Re: Most stable valve train???
[Re: BradH]
#1937268
10/23/15 01:42 PM
10/23/15 01:42 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
I guess you have not seen any of Allen Johnsons top fuel set-ups then - he must be a budget racer - just because it appears to be an old design does not mean its antiquated in function.
[Re: DoubleD]
#1937273
10/23/15 01:51 PM
10/23/15 01:51 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
I guess you have not seen any of Allen Johnsons top fuel set-ups then - he must be a budget racer - just because it appears to be an old design does not mean its antiquated in function. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) They still use springs. http://www.alanjohnsonperformance.com/rocker-assembly/item/76-top-fuel-426-hemi-rockers-parts
[Re: DoubleD]
#1937276
10/23/15 01:59 PM
10/23/15 01:59 PM
BradH
I guess you have not seen any of Allen Johnsons top fuel set-ups then - he must be a budget racer - just because it appears to be an old design does not mean its antiquated in function. I believe you're referring to Alan Johnson, the TF guy, not Allen Johnson, the Pro Stock guy. And all I know is if it's important to keep the rocker stable horizontally on the shaft (not sliding sideways over the valve tip as the loads change), a collar or a solid spacer has got to be far more effective than a spring, which cam compress ('cuz that's what springs do, right?) and let the rocker move around. Seems like a no-brainer to me, but I don't own a Hemi, either.
[Re: 65 Hemi]
#1937371
10/23/15 04:32 PM
10/23/15 04:32 PM
Posts: 4,213 New York
polyspheric
New York
The spring install relies on knowledge of which way the rocker will thrust when loaded - that should be against a hardened and parallel surface, like the shoulder of a stand. I wonder if anyone has tried a radial bearing ("lazy susan") here as thrust control? The spring goes on the other side of the rocker.
If you assemble it correctly, the rocker's lateral position never moves.
Boffin Emeritus
[Re: 65 Hemi]
#1937377
10/23/15 04:39 PM
10/23/15 04:39 PM
polyspheric
New York
Really curious: all that shiny stuff, color anodizing, Grade 99 hardware, million lb. tensile strength valve cover screws...
and yet, with the exception of Barton, every Gen-2 rocker assembly I've seen has no provision for adjusting the geo of intake and exhaust rockers separately - their shafts are on the same stand. Shim/shorten one, shim/shorten both.
What are people with Stage V, yatta, yatta doing when shimming the stand to correct the intake rockers throws the exhaust geo out the window?
Anticipated response:
. . . . . "...what?"
Boffin Emeritus
[Re: polyspheric]
#1937389
10/23/15 05:08 PM
10/23/15 05:08 PM
BradH
I wonder if anyone has tried a radial bearing ("lazy susan") here as thrust control? IIRC, Barton's custom T&D setup for the SS/AH Gen II Hemis uses bearings on the thrust side (possibly both sides). As far as the spring deal... if the load imparted on the rocker by the pushrod is always AWAY from the spring side, then I understand why it shouldn't make a difference. I'm not familiar w/ those engines' rocker & pushrod geometry and where it does / doesn't matter. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: polyspheric]
#1937458
10/23/15 07:36 PM
10/23/15 07:36 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
. . . . . "...what?" In short, you are asking why nobody makes a paired rocker shaft setup for the Gen II HEMI engines? Am I interpreting this correctly? It can be hard to see through the woods around here lol.
[Re: Jeremiah]
#1937469
10/23/15 07:56 PM
10/23/15 07:56 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Barton, Jesel and Brad Anderson make paired and individual single sahft rocker systems for the Gen 11 426 race Hemiroid motors ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) The B.A. parts, individual stainless steel rockers, fit there heads only, I think ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) They sure are nice and they will exceed 11,000 RPM safely repeatably ![work work](/ubbthreads/images/graemlins/custom/work.gif) ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
