Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1936779
10/22/15 03:51 PM
10/22/15 03:51 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
BTW,with that black nylon hose, you can use the same fittings that you were using on the braided line, and price wise its almost the same.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1936780
10/22/15 03:52 PM
10/22/15 03:52 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
I have the lined nylon hoses an it bends very easy! Have a shop press the fittings on, it will never leak or come apart. Fittings come in polished, black and red/blue. And no punctured fingertips!
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1936813
10/22/15 04:50 PM
10/22/15 04:50 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have been wraping the lines with electrical tape and using the small cutoff wheels on a Dremel tool. The hose cutter looks like it would be alot quicker. With the nylon covered hose, I just use a razor blade.
The Teflon lined stuff is expensive and does not flex.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1936834
10/22/15 05:18 PM
10/22/15 05:18 PM
Sterling Heights, MI
John_T_Brown Offline
I cut all stainless hose with this:
Summit Hose Cutter
Bought it 10 years ago and never missed a beat. Also the cleanest way you can cut them.
If it ain't broke fix it anyway!
Re: Tool for cutting braided stainless steel hose? [Re: Monte_Smith] #1936963
10/22/15 09:17 PM
10/22/15 09:17 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Originally Posted By Monte_Smith
I know LOTS of people still like and use the braided line with the red/blue ends and I myself, have totes full of lines like that. But these days, I don't know, I guess it just strikes me as very 80s on the look, plus the stuff is heavy and harder to work with. Especially if you have a car with LOTS of plumbing, that look is just very "busy" to me now. While I still do at times use a colored fitting now, it is usually black ends on black hose
If I was building from scratch I would definitely use lighter nylon braided hose. I just have too much braided stainless and red/blue fittings change to something more modern.
Re: Tool for cutting braided stainless steel hose? [Re: Thumperdart] #1936977
10/22/15 10:03 PM
10/22/15 10:03 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Personally, I only use TFE for brake, clutch or nitrous lines.
I have also gotten away from the steel braided stuff period and gone to the black nylon outer braided hose. It's much lighter, has the same core and as an added bonus, you don't bleed after assembling ends on it..........LOL!!!
DITTO...........Plus I cut mine w/scissors or pvc cutters w/ease.......I now use the Earls lightweight hose and fittings $$$$$$ biggrin
I use these to assemble braided lines.
http://www.summitracing.com/parts/kts-416/overview/
I don't stick my fingers anymore. Well worth the price.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Tool for cutting braided stainless steel hose? [Re: Bigcube] #1937193
10/23/15 10:38 AM
10/23/15 10:38 AM
an8sec70cuda Offline
Originally Posted By Bigcube
This works much nicer than a chop saw or cut off wheel since it compresses the end at the same time it cuts. Makes it easier to assemble the ends.
http://www.summitracing.com/parts/sum-900040
iagree This is what I use too. Easiest and cleanest way to do it IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tool for cutting braided stainless steel hose? [Re: OUTLAWSSAA] #1937210
10/23/15 11:35 AM
10/23/15 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
Good to know. Thanks.
Fastest 300
Re: Tool for cutting braided stainless steel hose? [Re: Digger73] #1937251
10/23/15 01:10 PM
10/23/15 01:10 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Digger73 (Mike)
I don't like mine, gets dull real easy.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1937303
10/23/15 02:46 PM
10/23/15 02:46 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
By far the easiest and cleanest way is to use the method shown on the Earl's website. They use a large sharp masonry chisel, a 5 lbs maul and a small flat block of brass.
One good hit is all it takes to cleanly and instantly cut any braided line.
I was shocked when I watched how easy it is to do on their video. They cut all of their lines this way. It leaves the hose clean and the ends perfectly formed with no taping required.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1937310
10/23/15 02:57 PM
10/23/15 02:57 PM
Ohio
Todd Offline
Todd  Offline
Ohio
A sharp chisel and a block of wood. Works very well. Clean cut and no burrs.
Re: Tool for cutting braided stainless steel hose? [Re: jbc426] #1937363
10/23/15 04:17 PM
10/23/15 04:17 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I first saw it done this way over 35 years ago. I can't imagine doing it any other way.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1937405
10/23/15 05:48 PM
10/23/15 05:48 PM
AndyF Online content
AndyF  Online Content
I won't be of much help in this thread since these days I use the black hose. But back in the day when I did use steel braided hose I had the local hose shop make up the lines for me. They have some nice equipment for building hoses since that is what they do all day long. It only costs a few bucks per hose for assembly and pressure check.
Re: Tool for cutting braided stainless steel hose? [Re: Challenger 1] #1937424
10/23/15 06:23 PM
10/23/15 06:23 PM
gregsdart Online content OP
gregsdart  Online Content OP
Originally Posted By Challenger 1
Originally Posted By gregsdart
Thanks, guys. I won't say how long it has been since my lines were changed, but they are waaaaaay over due. The cutter is the way I will go, because like Challenger I also plugged a couple of nozzles trying to use a chop saw. Even after a good cleaning with a bore brush and solvent, something stayed behind.
My problem came from a corroded fitting, not the hose or when the hose was made. Fittings and hose need to replaced after some time. The white stuff stuck in your nozzle is fitting not hose.
I tried a shear years ago to cut hose, like said above it has to be really sharp, if not then your better off with a chop saw IMO.
I did have some issues with "white scum" but that was later. I went to Klotz fuel lube and haven't had any maintenance issues since, which is maybe fifteen years ago. The plugged nozzles were plugged with black bits of rubber from cutting the hose.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1937918
10/24/15 08:09 PM
10/24/15 08:09 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
The method that provided a good quick and clean cut at my old shop was a circular knife. Depending on the number of assemblies you need to build...it might be worth buying such a blade and putting it in your table saw. Cuts like butter.
Re: Tool for cutting braided stainless steel hose? [Re: Bigcube] #1938268
10/25/15 12:55 PM
10/25/15 12:55 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
That tool is akin to cheating. I wrap some masking tape around where the cut is to be made and usually leave the tape there as I put on the fitting, which eliminates any of the wires coming loose. Don't forget to oil the part that goes into the tube.
Re: Tool for cutting braided stainless steel hose? [Re: gregsdart] #1938620
10/25/15 11:09 PM
10/25/15 11:09 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I use an angle grinder with a cutoff wheel. I've found that if you get real aggressive you'll have wires sticking out, but if you go slow there is less chance of wires sticking out. Any wires are ground off with just a LIGHT touch of the wheel. I would buy the tool if I did it often.
Yeah, it's got a smallblock.
