lbs with an iron block Hemi...We now have an aluminum 605 Hemi.... Standard roll bar, race seats, no back seats, no wipers, no heater box, MF front k-frame, and FG hood, full carpeting....Dana 60 with a spool and leaf springs and Wilwoods on all corners...We are thnking one run in the mid 9's and then we slow it down to 10.0's... Put the 1250 on yet....... No...Drove it with the SV1 the other day, and that is probably one jet size too fat, but very close now. It also needs the transition slightly leaned as well. But I have another problem. Probably won't be driving it again for a long while. Got the other blocks yet? Was waiting for you to call after you drove it remember? When it performs as I think it will, send em to me and I`ll get you black blocks and transfer the tune over for ya....... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
