Re: Need help fine-tuning my idle RPM
[Re: sixpackgut]
#1940578
10/28/15 06:24 PM
10/28/15 06:24 PM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
my secret timing curve and I don't know if you can do this with the dist your running but it works with the newer mopar ones was
just 1 light spring. not 2
set the timing when its cranking over at 22* then have the advance you want +12* and your timing is rock solid at idle. also ran a collar on my shaft I may play around with that just for the sake of it making it easier to start at 22 degrees initial. My pertronix distributor came with some bars that are like +10, +12 etc. I made some huge progress tonite! I tried some drilled out idle air bleeds that were bigger than the four .067's that were in the carb and it made the motor run terrible. So I put new .061's in the front and some drilled out .064's in the rear and it's much better! Idling at 1100 in park and 900 in gear. I'm heading to Summit right now to buy .061's for the rear of the carb and I think it will be pretty darn good. It's suppose to rain for a couple days so once that's all dried up I'll take it for a spin friday.
[Re: ProSport]
#1940621
10/28/15 07:22 PM
10/28/15 07:22 PM
Thumperdart
State of confusion
Ok I just blocked one primary idle bleed and idle went down slightly, blocked the other primary side and it dropped a couple hundred rpm.
All 4 idle air bleeds are .067, should I try some .072's? That`s a big jump and I usually start at .070 and go from there on MOST 4-corner idle stuff.......
[Re: AndyF]
#1940629
10/28/15 07:30 PM
10/28/15 07:30 PM
Thumperdart
State of confusion
If you know anyone who has an Edelbrock 800 carb that they'll loan you it would be worth the try. You'll be amazed at how much better the Edelbrock will idle on that engine. You'll give up some hp on the top end and it might have other problems such as running out of fuel at WOT, but it will idle really nice.
I keep an Edelbrock 800 around just for tuning reasons. Whenever we bolt on an engine like yours the idle gets so much better the owner can't believe it. Your kidding right? Give the Holley a shot and keep the more TUNEABLE carb and those calibrations are generally WAY off and as Andy said, you can check the ifr`s but start w/the idle bleeds and you`ll be amazed.......Then after that you`ll find there`s too much emultion so plugging and moving becomes my norm. Oh ya, lower the ifr`s while your in there for a more stable idle/fuel curve.......
[Re: ProSport]
#1940675
10/28/15 08:29 PM
10/28/15 08:29 PM
ProSport
Akron, Ohio
Well the car motor wasn't happy with the new .061's in the rear so I went back to the drilled (.064's)back in the rear and ended up setting the air/fuel mixture screws at 1.5 turns and it seems to be running great. Also, the timing does not move when going from neutral to drive, it stays at about 28, total timing is set at 32. It's idling at about 1050-1100 in park, and 900 in gear so I'll keep playing with it but I'm pretty happy with that! To me it's annoying when it idles at 1200-1300 in park for this particular street car. Andy, next time I pull the bowls I'll check for idle jets in the metering blocks, I'm not sure if these are billet or just really clean cast blocks. I figured I'd start with the idle bleeds since they're so easy to change. Once I start leaning over the fenders for hours trying different idle jets in the metering blocks I'll probably have to wear a back brace the next day!
[Re: ProSport]
#1940678
10/28/15 08:33 PM
10/28/15 08:33 PM
ProSport
Akron, Ohio
Oh and I appreciate the info on the Eddy 800 carb but this ProSystems carb on my 500" motor is killer when I'm out driving and playing with the loud pedal, it seems like it is tuned spot-on. I just drove it so much this summer that I didn't have time to mess with the idle RPM til now.
[Re: ademon]
#1940695
10/28/15 09:19 PM
10/28/15 09:19 PM
ProSport
Akron, Ohio
I would drop the initial timing from 28 to about 14 to 18 for starters. I honestly don't know how yet with the Pertronix distributor but I'm gonna try what Sixpackgut mentioned earlier, my distributor came with bars to limit advance. It's running fine though, it doesn't ever have any problems firing up at all, or anything else goofy.
[Re: ademon]
#1940719
10/28/15 09:56 PM
10/28/15 09:56 PM
Posts: 10,632 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would drop the initial timing from 28 to about 14 to 18 for starters. I would maybe go 20-22 base with one light springs and limit the advance to 10-12 degrees. With my Firecore distributor I set the base at 22 and total 34 and my particular combo runs perfect with that timing. I think you really need to get your timing dialed in before even trying to tune the carb. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: ProSport]
#1940722
10/28/15 10:03 PM
10/28/15 10:03 PM
ProSport
Akron, Ohio
Thanks, I'll check the metering block idle jets when I have time to pull them off this weekend. The transition slots are fine I'm sure since both butterflies are not open very far, I remember checking it before installing the carb, I'll check it though when I pull the carb back off.
I have no desire to idle this motor at 500-600 RPM, 850-900 in gear is where I want it and it's pretty much there now, but I do want to learn more about the idle bleeds in the metering blocks.
[Re: fourgearsavoy]
#1940725
10/28/15 10:07 PM
10/28/15 10:07 PM
ProSport
Akron, Ohio
I would drop the initial timing from 28 to about 14 to 18 for starters. I would maybe go 20-22 base with one light springs and limit the advance to 10-12 degrees. With my Firecore distributor I set the base at 22 and total 34 and my particular combo runs perfect with that timing. I think you really need to get your timing dialed in before even trying to tune the carb. Gus Thanks Gus, I'm gonna try that for sure, just need to learn the proper way to do it with the Pertronix. When I tried heavier springs it didn't like it at all, but maybe with the light springs and a 12 degree advance limiter it will be ok? I'll let you guys know when I try it. Car is running very nice though, need some stickier tires before I hurt myself though lol.
