Re: Domed vs flat top Indy SR 499
[Re: Eric]
#1933312
10/16/15 05:09 PM
10/16/15 05:09 PM
Posts: 10,049 MN
JERICOGTX
MN
My SR heads are 70cc's, zero deck 499 and right on at 13:1. I also run 110 gas.
69 GTX
68 Road Runner
[Re: Eric]
#1934969
10/19/15 03:03 PM
10/19/15 03:03 PM
Posts: 481 Cheswick, PA
Bob_Spelic
Cheswick, PA
My experience, if you can get the compression you want, is to stay with flat tops. Generally, in my opinion, you will make more power with less timing and if using a production block, that is a good thing.
My 493 with 14cc ross domes ran well, but it made the fastest times on the track with 38/40 degrees of timing. My 572 flat top ross engine only need 30 degrees to make the most on the dyno, but it ran the fastest MPH with 32 degrees.
anyway, a long winded relply.................to say flat tops
[Re: Eric]
#1935170
10/19/15 09:10 PM
10/19/15 09:10 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I cut my cylinder heads down to 62 CC which allowed me to use a very small dome to get 15 to 1 compression. that seems to work pretty good.I think the dome is only about. 0.080 high.
[Re: Eric]
#1935201
10/19/15 09:48 PM
10/19/15 09:48 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Anyone ever mill a domed to flat top?? Wouldn't a lathe be more appropriate due to easier fixtureing? I am gonna get the Diamonds I have flt topped and that was how I thought it could be done easiest.
[Re: Eric]
#1935288
10/19/15 11:32 PM
10/19/15 11:32 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
My ears are buzzing right now from doing a set of KB quench domes flat with a die grinder, very low budget thing here though. Just trying to make them work with a magnum head and not going for any real precise piston head clearance. Local machine shop said $300, for that price I could buy a different piston so an hour later the set I had on the shelf work.
[Re: Eric]
#1935692
10/20/15 06:12 PM
10/20/15 06:12 PM
HotRodDave
Kalispell Mt.
I did that with a router once, just put the pistons on rods in the block. I lost that carbide and have not been able to find another flat ended one aluminum cutting one like that. I tried it with a round ended one and it was NOT happy cutting that hypereutectic material that way.
