Re: Tuning stock 340 Six Pack
[Re: f2502011]
#1972709
12/19/15 03:33 PM
12/19/15 03:33 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
What is the vehicle? What does it weigh, what rear end gears? What trans? Where do you live, what is the ambient temp while you are driving?
If engine temp is too cool it will bog, unless tuned to run at that cool temp. Is the heat crossover in the intake clear and not blocked by a gasket? If you have not even checked the outboard springs yet you are missing important info. Know the basics first, then get fancy.
Why not offset linkage? THINK about it, WHAT does that linkage do? It closes two end carbs, so when your foot says to close them, it needs to happen right now. The linkage does not open the carbs.
WHY do you want offset linkage, what is the gain?
[Re: NANKET]
#1972749
12/19/15 04:42 PM
12/19/15 04:42 PM
Posts: 364 US
f2502011
US
WHY do you want offset linkage, what is the gain? 1970 Challenger 340 6 BBL 3.55 gears whatever a stock one weighs probably between 3000 and 3500 lbs TX torqueflite between 50 and 70 degrees I don't know on the crossover and haven't checked the outboard springs. Why would I want to offset the linkage? I was curious about it and the pros and cons of it since I read that taking one turn out of the rear carb linkage and adding one turn into the front carb linkage may be a possible solution to bog/off idle hesitation in a Jan 92 Chrysler Power article on tuning 6 packs and that's what I'm trying to tackle.
1970 EK2 T/A 727
[Re: crackedback]
#1975594
12/24/15 12:04 PM
12/24/15 12:04 PM
Posts: 364 US
f2502011
US
From the text... Make sure the timing is 15 - 18 deg btdc [advance] at idle. THIS IS IMPORTANT Carry on. Anyone have any tips on how to modify the slot to limit total timing? Where is the slot that I need to modify? I have initial at 10 right now because there is 24-26 mechanical and if I go over 10 I would have too much total timing. To rule out the accelerator pump should I disconnect the linkages and vacuum to the outboards and see if it bogs on just the center?
1970 EK2 T/A 727
[Re: f2502011]
#1975642
12/24/15 01:52 PM
12/24/15 01:52 PM
RapidRobert
(1) the FBO plate ($25 to your door) is the fastest/easiest. You can weld the slots up then file em down to the right amt which is time consuming but free (exc for the welding) and the FBO plate has slots for 10-12-14-16-18 (not mine but I eyeballed one) & for dead on dist tuning if the vac gauge method for initial then wants an odd # to get to say 35 total (tried & true SB amt)then the plate will be slightly off (OCD anyone). Jimmy G the JB weldmaster uses that instead of welding. What I would suggest NOW is bump the initial up to 18/slow the idle/reset initial to 18 (if it changed) & see if you can get a good/low(er) idle. it'll take 5 minutes and you can set the initial back in no time if you ain't happy with the results. EDIT the slots are the 2 oblong holes in the flat cam plate in the dist (pop the cap & you can see em & each one has a pin in it & you are limiting how far that pin(s) can move in the slot by shortening the slot on each side)
[Re: f2502011]
#1975742
12/24/15 04:29 PM
12/24/15 04:29 PM
Posts: 364 US
f2502011
US
Here's some pics of the springs in the pods. Not sure if I need different springs for the bog issue. They look pretty light but don't have a color like black, white or yellow. Anyone know?
1970 EK2 T/A 727
[Re: f2502011]
#1976644
12/26/15 05:32 PM
12/26/15 05:32 PM
RapidRobert
I just saw a chart on here for them (color VS strength) I'd sure think that one would be the "plain" one, iirc the lightest which would as you know come in the quickest/be the most likely to bog
[Re: f2502011]
#1976679
12/26/15 06:45 PM
12/26/15 06:45 PM
Posts: 364 US
f2502011
US
Anyone have any black or brown springs from a kit that they don't need? Just thought I would ask before I buy a spring kit. Also what part number kit would I need should I not score some on here?
1970 EK2 T/A 727
[Re: f2502011]
#1976745
12/26/15 09:02 PM
12/26/15 09:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Do they have to be Holley springs?
Holley PN 20-13 you'll need to order 2 kits, total approx $30 use genuine Holley parts, you don't need any further issues Generally I start with the white springs, and move up the spring range to tailor the opening rate/rpm of the secondaries, rather than working downward from Brown or Black springs...I prefer the secondaries coming in as earliest as possible, and basically as demanded by my right foot, rather than "waiting" for the system to overcome high spring tension in the secondaries Mike
[Re: DAYCLONA]
#1976768
12/26/15 10:04 PM
12/26/15 10:04 PM
Posts: 364 US
f2502011
US
Holley PN 20-13 you'll need to order 2 kits, total approx $30 use genuine Holley parts, you don't need any further issues Generally I start with the white springs, and move up the spring range to tailor the opening rate/rpm of the secondaries, rather than working downward from Brown or Black springs...I prefer the secondaries coming in as earliest as possible, and basically as demanded by my right foot, rather than "waiting" for the system to overcome high spring tension in the secondaries Mike I've read that the Edelbrock and Holley kits are the same. Can anyone confirm?
1970 EK2 T/A 727
[Re: f2502011]
#1977055
12/27/15 01:05 PM
12/27/15 01:05 PM
Posts: 364 US
f2502011
US
Holley PN 20-13 you'll need to order 2 kits, total approx $30 use genuine Holley parts, you don't need any further issues Generally I start with the white springs, and move up the spring range to tailor the opening rate/rpm of the secondaries, rather than working downward from Brown or Black springs...I prefer the secondaries coming in as earliest as possible, and basically as demanded by my right foot, rather than "waiting" for the system to overcome high spring tension in the secondaries Mike I've read that the Edelbrock and Holley kits are the same. Can anyone confirm? Did some more research on this. Holley makes the Edelbrock kit. They are all the same. BIG-10258, 20-13, B5006K, Edelbrock 12412.....and probably some others.
1970 EK2 T/A 727
[Re: crackedback]
#1984102
01/05/16 12:42 PM
01/05/16 12:42 PM
Posts: 364 US
f2502011
US
950 rpm is way too high for a stock cammed 70 340
Turn the initial to 16*, limit mechanical and it may even get rid of your bog. See if it starts hot at 16* and I bet you it's a bunch snappier at idle. Don't drive it with 16* initial until you limit the mechanical advance
Learn what it takes to limit mechanical advance. Otherwise you will be hamstrung with a crappy running car at idle and low rpm due to the emission requirements these cars were built with. Most of what I read says 15-18 initial, but then I've read some other info that says not to go that high and keep it around 12 with my cam so I'm not sure what is best. The engine is a 340 with 10.5:1 compression and the cam has 114 centerline. I'll be running 93 octane pump gas, Autolite 65 spark plugs and have brown springs in the vacuum diaphragms. Should I still go for the initial of 16? I have a limiter plate that will allow me to limit it to initial plus up to 18 more degrees.
1970 EK2 T/A 727
[Re: f2502011]
#1984130
01/05/16 01:41 PM
01/05/16 01:41 PM
RapidRobert
I'm (was) running 18 on a bone stock 83 318. you might do the "vac gauge method" & see what that gets you for what it wants for initial. No way would I think 12 would be better than 16 even WO a cam & with it even more reason to bump it up. At least see what the VGM comes up with & try both ways if desired & tune for both (idle speed back to your lowest reasonable hot idle speed along with mixture screws) & see which acts the best then change the slot choice in the plate then springs then adj the can.
