Re: Poor man line lock... [Re: FastmOp] #1939142
10/26/15 08:04 PM
10/26/15 08:04 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Originally Posted By FastmOp
Never use a toggle swith. That's as dangerous as anything. A push button is the only way to go.
There is at least one track in my area that will throw you out of the foot brake class if you have your line lock on a button. Their rule is toggle switch only. (NO PUSH BUTTONS)
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Poor man line lock... [Re: D-50] #1939225
10/26/15 09:51 PM
10/26/15 09:51 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
You can buy a spst(single pole single throw) toggle switch with momentary contacts
http://www.grainger.com/product/CARLING-...ic.grainger.com
It's not a push button
"Just a Bracket car dressed up like a streetcar"
Re: Poor man line lock... [Re: STROKIE] #1939236
10/26/15 09:56 PM
10/26/15 09:56 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You can get creative with a monetary. I've wired them too horn buttons, rim blow wheels, blinkers, dimmers, brake lights(on a one time release). Switches under the carpet only you know where they are. and on and on.
Re: Poor man line lock... [Re: STROKIE] #1939598
10/27/15 12:31 PM
10/27/15 12:31 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Or a toggle with a cover on it
Re: Poor man line lock... [Re: STROKIE] #1939645
10/27/15 01:41 PM
10/27/15 01:41 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I know a guy that had that exact setup in his Dart for years. Never heard of it being an issue. Not sure if he still has it or not. I'm sure it will work for what you're doing just fine. Don't let the haters ruin your day. I run a line lick turned backwards like described above to lock out the back brakes; I prefer having control of the brake pressure while on the throttle. Great looking Charger by the way.
Re: Poor man line lock... [Re: StealthWedge67] #1939650
10/27/15 01:43 PM
10/27/15 01:43 PM
an8sec70cuda Offline
iagree Pretty cool setup that ought to work just fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Poor man line lock... [Re: gtsdude] #1939763
10/27/15 05:33 PM
10/27/15 05:33 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
That is exactly how I am gonna do my LL and TB. Cover open, switch "on" and the device is actuated, close cover (shuts switch), device inactivated. The switches/covers will be behind the shifter.
Re: Poor man line lock... [Re: Airwoofer] #1939906
10/27/15 09:40 PM
10/27/15 09:40 PM
Az
Crizila Offline
Crizila  Offline
Az
Here is how I run mine. Toggle switch powers up the red momentary button on the shifter to lock the front brakes. You gotta be pretty deliberate to [censored] it up.
Fastest 300
