Page 7 of 45 1 2 5 6 7 8 9 44 45
Re: Trick Flow heads [Re: B Dartman] #1938059
10/24/15 11:49 PM
10/24/15 11:49 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Even more interesting is the fact that the rocker shaft studs need to be all short ones. No long ones required. I used 10x of the 2.500 ARP stud and it worked just fine.
For assurances, what is the ARP Part#?
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: B Dartman] #1938264
10/25/15 12:52 PM
10/25/15 12:52 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Longer head bolts if you already have a stock length 145-3606 ARP Hex head bolt kit and just want to buy the ten longer bolts instead of a complete 145-3609 kit are ARP-HAP4500-5
The only Carbs I care about are under the hood!
Re: Trick Flow heads [Re: Azzkikrcuda] #1938312
10/25/15 02:18 PM
10/25/15 02:18 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Originally Posted By Azzkikrcuda
Short Rockers studs ARP-AJ2500-1B
up up Thank you!
Re: Trick Flow heads [Re: fast68plymouth] #1938331
10/25/15 02:46 PM
10/25/15 02:46 PM
AndyF Online content
AndyF  Online Content
I mocked up the rocker arms with a thick steel hold down and a thick washer and came to the conclusion that a 2.750 long stud would be better.
The Crane rocker arms look like they fit pretty well on these Trick Flow heads.
Re: Trick Flow heads [Re: fast68plymouth] #1938367
10/25/15 04:18 PM
10/25/15 04:18 PM
Different rocker arms on the TF heads:
Re: Trick Flow heads [Re: AndyF] #1938397
10/25/15 05:24 PM
10/25/15 05:24 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Good call; you can see minimal threads captured with this setup - top end of studs.
We're all learning together on these...thanks for the additional update!
up up
Re: Trick Flow heads [Re: fast68plymouth] #1938420
10/25/15 06:15 PM
10/25/15 06:15 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
AndyF,
What is the part number for those rocker cover gaskets. Are those from Felpro?
Re: Trick Flow heads [Re: Beep Beep] #1938454
10/25/15 07:27 PM
10/25/15 07:27 PM
Originally Posted By Beep Beep
AndyF,
Moroso makes them. Rubber coated steel. They work really well with a cast valve cover that has a flat rail. About the only gasket that works with a vacuum pump.
http://www.summitracing.com/parts/mor-93055/overview/
Re: Trick Flow heads [Re: fast68plymouth] #1938509
10/25/15 08:32 PM
10/25/15 08:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've had no luck with those Moroso gaskets, probably cuz I over-torque them. The Superformance gaskets are 10 times better in my opinion.
Re: Trick Flow heads [Re: ProSport] #1938527
10/25/15 09:01 PM
10/25/15 09:01 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
ARP part number for the 2.75 long studs should be ARP-AJ2-750-1B
Re: Trick Flow heads [Re: fast68plymouth] #1938584
10/25/15 10:18 PM
10/25/15 10:18 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
Thanks AndyF!
Re: Trick Flow heads [Re: Azzkikrcuda] #1938612
10/25/15 10:53 PM
10/25/15 10:53 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
up up
Re: Trick Flow heads [Re: fast68plymouth] #1940654
10/28/15 08:54 PM
10/28/15 08:54 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Has anyone got these heads on a running engine yet? If so whats the verdict.
Re: Trick Flow heads [Re: fast68plymouth] #1945322
11/04/15 11:07 PM
11/04/15 11:07 PM
Mock up with RAS rocker arms:
Re: Trick Flow heads [Re: fast68plymouth] #1945828
11/05/15 07:31 PM
11/05/15 07:31 PM
I just got a set of rocker arms from Hughes so I'll get those installed and snap some pictures. The new Hughes rocker arms look great.
Re: Trick Flow heads [Re: AndyF] #1945967
11/05/15 11:10 PM
11/05/15 11:10 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Andy dose RAS still sale those rocker arms and shafts. Looked on there site couldn't find them. Thanks.
Re: Trick Flow heads [Re: fast68plymouth] #1946301
11/06/15 02:32 PM
11/06/15 02:32 PM
No idea. RAS was sold then went out of business and then came back under a different name. The RAS rocker arms used to be the best shaft rocker arm you could buy for a BB Mopar but I don't think they ever sold enough of them to stay in business. I've owned a few sets over the years and always had great luck with them.
Re: Trick Flow heads [Re: fast68plymouth] #1946671
11/06/15 11:41 PM
11/06/15 11:41 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
We are looking at going for a set of these heads for my sons Aussie A Valiant, it is a mild 440, 11-1, 650 lift solid cam that is currently running my Max port 370cfm SR indys. Have been told that the engine would like the smaller T/F's. Might get my heads back smile
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: AndyF] #1946719
11/07/15 12:57 AM
11/07/15 12:57 AM
Hughes rocker arms. This new design looks pretty tough. I like the groove and the beefy design.
Re: Trick Flow heads [Re: fast68plymouth] #1946729
11/07/15 01:24 AM
11/07/15 01:24 AM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
^^^Those look nice.
