Re: rebuilt 496 sounds like a diesel? long [Re: 70VcodeCoronetRT] #1947048
11/07/15 06:08 PM
11/07/15 06:08 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Sheet from the machine shop shows a final oversize of 4.360. Using the Diamond 52417 piston. which is a 4.360 bore piston.
Re: rebuilt 496 sounds like a diesel? long [Re: 70VcodeCoronetRT] #1947056
11/07/15 06:25 PM
11/07/15 06:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That doesn't tell you what clearance he set it at .
Re: rebuilt 496 sounds like a diesel? long [Re: 70VcodeCoronetRT] #1947077
11/07/15 07:03 PM
11/07/15 07:03 PM
Nebraska
Nebraska
Looks like .005 piston to wall clearance. If I'm reading his scribbles correct.
Re: rebuilt 496 sounds like a diesel? long [Re: 70VcodeCoronetRT] #1947100
11/07/15 07:56 PM
11/07/15 07:56 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
My first 440 with KB hypers sounded like a diesel at Idle...I mean you could hear that sound a bit. I was told it was a common hyper piston sound. The engine is still running to this day after 15 years with no issues..street / strip.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: rebuilt 496 sounds like a diesel? long [Re: 70VcodeCoronetRT] #1947410
11/08/15 09:55 AM
11/08/15 09:55 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Sounds on the loose side, but is a stroker so that might be normal (I have no experience with storkers yet)
My memory is fuzzy after 25+ years but the TRW forged slugs in my 440 were set to 3 and 1/2. Motor has been together forever, buzzed to 7200 and hit hard with nitrous too.
Cast pistons run tighter than forged as they expand less.
"I think its got a hemi"
Re: rebuilt 496 sounds like a diesel? long [Re: 70VcodeCoronetRT] #1947455
11/08/15 12:09 PM
11/08/15 12:09 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The issue is pistons are not the same diameter at the top as they are in the skirt. with a stroker, the skirt hangs out of the bore at BDC, and the piston is generally much shorter, the top of the piston fits the bore looser, and that is why it "rocks" at BDC.
