Re: Poor man line lock...
[Re: FastmOp]
#1939142
10/26/15 08:04 PM
10/26/15 08:04 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Never use a toggle swith. That's as dangerous as anything. A push button is the only way to go. There is at least one track in my area that will throw you out of the foot brake class if you have your line lock on a button. Their rule is toggle switch only. (NO PUSH BUTTONS)
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: STROKIE]
#1939645
10/27/15 01:41 PM
10/27/15 01:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I know a guy that had that exact setup in his Dart for years. Never heard of it being an issue. Not sure if he still has it or not. I'm sure it will work for what you're doing just fine. Don't let the haters ruin your day. I run a line lick turned backwards like described above to lock out the back brakes; I prefer having control of the brake pressure while on the throttle. Great looking Charger by the way.
[Re: StealthWedge67]
#1939650
10/27/15 01:43 PM
10/27/15 01:43 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I know a guy that had that exact setup in his Dart for years. Never heard of it being an issue. Not sure if he still has it or not. I'm sure it will work for what you're doing just fine. Don't let the haters ruin your day. I run a line lick turned backwards like described above to lock out the back brakes; I prefer having control of the brake pressure while on the throttle. Great looking Charger by the way. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Pretty cool setup that ought to work just fine.
[Re: gtsdude]
#1939763
10/27/15 05:33 PM
10/27/15 05:33 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Or a toggle with a cover on it That is exactly how I am gonna do my LL and TB. Cover open, switch "on" and the device is actuated, close cover (shuts switch), device inactivated. The switches/covers will be behind the shifter.
[Re: Airwoofer]
#1939906
10/27/15 09:40 PM
10/27/15 09:40 PM
Posts: 7,506 Az
Crizila
Az
Here is how I run mine. Toggle switch powers up the red momentary button on the shifter to lock the front brakes. You gotta be pretty deliberate to [censored] it up.
Fastest 300
