Re: Need help fine-tuning my idle RPM
[Re: jb500]
#1946152
11/06/15 08:08 AM
11/06/15 08:08 AM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
While you have the carb apart, take a look at the idle feed passageways on the main body. I too have a Pro-Sys 950 and found that the secondary side had reducer plugs installed in the idle passageways. Removed them and the engine idles much better in gear. It now gets the fuel it was starving for and took away the eye buring lean mixture I chased for a while.
Crap, wish I'd seen this before I put it back together last night and went cruising lol. Sounds like something worth looking into.
[Re: jb500]
#1946296
11/06/15 01:27 PM
11/06/15 01:27 PM
Thumperdart
State of confusion
Got a pic I`m trying to visualize what you`re talking about? Do you mean plugs in the emul. holes? Or the ifr brass plugs? ProSport.....by blocking/pluggin the sec. holes you made it richer and for me when the idle wanders as you stated, it`s USUALLY a bit lean.......
[Re: ProSport]
#1946312
11/06/15 01:49 PM
11/06/15 01:49 PM
ProSport
Akron, Ohio
That makes sense, thanks.
[Re: Thumperdart]
#1946369
11/06/15 03:18 PM
11/06/15 03:18 PM
Posts: 202 TN Hoosier
jb500
TN Hoosier
Got a pic I`m trying to visualize what you`re talking about? Do you mean plugs in the emul. holes? Or the ifr brass plugs? ProSport.....by blocking/pluggin the sec. holes you made it richer and for me when the idle wanders as you stated, it`s USUALLY a bit lean....... In the actual main body, not the metering plates. There were two 8-32 plugs (forget the drill size) installed into the idle passageways on the secondary side. They tapped the body and put in the orifice plugs to restrict idle flow.
[Re: jb500]
#1946462
11/06/15 05:06 PM
11/06/15 05:06 PM
Thumperdart
State of confusion
Later today when I can get to a computer. Cool, thankxxx.......Someone brought me a DaVince carb to check out and I gave it back cos there were holes and plugs in funny places and couldn`t put my name on it.......
[Re: Thumperdart]
#1946665
11/06/15 10:33 PM
11/06/15 10:33 PM
jb500
TN Hoosier
Later today when I can get to a computer. Cool, thankxxx.......Someone brought me a DaVince carb to check out and I gave it back cos there were holes and plugs in funny places and couldn`t put my name on it....... I grabbed an often used Holley diagram rather than pull apart my carb. The two plugs (.035 orifice) were installed into the ports labled #3 (top pic on sheet) on the secondary side.
[Re: jb500]
#1946699
11/06/15 11:29 PM
11/06/15 11:29 PM
Thumperdart
State of confusion
Ya, that`s a first for me I usually drill/tap the t-slot hole next to it..........
[Re: ProSport]
#1946701
11/06/15 11:30 PM
11/06/15 11:30 PM
jb500
TN Hoosier
My combo is pretty close to yours: 10.5:1 263@.050 Dynamic Vert Initial: 25deg Total: 38deg Carb: IFR: 0.035 moved to bottom of metering block IAB: 73 x 4 MAB: 28 x 4 Throttle plates drilled. Idles in gear around 950rpm showing about 13.5 on the AFR gauge.
[Re: ProSport]
#1946753
11/07/15 12:58 AM
11/07/15 12:58 AM
ProSport
Akron, Ohio
Very similar combo for sure, post pics of your car and engine on this thread if you don't mind, I'd like to see them. Your IAB's are way bigger than mine, I'll check for those restrictors in my main body, if I remove them I'll probably have to change my IAB's.?
