Vacuum advance diaphragm question/part number request 340-6 #1941692
10/30/15 04:23 PM
10/30/15 04:23 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
1970 challenger 340-6 has an original vacuum advance diaphragm. Tested with a vacuum pump and it goes down real slowly is this normal or how long should it hold vacuum?
If I have to replace it I'll need to replace it with an original. Anyone know what part number I need to look for? Do they make accurate reproductions or will I be looking at NOS?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941695
10/30/15 04:35 PM
10/30/15 04:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If it goes down,it has a bad diaphragm,it can be fixed.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941696
10/30/15 04:37 PM
10/30/15 04:37 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
How can I fix it?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941698
10/30/15 04:40 PM
10/30/15 04:40 PM
if it wont hold vacuum then it is shot. any points SB one will fit tho the amt of adv (stamped on the arm will vary) and you can shim the notch in the arm to reduce it and file the notch so it will go in farther (difficult but can be done) for more advance or just plug an play with the one your parts house gives you (you can adj the tip in point with a 3/32" allen wrench). if you need NOS or a repro I ain't up on that.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941717
10/30/15 05:36 PM
10/30/15 05:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Manual Trans 3514265
Auto Trans 3620704
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941749
10/30/15 06:33 PM
10/30/15 06:33 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
How can the bad diaphragm be fixed? I can't seem to find a 3620704 are there other part numbers that would work? It doesn't have to be date code correct or anything just needs to look like the original.
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941785
10/30/15 08:20 PM
10/30/15 08:20 PM
have your parts house pull one up for you & take yours in & do a side by side visual then make your decision
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941795
10/30/15 08:50 PM
10/30/15 08:50 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Depends on who you know,had this one done a week ago.Also,you won't find one for any Prestolite dual point at a parts house.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: 62maxwgn] #1941807
10/30/15 09:17 PM
10/30/15 09:17 PM
Max, who does em? EDIT "Joesixpack" on here might have an NOS one for sale. If he does it'd sure be cheaper than having one redone
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: RapidRobert] #1941823
10/30/15 09:52 PM
10/30/15 09:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By RapidRobert
Max, who does em?
Trade secret,I can get them done but was requested by the vendor not to give out their information.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: RapidRobert] #1941825
10/30/15 10:00 PM
10/30/15 10:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Robert,I guarantee you if you find a "correct" Prestolite N.O.S 70 dual point vacuum advance,be it big or small block it will be four times what I can get them done.Here is a sample.
http://www.ebay.com/itm/1970-1971-Cuda-Challenger-Road-Runner-GTX-Charger-Hemi-VACUUM-ADVANCE-NOS-MoPar-/361035250057?hash=item540f60b989:g:1R4AAOSwxH1T~-z8&vxp=mtr
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: 62maxwgn] #1941858
10/30/15 11:02 PM
10/30/15 11:02 PM
Max I believe you!
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941870
10/30/15 11:36 PM
10/30/15 11:36 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I don't know anyone. What should I do to solve my issue?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1941919
10/31/15 12:42 AM
10/31/15 12:42 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Check your PM's
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1942032
10/31/15 10:55 AM
10/31/15 10:55 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
Do the vacuum diaphragms have any markings, part numbers etc., on them? What does dual point mean and how can I tell if mine is dual point or not?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1942034
10/31/15 11:00 AM
10/31/15 11:00 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
Here's the parts house one and an original dual point. Not sure it looks much different than an original except it's much brighter and the hexagon section is longer.
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1942080
10/31/15 12:37 PM
10/31/15 12:37 PM
For fitment the critical part is the shape of the arm. Are you good there (both the same & will be if they pulled the correct one for a points SB) and is the finish/longer hex acceptable to you? Also what number is showing on the arms?
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: RapidRobert] #1942185
10/31/15 01:59 PM
10/31/15 01:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The distributor in question if what OP posted is correct is from a 340-6 which would be a Prestolite dual point.The Chrysler single point and the electronic use a different breaker plate and the advance is not interchangeable with the dual point plate.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1942479
10/31/15 08:59 PM
10/31/15 08:59 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: 62maxwgn] #1942489
10/31/15 09:18 PM
10/31/15 09:18 PM
Alright, got it. OP it'll have a # on the arm (& likely a letter such as 16L) & that # times 2 is the amt of max vac adv that can will give you on the crank. I ain't sure what the letter is for.
