Re: Alternator upgrade?
[Re: Wedgeman]
#1937946
10/24/15 09:03 PM
10/24/15 09:03 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
Does the Denso have a built in regulator ? Yes
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 451Mopar]
#1937948
10/24/15 09:08 PM
10/24/15 09:08 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I ran one of their older Ford case converted 140 Amp models. It was what I needed for 2 fans and H4 headlights. Put out 95A at idle.
Mopar to the bone!!!
[Re: Wedgeman]
#1937953
10/24/15 09:15 PM
10/24/15 09:15 PM
fourgearsavoy
Rittman Ohio
COOL
where to find a wiring diagram for this ?
Any part number someone ?
Dan I think Andy can hook you up with a connector and how it's hooked up. I got the connector when I salvaged the alternator off a Toyota pickup. Andy will hook you up with all the brackets and I think he even makes a trick pulley for it too. Just check the AR Engineering website for everything you need for the conversion. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: fourgearsavoy]
#1937993
10/24/15 10:42 PM
10/24/15 10:42 PM
Posts: 1,845 Tampa
DusterDave
Tampa
If 120 amps is all you need, then look for a Denso alternator from a '89-'91 Dodge Ramcharger. I bought one from this company, works great. It's new, and its reasonably priced. It works with the standard Mopar external regulator. 120 amp Denso alternator
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: justinp61]
#1938030
10/24/15 11:20 PM
10/24/15 11:20 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I use the 14611 Denso off ebay, it was cheap and shows 14 volts in my car at all times, best charging setup I've ever owned. AR-Engineering sells the wire pigtail, motor plate mount, and pulley for it. I don't have a good photo of mine but this is Butch's photo...
[Re: justinp61]
#1938031
10/24/15 11:21 PM
10/24/15 11:21 PM
ProSport
Akron, Ohio
Mounting kit
[Re: Gabby63]
#1938262
10/25/15 12:50 PM
10/25/15 12:50 PM
Thumperdart
State of confusion
The Denso is internally regulated and one goes to 12+ and one to keyed 12+ iirc.........
[Re: justinp61]
#1938263
10/25/15 12:51 PM
10/25/15 12:51 PM
ProSport
Akron, Ohio
I don't use a regulator with the 14611, it's internally regulated as far as I know. It's only 60 or 70 amps but it sure does the job.
[Re: justinp61]
#1938273
10/25/15 01:06 PM
10/25/15 01:06 PM
ProSport
Akron, Ohio
On the 3-wire harness:
Red is not used. Blue goes to the large post on my starter relay(always hot). Green goes to a switched 12 volt fuse.
[Re: ProSport]
#1938292
10/25/15 01:44 PM
10/25/15 01:44 PM
Thumperdart
State of confusion
Ya, I didn`t have the connector so I ran one to constant 12+ and the other to a switched 12+ and as you said, the third wasn`t needed.......
[Re: FastmOp]
#1938323
10/25/15 02:30 PM
10/25/15 02:30 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
East coast makes the mini alternator in 1 wire and with the pullys you need.
Will it work with the brackets I already have?
[Re: 451Mopar]
#1938981
10/26/15 03:41 PM
10/26/15 03:41 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Be interesting to hear feedback. They offer a high output 4 Runner alternator. I messaged them to see if it is a direct replacement for the Denso 210-0106 used in Any's kits. I want to go electric fan/water pump/EFI and want a bit more juice than the off the shelf Denso.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
