Valve Spring Upgrade? BB #1944577
11/03/15 09:41 PM
11/03/15 09:41 PM
IN
ahy Offline OP
ahy  Offline OP
IN
I have enjoyed running my Ed head 496 for about 10 years and this year it got some meaningful road track time... and hammered a lot harder. At the end of the straights it is seeing 6250 RPM or more. I have the rev limit set at 6,500. I am thinking of pulling it for inspection, freshen and better oil pan.
When I do, I am debating valve spring upgrade to make sure it stays happy at 6,250-6,500 RPM. I am running a fast MM lobe flat tappet, .55" lift and 243@.050 duration with stock Ed springs. Comp 10 degree locks. I think the basic Ed spring may be getting marginal at higher revs in this setup. I'm debating a moderate double spring or the Comp beehive. Suggestions welcome.
Re: Valve Spring Upgrade? BB [Re: ahy] #1944586
11/03/15 09:54 PM
11/03/15 09:54 PM
AndyF Offline
AndyF  Offline
I'd go with the beehives if it was my motor. I've used Comp 26120 springs as well as 26055 springs. The beehives are a win-win solution. They are lighter, the retainer is lighter, there is more clearance for the rocker arm and the shape helps avoid harmonics.
Re: Valve Spring Upgrade? BB [Re: AndyF] #1944724
11/04/15 12:04 AM
11/04/15 12:04 AM
IN
ahy Offline OP
ahy  Offline OP
IN
Thanks Andy. The 26120 look like they would handle my application, based on lift at least. Also quite a bit more seat pressure vs the Ed springs (from memory) which should be a good thing with the fast cam.
Re: Valve Spring Upgrade? BB [Re: ahy] #1944796
11/04/15 01:39 AM
11/04/15 01:39 AM
AndyF Offline
AndyF  Offline
I think I have a slightly used set of those sitting in the drawer if you're interested. Probably just have a few dyno pulls on them before I changed combos.
Re: Valve Spring Upgrade? BB [Re: AndyF] #1945865
11/05/15 08:36 PM
11/05/15 08:36 PM
IN
ahy Offline OP
ahy  Offline OP
IN
Thanks. May get in touch when I am ready to pull it.
