Page 2 of 5 1 2 3 4 5
Re: Moving Battery to trunk, do you have to have a shut [Re: dirtybee] #193293
01/15/09 12:38 AM
01/15/09 12:38 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Some don't like to run the continuous duty relay for the alternator.
I like to run the alternator to one because when the switch gets thrown, there are NONE, ZERO, ZIP, NADA hot wires beyond the cut off and the relay. Nothing hot outside the trunk.
Running the alt + to the battery keeps that line live at all times.
For those playing along at home requiring a visual:
Re: Moving Battery to trunk, do you have to have a shut off [Re: Leadfoot] #193294
01/15/09 02:22 AM
01/15/09 02:22 AM
AndyF Online content
AndyF  Online Content
Does killing "All" power mean it kills the engine and it will not crank either? I can't think of a way to do it with a single set of contacts like most switches that I've seen. I've never put a lot of thought into it either.
The easy way to do it is to put the switch on the negative side of the bat. But evidently the tech guys at NHRA aren't smart enough to allow that logical solution so they insist on the switch being on the positive side. Having the switch on the positive side causes several issues with the charging circuit but NHRA refuses to open their mind.
Re: Moving Battery to trunk, do you have to have a shut off [Re: AndyF] #193295
01/15/09 03:16 AM
01/15/09 03:16 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
that being said...whenever I was tech inspected at any NHRA event,they would have me start the car then they would turn off the switch making sure the engine and all electrical would shut off..I dont recall any of them checking the battery leads or source except whether or not the battery was in a box(no firewall needed) or open and if there was a cell(firewall needed)..
so..yes switching the negative is the best way..and easiest..but not allowed
Re: Moving Battery to trunk, do you have to have a shut off [Re: smokinwoody] #193296
01/15/09 07:36 AM
01/15/09 07:36 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Fire wall still needed if fuel cell is in the trunck area and also the box needs to be NHRA approve for that. Not just a battery box like a marine use box.
Re: Moving Battery to trunk, do you have to have a shut off [Re: MoparforLife] #193297
01/15/09 10:13 AM
01/15/09 10:13 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
IIRC the rules state that the switch must be on the POS side of the battery.
I don't have a rule book with me right now so feel free to correct me if I'm wrong.
Re: Moving Battery to trunk, do you have to have a shut off [Re: WILD BILL] #193298
01/15/09 10:32 AM
01/15/09 10:32 AM
Fort Worth, Texas
Mike Miller Offline
Mike Miller  Offline
Fort Worth, Texas
According to the NHRA rule book....
The switch must be on the positive side and stop ALL electrical fuctions.
This is to shut the engine off and prevent fires from shorted wires after an accident, the same reason you always see the fire department cut the battery cables on a car after a collision hard enough to damage wiring.
Why is it that a rule is put in place for your safety and then people have to try to find a way around it? These switches are a no brainer to hook up. Take the cable coming from the battery to one side of the switch, connect the other side to everything else (thru the starter relay or whatever).
Re: Moving Battery to trunk, do you have to have a shut off [Re: Mike Miller] #193299
01/15/09 12:32 PM
01/15/09 12:32 PM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
How many times have you gotten into the car and realized the switch is in the off position? I put the switch on the driver side rollbar tube that runs from the top of the main loop to the rear of the car. Then a long rod or a chute cable can be mounted right above your head so you can also operate the switch from inside the car. If you have a problem on the track, your the first one there, so you can kill your own power.
Re: Moving Battery to trunk, do you have to have a shut off [Re: Stewart] #193300
01/15/09 05:31 PM
01/15/09 05:31 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Stewart, what if you are knocked out? The switch must accessable from the back of the car so track personnel can cut power.
The switch must be on the positive side because if it is on the negative side and in a crash the neg. cable is cut or chafed it will provide a ground making the switch useless.
Call Mark at Mad electrical 559-539-7128 he will sell you all you need to do it right. Website is www.madelectrical.com
I followed his instructions and have had no problems at all.
The switch can be on the main positive cable but I had a hot start problem with mine wired that way. Mark's way of wiring it solved all that and is NHRA legal too.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Moving Battery to trunk, do you have to have a shut off [Re: fasteddie] #193301
01/15/09 06:13 PM
01/15/09 06:13 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Is the "Ford" solenoid a particular part number,,eg,,from NAPA or the local automotive store ?
I saw in one of the pics a "Borg Warner S605 Continous Duty Relay".... (is this the Ford solenoid that people use?)
ps RobX,,you da man,,great pics/diagrams,,i saved and printed all of them for future reference.
