Re: Moving Battery to trunk, do you have to have a shut
[Re: dirtybee]
#193293
01/15/09 12:38 AM
01/15/09 12:38 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Some don't like to run the continuous duty relay for the alternator. I like to run the alternator to one because when the switch gets thrown, there are NONE, ZERO, ZIP, NADA hot wires beyond the cut off and the relay. Nothing hot outside the trunk. Running the alt + to the battery keeps that line live at all times. For those playing along at home requiring a visual: ![](http://img.photobucket.com/albums/v655/crackedback/trunkbattwire1.jpg) ![](http://img.photobucket.com/albums/v655/crackedback/trunkbattwire2.jpg) ![](http://img.photobucket.com/albums/v655/crackedback/trunkbattwire3.jpg)
Re: Moving Battery to trunk, do you have to have a shut off
[Re: Leadfoot]
#193294
01/15/09 02:22 AM
01/15/09 02:22 AM
Posts: 31,085 Oregon
AndyF
Does killing "All" power mean it kills the engine and it will not crank either? I can't think of a way to do it with a single set of contacts like most switches that I've seen. I've never put a lot of thought into it either.
The easy way to do it is to put the switch on the negative side of the bat. But evidently the tech guys at NHRA aren't smart enough to allow that logical solution so they insist on the switch being on the positive side. Having the switch on the positive side causes several issues with the charging circuit but NHRA refuses to open their mind.
[Re: AndyF]
#193295
01/15/09 03:16 AM
01/15/09 03:16 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
that being said...whenever I was tech inspected at any NHRA event,they would have me start the car then they would turn off the switch making sure the engine and all electrical would shut off..I dont recall any of them checking the battery leads or source except whether or not the battery was in a box(no firewall needed) or open and if there was a cell(firewall needed)..
so..yes switching the negative is the best way..and easiest..but not allowed
[Re: smokinwoody]
#193296
01/15/09 07:36 AM
01/15/09 07:36 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Fire wall still needed if fuel cell is in the trunck area and also the box needs to be NHRA approve for that. Not just a battery box like a marine use box.
[Re: MoparforLife]
#193297
01/15/09 10:13 AM
01/15/09 10:13 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
IIRC the rules state that the switch must be on the POS side of the battery.
I don't have a rule book with me right now so feel free to correct me if I'm wrong. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Stewart]
#193300
01/15/09 05:31 PM
01/15/09 05:31 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
Stewart, what if you are knocked out? The switch must accessable from the back of the car so track personnel can cut power. The switch must be on the positive side because if it is on the negative side and in a crash the neg. cable is cut or chafed it will provide a ground making the switch useless. Call Mark at Mad electrical 559-539-7128 he will sell you all you need to do it right. Website is www.madelectrical.comI followed his instructions and have had no problems at all. The switch can be on the main positive cable but I had a hot start problem with mine wired that way. Mark's way of wiring it solved all that and is NHRA legal too.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: fasteddie]
#193301
01/15/09 06:13 PM
01/15/09 06:13 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Is the "Ford" solenoid a particular part number,,eg,,from NAPA or the local automotive store ? I saw in one of the pics a "Borg Warner S605 Continous Duty Relay".... (is this the Ford solenoid that people use?) ps RobX,,you da man,,great pics/diagrams,,i saved and printed all of them for future reference. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: RobX4406]
#193303
01/15/09 06:32 PM
01/15/09 06:32 PM
69CHARGERMD
KENTUCKY
Thanks Rob, I checked the NAPA site,,,they picture 2 different solenoids,,one looks more sturdy than the other,,and price was way different,,,, Was there a particular one you used ? I also put the link to MadElectical,,,, i might get this one,,,has the wires,,and solenoid,,,and the price was pretty good.... http://www.madelectrical.com/catalog/st-1.shtml
[Re: dirtybee]
#193311
01/15/09 10:33 PM
01/15/09 10:33 PM
smokinwoody
somwhere
smokinwoody, no offence but i can't see where alot of those wires are going to/ coming from. i would love to see a clear (even drawn with a pencil) diagram of a SIMPLE way to LEGALLY install a 2 prong on/off batt cutoff switch on a car running a mostly stock mopar wiring setup with an orig alternator. i have eliminated the ammeter in favor of the MADELECTRIC voltmeter conversion. can i hook up my switch by simply running a few wires and NO ford solenoid? thats what i want to know. sorry if this is boring or redundant or a hijack but i thought i'd be able to just hook up this overpriced switch and race without a whole rigamaroll?
none taken...lol...it looks like a mess back there but its realy simple..
its basicaly this..
![](http://img.photobucket.com/albums/v506/smokinwoody/wiringdiagram.jpg)
the alternator goes to the solonoid and then to the battery...when the switch is off,the power is released to the solonoid thus killing the alternator and the switch killing off all positive power from the battery...
[Re: smokinwoody]
#193312
01/15/09 11:01 PM
01/15/09 11:01 PM
69CHARGERMD
KENTUCKY
Smokin' good pics.... I need to re-wire the Belvedere,,,,and put in a solenoid,,,and run a wire up to the alternator....to make it right. Question: Where did you get the wiring you have,,,,and how did you know what gauge to use for what .... thanks, Doug ps,,,is the way you have your (+) cable running from battery,,,,,to the kill switch,,,,,and then to the starter how you did it ? ( wont this keep the large,,batt cable running to the front of the car hot ALL the time when teh kill switch is in the on position ? ),,, in the first diagram that Rob posted,,,the batt cable looks to go thru the solenoid,,,,( i suppose in that case, the batt cable would only be hot during starting ,,,and then "dead" while the car is running ?),,, I hope i am making sense,,,, not sure if i am missing something ? On the Madelectric site,,,they also show the large batt cable going thru the solenoid,,, I have to figure out how to wire mine....... Doug ![](/ubbthreads/images/graemlins/beer.gif)
