Vacuum advance diaphragm question/part number request 340-6
#1941692
10/30/15 04:23 PM
10/30/15 04:23 PM
Posts: 364 US
f2502011
US
1970 challenger 340-6 has an original vacuum advance diaphragm. Tested with a vacuum pump and it goes down real slowly is this normal or how long should it hold vacuum?
If I have to replace it I'll need to replace it with an original. Anyone know what part number I need to look for? Do they make accurate reproductions or will I be looking at NOS?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6
[Re: f2502011]
#1941698
10/30/15 04:40 PM
10/30/15 04:40 PM
RapidRobert
if it wont hold vacuum then it is shot. any points SB one will fit tho the amt of adv (stamped on the arm will vary) and you can shim the notch in the arm to reduce it and file the notch so it will go in farther (difficult but can be done) for more advance or just plug an play with the one your parts house gives you (you can adj the tip in point with a 3/32" allen wrench). if you need NOS or a repro I ain't up on that.
[Re: f2502011]
#1941717
10/30/15 05:36 PM
10/30/15 05:36 PM
Posts: 26,046 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If I have to replace it I'll need to replace it with an original. Anyone know what part number I need to look for? Manual Trans 3514265 Auto Trans 3620704
[Re: f2502011]
#1941749
10/30/15 06:33 PM
10/30/15 06:33 PM
Posts: 364 US
f2502011
US
How can the bad diaphragm be fixed? I can't seem to find a 3620704 are there other part numbers that would work? It doesn't have to be date code correct or anything just needs to look like the original.
1970 EK2 T/A 727
[Re: f2502011]
#1941785
10/30/15 08:20 PM
10/30/15 08:20 PM
RapidRobert
have your parts house pull one up for you & take yours in & do a side by side visual then make your decision
[Re: f2502011]
#1941795
10/30/15 08:50 PM
10/30/15 08:50 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
How can the bad diaphragm be fixed? I can't seem to find a 3620704 are there other part numbers that would work? It doesn't have to be date code correct or anything just needs to look like the original. Depends on who you know,had this one done a week ago.Also,you won't find one for any Prestolite dual point at a parts house.
[Re: 62maxwgn]
#1941807
10/30/15 09:17 PM
10/30/15 09:17 PM
RapidRobert
Max, who does em? EDIT "Joesixpack" on here might have an NOS one for sale. If he does it'd sure be cheaper than having one redone
[Re: RapidRobert]
#1941825
10/30/15 10:00 PM
10/30/15 10:00 PM
62maxwgn
Blair County,PA
Max, who does em? EDIT "Joesixpack" on here might have an NOS one for sale. If he does it'd sure be cheaper than having one redone Robert,I guarantee you if you find a "correct" Prestolite N.O.S 70 dual point vacuum advance,be it big or small block it will be four times what I can get them done.Here is a sample. http://www.ebay.com/itm/1970-1971-Cuda-Challenger-Road-Runner-GTX-Charger-Hemi-VACUUM-ADVANCE-NOS-MoPar-/361035250057?hash=item540f60b989:g:1R4AAOSwxH1T~-z8&vxp=mtr
[Re: f2502011]
#1941870
10/30/15 11:36 PM
10/30/15 11:36 PM
Posts: 364 US
f2502011
US
I don't know anyone. What should I do to solve my issue?
1970 EK2 T/A 727
[Re: f2502011]
#1941919
10/31/15 12:42 AM
10/31/15 12:42 AM
62maxwgn
Blair County,PA
I don't know anyone. What should I do to solve my issue? Check your PM's
[Re: f2502011]
#1942032
10/31/15 10:55 AM
10/31/15 10:55 AM
Posts: 364 US
f2502011
US
Do the vacuum diaphragms have any markings, part numbers etc., on them? What does dual point mean and how can I tell if mine is dual point or not?
1970 EK2 T/A 727
[Re: f2502011]
#1942034
10/31/15 11:00 AM
10/31/15 11:00 AM
Posts: 364 US
f2502011
US
Here's the parts house one and an original dual point. Not sure it looks much different than an original except it's much brighter and the hexagon section is longer.
1970 EK2 T/A 727
[Re: f2502011]
#1942080
10/31/15 12:37 PM
10/31/15 12:37 PM
RapidRobert
For fitment the critical part is the shape of the arm. Are you good there (both the same & will be if they pulled the correct one for a points SB) and is the finish/longer hex acceptable to you? Also what number is showing on the arms?
[Re: RapidRobert]
#1942185
10/31/15 01:59 PM
10/31/15 01:59 PM
62maxwgn
Blair County,PA
For fitment the critical part is the shape of the arm. Are you good there (both the same & will be if they pulled the correct one for a points SB) and is the finish/longer hex acceptable to you? Also what number is showing on the arms? The distributor in question if what OP posted is correct is from a 340-6 which would be a Prestolite dual point.The Chrysler single point and the electronic use a different breaker plate and the advance is not interchangeable with the dual point plate.
[Re: f2502011]
#1942479
10/31/15 08:59 PM
10/31/15 08:59 PM
Posts: 364 US
f2502011
US
1970 EK2 T/A 727
[Re: 62maxwgn]
#1942489
10/31/15 09:18 PM
10/31/15 09:18 PM
RapidRobert
For fitment the critical part is the shape of the arm. Are you good there (both the same & will be if they pulled the correct one for a points SB) and is the finish/longer hex acceptable to you? Also what number is showing on the arms? The distributor in question if what OP posted is correct is from a 340-6 which would be a Prestolite dual point.The Chrysler single point and the electronic use a different breaker plate and the advance is not interchangeable with the dual point plate. Alright, got it. OP it'll have a # on the arm (& likely a letter such as 16L) & that # times 2 is the amt of max vac adv that can will give you on the crank. I ain't sure what the letter is for.