[Re: ProSport]
#1940764
10/28/15 11:18 PM
10/28/15 11:18 PM
Thumperdart
State of confusion
I have no desire to idle this motor at 500-600 RPM, 850-900 in gear is where I want it and it's pretty much there now, but I do want to learn more about the idle bleeds in the metering blocks. The ifr`s supply fuel for the idle circuit and on yours hopefully they`re bet. .032-.034 and have seen em as high as .041 on 4150`s.......
[Re: ProSport]
#1940869
10/29/15 07:09 AM
10/29/15 07:09 AM
ProSport
Akron, Ohio
Good info, thanks. How are you guys drilling your air bleeds, are you free-hand drilling or are you making a jig for a drill press?
[Re: ProSport]
#1940889
10/29/15 08:50 AM
10/29/15 08:50 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Good info, thanks. How are you guys drilling your air bleeds, are you free-hand drilling or are you making a jig for a drill press? I have a tall nut/all thread connector that I thread the bleeds into, then chuck into the drill, holding the drill in the bench vise. Hold the drill bit in a pin vice. Think of using it like a lathe. Has worked out so far. Think I borrowed this method from Mark's site... Bought the tall nuts and a bunch of set screws from McMaster, 10-32 for air bleeds and Transfer slot restrictions, 6-32 for emulsion, idle and power valve restrictions.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: ProSport]
#1941027
10/29/15 01:26 PM
10/29/15 01:26 PM
Thumperdart
State of confusion
Good info, thanks. How are you guys drilling your air bleeds, are you free-hand drilling or are you making a jig for a drill press? I made an alum. drill plate and drilled and threaded it for 6-32,8-32 and 10-32 sizes and just use a regular cord drill to drill em w/wd-40 or cutting oil. It can be tricky at first especially w/the smaller .024-.026 bits.......
[Re: OUTLAWD]
#1941101
10/29/15 03:57 PM
10/29/15 03:57 PM
Posts: 4,457 Washington
madscientist
Washington
Good info, thanks. How are you guys drilling your air bleeds, are you free-hand drilling or are you making a jig for a drill press? I have a tall nut/all thread connector that I thread the bleeds into, then chuck into the drill, holding the drill in the bench vise. Hold the drill bit in a pin vice. Think of using it like a lathe. Has worked out so far. Think I borrowed this method from Mark's site... Bought the tall nuts and a bunch of set screws from McMaster, 10-32 for air bleeds and Transfer slot restrictions, 6-32 for emulsion, idle and power valve restrictions. This is the best method if you don't have a lathe. If you have a lathe, you can make a fixture to hole the bleed like above, ot, you can just grab the bleed in the chuck and then hold the drill in a pin vise and drill it out. I try to use as much speed as possible and a light feed to keep from snapping those tiny bits.
[Re: madscientist]
#1941249
10/29/15 07:34 PM
10/29/15 07:34 PM
Thumperdart
State of confusion
So I ASSume you figured your carb out.......
[Re: Thumperdart]
#1941309
10/29/15 09:23 PM
10/29/15 09:23 PM
ProSport
Akron, Ohio
Good info, thanks. How are you guys drilling your air bleeds, are you free-hand drilling or are you making a jig for a drill press? I made an alum. drill plate and drilled and threaded it for 6-32,8-32 and 10-32 sizes and just use a regular cord drill to drill em w/wd-40 or cutting oil. It can be tricky at first especially w/the smaller .024-.026 bits....... This sounds like the best way for me to do it, I don't really have the tools or knowledge to do it the other way mentioned. Yes Thumper, I think it's much better now, air/fuel mixture screws are 1.5 turns out, butterflies are not open very far, idles at 900 in gear and 1050-1100 in park. You guys have given me more ideas to work with, I'll mess with the distributor next. Suppose to be sunny tomorrow so I'll be cruisin!
[Re: ProSport]
#1941322
10/29/15 09:34 PM
10/29/15 09:34 PM
Thumperdart
State of confusion
Good info, thanks. How are you guys drilling your air bleeds, are you free-hand drilling or are you making a jig for a drill press? I made an alum. drill plate and drilled and threaded it for 6-32,8-32 and 10-32 sizes and just use a regular cord drill to drill em w/wd-40 or cutting oil. It can be tricky at first especially w/the smaller .024-.026 bits....... This sounds like the best way for me to do it, I don't really have the tools or knowledge to do it the other way mentioned. Yes Thumper, I think it's much better now, air/fuel mixture screws are 1.5 turns out, butterflies are not open very far, idles at 900 in gear and 1050-1100 in park. You guys have given me more ideas to work with, I'll mess with the distributor next. Suppose to be sunny tomorrow so I'll be cruisin! Glad it`s coming around and my method works well for me..........
[Re: ProSport]
#1941614
10/30/15 11:25 AM
10/30/15 11:25 AM
ProSport
Akron, Ohio
One more question, does a smaller number power valve help the idle? I'm only asking cuz I saw someone mention to someone else on a different site that a 3.5 power valve might help with their big cam/tight converter combo.
