Page 6 of 6 1 2 3 4 5 6
Re: So...how many predator engines are out there? [Re: camastomcat] #1932102
10/14/15 04:33 PM
10/14/15 04:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It sure does look good in there.
Re: So...how many predator engines are out there? [Re: FastmOp] #1932123
10/14/15 05:19 PM
10/14/15 05:19 PM
Chesterfield Twp. Mi.
John Burdine Online work
John Burdine  Online Work
as I said, mock up for headers, that's the old shortblock.
Re: So...how many predator engines are out there? [Re: John Burdine] #1932138
10/14/15 05:43 PM
10/14/15 05:43 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
You should have a lot of people looking at your tail lights when you get those 8 barrels open.
Good luck with your combo.
Re: So...how many predator engines are out there? [Re: dafixr] #1932156
10/14/15 06:09 PM
10/14/15 06:09 PM
Thanks man, i in way over my head $$$, you only live once.
That's a lame excuse, I need to have my head examined.
Re: So...how many predator engines are out there? [Re: camastomcat] #1932157
10/14/15 06:14 PM
10/14/15 06:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
LOL....That motor looks pretty good in there John. Best of luck with it for sure.
Re: So...how many predator engines are out there? [Re: John Burdine] #1932172
10/14/15 06:56 PM
10/14/15 06:56 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Looks awesome John! beer
CHIP
'06 GMC 2500HD LBZ Duramax
Re: So...how many predator engines are out there? [Re: camastomcat] #1932213
10/14/15 08:19 PM
10/14/15 08:19 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Wow! You ain't messing around, John! Looks great!
Re: So...how many predator engines are out there? [Re: STEFF] #1935151
10/19/15 08:47 PM
10/19/15 08:47 PM
are you guys running any additional oil drain-back lines from the heads?
Re: So...how many predator engines are out there? [Re: John Burdine] #1935213
10/19/15 10:00 PM
10/19/15 10:00 PM
Jerry Kathe Offline
Jerry Kathe  Offline
[/quote] Thanks man, i in way over my head $$$, you only live once.
That's a lame excuse, I need to have my head examined. [/quote]
Isn't that all of us? realcrazy
Looks good!
Should be a bad hot rod.
Re: So...how many predator engines are out there? [Re: John Burdine] #1935226
10/19/15 10:14 PM
10/19/15 10:14 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
No need with the Predator heads.
Re: So...how many predator engines are out there? [Re: camastomcat] #1935444
10/20/15 10:18 AM
10/20/15 10:18 AM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
We run oil drain back lines at the rear of our heads (#10 lines), back into oil pan.
Re: So...how many predator engines are out there? [Re: camastomcat] #1936131
10/21/15 01:27 PM
10/21/15 01:27 PM
Salt Lake City
Salt Lake City
You probably already posted this but, are you running an Indy Max block? That's the only reason I would think you would need drainback lines.
Re: So...how many predator engines are out there? [Re: camastomcat] #1936146
10/21/15 01:59 PM
10/21/15 01:59 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
KB block,
Keeping any excessive oil from going on to the rotating assembly is free HP, plus oil is back to pan a little faster instead of being sprayed around.
Re: So...how many predator engines are out there? [Re: camastomcat] #1936792
10/22/15 04:23 PM
10/22/15 04:23 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Had everything to do it but ran out of time.
After running it without, the KB block and heads seems to be draining back just fine.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