[Re: John_Kunkel]
#1948733
11/10/15 02:22 PM
11/10/15 02:22 PM
Posts: 364 US
f2502011
US
If I have to replace it I'll need to replace it with an original. Anyone know what part number I need to look for? Manual Trans 3514265 Auto Trans 3620704 Anyone know what the difference is between these two? Mine is an automatic and I haven't been able to find a 3620704 but have found a 3514265.
1970 EK2 T/A 727
[Re: f2502011]
#1948738
11/10/15 02:29 PM
11/10/15 02:29 PM
RapidRobert
Anyone know what the difference is between these two? The only difference will be the amt of (total) adv the can offers (& it'll be stamped on the arm). You might be able to lookup the two different numbers (amounts of adv) & likely can live with/use either one and depending on if the number of the one you get is more or less than your orig bad one you can alter the amt of adv. decreasing it is easy, increasing it is hard(er) but can be done. this is a seperate mod than adjusting the tip in with the 3/32" allen wrench. EDIT What number is on yours and have them check what number is on the one that they do have (& post em)
[Re: f2502011]
#1948806
11/10/15 04:01 PM
11/10/15 04:01 PM
Posts: 364 US
f2502011
US
As I try to get this thing tuned, another question is where is the best place to get a good intake manifold vacuum reading? I've tried the port on the carb for the vacuum advance and there is little if any vacuum there which could also be part of the problem unless that is normal? What should it be? Stock car, stock carbs stock cam etc.
1970 EK2 T/A 727
[Re: 62maxwgn]
#1949461
11/11/15 04:31 PM
11/11/15 04:31 PM
Posts: 364 US
f2502011
US
The vacuum advance port on the carb is ported vacuum,you won't get a reading there at idle,Take it off the PCV port on the carb or directly off the intake.If "nothing" has been modified you should have at least 17" or more. Also,
Incidentally,the Prestolite advance you posted above is for a big block,this is the correct small block advance. What are the differences?
1970 EK2 T/A 727
[Re: f2502011]
#1949899
11/12/15 11:47 AM
11/12/15 11:47 AM
Posts: 364 US
f2502011
US
Pulled my cap to take a look and used vacuum pump to help see what's going on. The VA doesn't do anything until about 8 and doesn't move anymore after 15. It's kinda jerky too and not smooth in its operation.
1970 EK2 T/A 727
[Re: f2502011]
#1949985
11/12/15 02:53 PM
11/12/15 02:53 PM
RapidRobert
The VA doesn't do anything until about 8 and doesn't move anymore after 15. It's kinda jerky too and not smooth in its operation. that is normal, you're in good shape (on this)
[Re: f2502011]
#1950040
11/12/15 04:43 PM
11/12/15 04:43 PM
Posts: 364 US
f2502011
US
I would like to see what number is stamped on the arm but I can't see it with it together. I've never taken one of these apart before how does it come apart so I can see the arm, springs etc.? Is there anything special about it as far as disassembly? Is there a way to know how much advance the distributor has other than figuring it out with a timing light? I've set my initial timing to 10 btdc and I've revved it up to 2000-2500 rpm and it seems the timing wants to keep climbing beyond 36 so I didn't go any higher to see where it would stop going up. I'm used to GM distributors they don't look like this.
1970 EK2 T/A 727
[Re: f2502011]
#1984180
01/05/16 03:09 PM
01/05/16 03:09 PM
Posts: 364 US
f2502011
US
Finally getting around to replacing the vacuum advance. I was unable to find an NOS canister for the automatic but got an NOS 3514265. They look the same but the arm on my original is an 8 and the one on the new one is 8.5. What do I need to do to set up the 3514265 to work as it should for my car?
1970 EK2 T/A 727
[Re: f2502011]
#1984189
01/05/16 03:22 PM
01/05/16 03:22 PM
RapidRobert
I doubt you will notice any pinging from the addit'l (1) degree you'd see on the crank (8.5-8=.5 x 2 = (1) deg. You can JB weld shims on either side of the notch in the arm on the case itself to limit the arms' travel & experiment with thickness till you see 16 addit'l on the crank when you plug in the can (you'd have it idling & plug the can into manifold just for this situation) assuming the chain and intergear slot/dist notch is tight so the mark ain't dancing around at idle so you can see exactly if the can is giving you exactly 16 (8x2)
[Re: RapidRobert]
#1984253
01/05/16 04:41 PM
01/05/16 04:41 PM
Posts: 364 US
f2502011
US
I doubt you will notice any pinging from the addit'l (1) degree you'd see on the crank (8.5-8=.5 x 2 = (1) deg. You can JB weld shims on either side of the notch in the arm on the case itself to limit the arms' travel & experiment with thickness till you see 16 addit'l on the crank when you plug in the can (you'd have it idling & plug the can into manifold just for this situation) assuming the chain and intergear slot/dist notch is tight so the mark ain't dancing around at idle so you can see exactly if the can is giving you exactly 16 (8x2) By chance does the diaphragm adjust with an Allen wrench to limit advance?
1970 EK2 T/A 727
[Re: f2502011]
#1984286
01/05/16 05:28 PM
01/05/16 05:28 PM
RapidRobert
CCW with a 3/32" allen wrench slows when (in hg amt) the curve amt (8x2=16 degrees) starts by tightening the spring so it takes more vac to overcome that tension & there fore at what amt (in hg) the curve ends so in effect once you are in the curve by tightening the spring (CCW) you have less adv at any given in hg amt so likely that would quell any pinging if it did ping exp cuz we are very close on the amt. you would monitor this in eveyday driving under varying RPM/throttle (load) positions