Re: Moving Battery to trunk, do you have to have a shut off [Re: 69CHARGERMD] #193302
01/15/09 06:20 PM
01/15/09 06:20 PM
RobX4406 Offline
RobX4406  Offline
http://www.napaonline.com/NOLPPSE/(S(saf...p;Dk=1&Dp=3
Hope that works. It's the interchange info from napa with part numbers for the relay.
Can't take credit for any of the diagrams. Someone else posted them and I did the same... clicked and saved. They do come in handy!
Re: Moving Battery to trunk, do you have to have a shut off [Re: RobX4406] #193303
01/15/09 06:32 PM
01/15/09 06:32 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Thanks Rob,
I checked the NAPA site,,,they picture 2 different solenoids,,one looks more sturdy than the other,,and price was way different,,,,
Was there a particular one you used ?
I also put the link to MadElectical,,,,
i might get this one,,,has the wires,,and solenoid,,,and the price was pretty good....
http://www.madelectrical.com/catalog/st-1.shtml
Re: Moving Battery to trunk, do you have to have a shut off [Re: WadeMetzinger] #193304
01/15/09 06:55 PM
01/15/09 06:55 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
this be what I did..
Re: Moving Battery to trunk, do you have to have a shut off [Re: smokinwoody] #193305
01/15/09 07:15 PM
01/15/09 07:15 PM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
Fasteddie
The switch is still hooked to the rod that is out the back of the car. It has to be to be legal. But I can also work it from in the drivers seat.
Re: Moving Battery to trunk, do you have to have a shut off [Re: Stewart] #193306
01/15/09 07:48 PM
01/15/09 07:48 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Fasteddie
That's cool. Just trying to be helpful.
Re: Moving Battery to trunk, do you have to have a shut off [Re: fasteddie] #193307
01/15/09 08:38 PM
01/15/09 08:38 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I made mine so the switch can be turned off and on from inside the car or behind it. I can't count how many times I got in and forgot to turn on the power. Not any more.
Re: Moving Battery to trunk, do you have to have a shut [Re: smokinwoody] #193308
01/15/09 08:56 PM
01/15/09 08:56 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
smokinwoody, no offence but i can't see where alot of those wires are going to/ coming from. i would love to see a clear (even drawn with a pencil) diagram of a SIMPLE way to LEGALLY install a 2 prong on/off batt cutoff switch on a car running a mostly stock mopar wiring setup with an orig alternator. i have eliminated the ammeter in favor of the MADELECTRIC voltmeter conversion. can i hook up my switch by simply running a few wires and NO ford solenoid? thats what i want to know. sorry if this is boring or redundant or a hijack but i thought i'd be able to just hook up this overpriced switch and race without a whole rigamaroll?
Re: Moving Battery to trunk, do you have to have a shut off [Re: PLUM BAD] #193309
01/15/09 09:09 PM
01/15/09 09:09 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
very cool plumbad......
Re: Moving Battery to trunk, do you have to have a shut off [Re: PLUM BAD] #193310
01/15/09 09:31 PM
01/15/09 09:31 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Hey guys, this is a great idea, I'm going to relocate my Batt to the trunk this spring!
I currently have a cut out on the neg side right now with the Batt up front, I think I have worn out my door hinges with going in and out to turn in on!! I always forget, Great idea, two methods to control the power!
Thanks!
ED
Re: Moving Battery to trunk, do you have to have a shut [Re: dirtybee] #193311
01/15/09 10:33 PM
01/15/09 10:33 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
none taken...lol...it looks like a mess back there but its realy simple..
its basicaly this..
the alternator goes to the solonoid and then to the battery...when the switch is off,the power is released to the solonoid thus killing the alternator and the switch killing off all positive power from the battery...
Re: Moving Battery to trunk, do you have to have a shut [Re: smokinwoody] #193312
01/15/09 11:01 PM
01/15/09 11:01 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Smokin'
good pics....
I need to re-wire the Belvedere,,,,and put in a solenoid,,,and run a wire up to the alternator....to make it right.
Question:
Where did you get the wiring you have,,,,and how did you know what gauge to use for what ....
thanks,
Doug
ps,,,is the way you have your (+) cable running from battery,,,,,to the kill switch,,,,,and then to the starter how you did it ? ( wont this keep the large,,batt cable running to the front of the car hot ALL the time when teh kill switch is in the on position ? ),,,
in the first diagram that Rob posted,,,the batt cable looks to go thru the solenoid,,,,( i suppose in that case, the batt cable would only be hot during starting ,,,and then "dead" while the car is running ?),,,
I hope i am making sense,,,,
not sure if i am missing something ?
On the Madelectric site,,,they also show the large batt cable going thru the solenoid,,,
I have to figure out how to wire mine.......
Doug
