Re: MUSCLE MOTORS 30 MIN ENGINE
[Re: ccdave]
#1934423
10/18/15 07:12 PM
10/18/15 07:12 PM
Thumperdart
State of confusion
This is why I build my own motors. I only have myself to blame when things go south. DITTO..........
[Re: steve660]
#1934437
10/18/15 07:42 PM
10/18/15 07:42 PM
Posts: 4,213 New York
polyspheric
New York
Someone we all know and love, but whose permission I don't have to identify him, had MM build a mild stroker B short block decades ago. In assembling the engine, it won't turn over.
The rods hit the block...
During the last stages of MM's work not one person tried to rotate the engine. Does that tell you something?
All the previous post were correct - every shop has a bad day, myself included. Now, explain this one?
Boffin Emeritus
[Re: B5 Bee]
#1934463
10/18/15 08:28 PM
10/18/15 08:28 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I don't buy this story. How do you assemble an engine and not rotate it? Definitely not BGR but my last mill came to me that way. The rod exited on the fifth pass. I thought it was tight but I figured he does this for a living....silly me.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: steve660]
#1934999
10/19/15 04:18 PM
10/19/15 04:18 PM
polyspheric
New York
Sorry, should have been more clear. IIRC he got the assembled short block, and in the process of buttoning it up he discovered it won't make a full turn.
Boffin Emeritus
[Re: steve660]
#1935377
10/20/15 02:13 AM
10/20/15 02:13 AM
polyspheric
New York
Of course, you're too clever for me, I made the whole thing up.
Let me unravel this: you don't understand how it happened, therefore I'm lying?
Boffin Emeritus
[Re: polyspheric]
#1935544
10/20/15 02:05 PM
10/20/15 02:05 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Sorry, should have been more clear. IIRC he got the assembled short block, and in the process of buttoning it up he discovered it won't make a full turn. Seems the shortblock was assembled............but you never know for sure with some of his posts, as he seems to just want to send out clever remarks and cryptic comments at times instead of real information.
[Re: Monte_Smith]
#1935568
10/20/15 02:49 PM
10/20/15 02:49 PM
BradH
I just asked how you put 8 rod and piston assemblies in a motor and not turn it over... Still a legit question to ask, since I don't know how either.
[Re: steve660]
#1935715
10/20/15 06:47 PM
10/20/15 06:47 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
On my Gen III I got all the way to put #7 and #8 in when I found out the block needed clearancing under the #8 hole to clear the #7 rod cap. Had to go all the way back apart, make the clearance, then get it re-hot tanked and re-painted. Small price to pay for an education.
Mopar to the bone!!!
[Re: DusterDave]
#1935720
10/20/15 07:04 PM
10/20/15 07:04 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ...
[Re: JohnRR]
#1935756
10/20/15 07:53 PM
10/20/15 07:53 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ... I'd like to see it stay open and regular updates on the progress. I have a nice size down payment at MM on a pump gas hemi that should be done early next year. Hopefully my experience is better than the OPs.
[Re: DusterDave]
#1935765
10/20/15 08:11 PM
10/20/15 08:11 PM
Quicktree
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. if he hadn't started this post he would probably be still dealing with a motor he can't use. so hopefully it will inspire them to get done. if one on one would accomplish anything we probably wouldn't be seeing this at all....
[Re: JohnRR]
#1935767
10/20/15 08:13 PM
10/20/15 08:13 PM
Posts: 289 Lowes
steve660
Lowes
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ... This saga is my only documentation for MM to do what they said they would do. And for the record.... I AM, and HAVE been dealing with MM, on a one on one basis, SINCE EARLY JULY!! This build started April 2014...2014!!! This isn't YOUR engine, nor YOUR money were talking about. Its not Your time and energy put in trying to get YOUR car set up with new engine. Only to have to tear it back apart again, crate it, drop it off at trucking company and wait....then have to listen to excuse after excuse why its not done. Whenever I do get it back I will post on here letting everybody know. Then...I get to start putting it back together again.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: gsmopar]
#1935808
10/20/15 09:27 PM
10/20/15 09:27 PM
Posts: 289 Lowes
steve660
Lowes
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ... I'd like to see it stay open and regular updates on the progress. I have a nice size down payment at MM on a pump gas hemi that should be done early next year. Hopefully my experience is better than the OPs. Hey gsmopar, When did they start your build and what kind of a time line did they give you and is it on track to be completed on time?
