Re: UPDATE Re: Liquids for Freeing Stuck Engine [Re: Iowan] #1934514
10/18/15 10:20 PM
10/18/15 10:20 PM
IN
ahy Offline
ahy  Offline
IN
Good! Putting a little Marvel Mystery oil in and turning carefully sounds like a good idea. As long as the oil flows and feels slippery, should do the trick.
Re: UPDATE Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1934837
10/19/15 11:35 AM
10/19/15 11:35 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Consider getting temperature on your side by using electric dipstick heaters and magnet attached block heaters.
Alluminum pistons expand at a different rate than cast iron block walls.
I personally would not try it first,
but there is a CRC Freeze-Off spraycan product (78254 05002 barcode)
that could be sprayed with a long tube through the sparkplug holes
directly on the piston crown to cause it to contract
and move the rings enough to potentially free up solid corrosion bindings.
Two or more cold/rewarm cycles might be needed.
Video boroscopes have become relatively cheap.
It might pay to use one with a 9 to 11 mm camera head
to look through sparkplug holes at the piston crown
while someone gently rocks the crank with your breaker bar.
You will see free pistons flex a bit inside rings that are not stuck
but problem cylinders will move little at all.
Remove the distributor cap
and watch for slight rotor movement too.
Good Luck.
Re: UPDATE Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1934855
10/19/15 12:14 PM
10/19/15 12:14 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Tap each rocker arm with a mallet to make sure valves are not stuck in their seats or better yet remove the shaft and tap the springs. I had a 383 once that sat inside for several years and was mildly stuck from sticking valves. Engine was fine, put many miles on it after
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
UPDATE Re: Liquids for Freeing Stuck Engine [Re: Powerflow] #1935084
10/19/15 06:48 PM
10/19/15 06:48 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A friend had a stuck 273 in the car from sitting, got it free with ATF, got it running and it was solid smoke for 30 minutes, then it was all clear and ran fine.
