Re: NEW Predator tool steel shaft rocker
[Re: camastomcat]
#1933804
10/17/15 03:16 PM
10/17/15 03:16 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
I You guys are running some big stuff in the valve train. I'm just using aluminum rockers with 7/16 double taper pushrods and .937 Crower .180 offset tappets, and as Tony says "smallish cam for a Predator". How much compression are the N/A guys running and how much HP are you expecting to see? Also, what timing are you running? 16.44 to 1 tom as you know, think should be able to make 1270+ hp N/A .expecting total timing to be around 31 degrees , will find out in a month or two on S&S Dyno......
[Re: polyspheric]
#1933842
10/17/15 05:26 PM
10/17/15 05:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Right - if it looks good, the engineering must be perfect, since (as we all know) all bad designs have rough edges, tool marks, etc. Care to elaborate on anything.............or are you just content to make vague shots from the outfield
[Re: John Burdine]
#1933846
10/17/15 05:31 PM
10/17/15 05:31 PM
Monte_Smith
North Alabama
Why does the stiffer rocker on the exhaust side make such a difference? Exhaust side is critical and as stated opens against more pressure. Valvetrain deflection is an issue. Also, you do NOT want a failure on the exhaust side in any motor, but especially a boosted or nitrous motor. With a broken exhaust rocker, the intake keeps piling stuff in the cylinder, but it's not getting out. The NEXT thing to "get out" is usually a rod. As for Cam FX, I run their keyway lifters..............top notch stuff
[Re: EchoSixMike]
#1933932
10/17/15 09:23 PM
10/17/15 09:23 PM
boatracer572
San Jose Ca.
Anyone know if there's any plans to make these for B-1 heads? Or Jesel Tomahawk stuff? S/F.....Ken M I think Chris can make rockers for just about anything! he has 4 cnc machines. If there is a demand (a few sets ) Im sure he would make a run of them.
[Re: Twin Turbo Mower]
#1934479
10/18/15 08:52 PM
10/18/15 08:52 PM
boatracer572
San Jose Ca.
Does the predator heads require offset lifters? No, I do not run offset lifters in mine.....
[Re: boatracer572]
#1934663
10/19/15 02:48 AM
10/19/15 02:48 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
Mine are .937 Jesel keyways. We spread them out as well to get them as straight as we could with the block we had. Also using all left hand offsets. Mine are about a straight as they can get. Required a lot of clearancing to block and heads as well. Still not quite ready but inching closer. Now with the season for the heads up car done things should move a little faster.
[Re: boatracer572]
#1934888
10/19/15 01:13 PM
10/19/15 01:13 PM
Al_Alguire
Las Vegas
Well since everyone is singing his praises I guess someone has to be a little rain. I have found Chris EXTREMELY hard to get ahold of. Don't want to go into to much detail but our experience with them has not been very good. Maybe just bad luck on our part.
[Re: dthemi]
#1936946
10/22/15 08:28 PM
10/22/15 08:28 PM
boatracer572
San Jose Ca.
I just added to my order with CamFX. Aside from the tool steel rockers and 1 inch tappets, I'm having Chris make a full set of Ti rockers for my next predator build as well. I'll post up some pictures when I see them.
Having a better base plate will be nice as well. There's nothing at all wrong with the T+D, just like everything else in the world. There's always something better.
Chris made Ti rockers for some of the winning PS teams before ti rockers got outlawed for PS by the good ole NHRA.
Monte, if you're reading this could you weigh in on the super A nozzle from nos? My manifold has 2 bungs for 90 degree nozzles in each runner, and I don't really want to re fit to annular. The scoop comes down over the manifold as well, I think making annular even more difficult to fit (I think). I'm looking for the meanest 90 nozzle there is.
Yep, Chris told me about your rockers..... 👍👍👍👍👍
