Re: Trick Flow heads
[Re: Skeptic]
#1933118
10/16/15 11:00 AM
10/16/15 11:00 AM
BradH
Summit has them listed with steel or Ti retainers. Info I found from "way back" says there are four different spring & retainer combinations, so the purchaser needs to determine which spring option fits their application: TFS-61617801-C00 1.460″ dual valve springs TFS-61617802-C00 1.550″ dual valve springs TFS-6161T783-C00 1.550″ dual valve springs w/ ti retainers TFS-6161T784-C00 1.560″ dual valve springs w/ ti retainers I know the 1.560" is intended for a solid roller up to .700" lift, but don't know what the others are spec'd for.
[Re: 70RT Charger]
#1933120
10/16/15 11:04 AM
10/16/15 11:04 AM
BradH
If you guys have any ideas and suggestions to make to TF... Well, here's a start, courtesy of a post from earlier: 1. Get guide clearance checked and corrected as needed 2. Get valve seat contact pattern checked and corrected as needed 3. Replace titanium retainers, if equipped, with tool steel retainers for street use << or switch to springs w/o dampers if you're going to still use ti retainers - Brad >> 4. Fill in stupid square holes in head surface
Has somebody made this call to TF yet and let them know instead of getting on here and complaining? Somebody who actually intends to purchase the heads (or works on them for a living) is a better person to pass on this info than someone like myself who is not a prospective customer and is simply compiling info for other's knowledge base.
[Re: Challenger340]
#1933122
10/16/15 11:08 AM
10/16/15 11:08 AM
BradH
A Flowbench never has been, nor ever will be a Dynomometer. And as I am quite sure we all know, it is just a "tool" to measure gains or losses in one particular area. A dyno never has been, nor ever will be, a drag strip. It, too, is a tool to measure gains & losses which may (or may not) translate into real-world performance changes as installed in a given vehcile.
[Re: Iowan]
#1933131
10/16/15 11:27 AM
10/16/15 11:27 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
It would be great if there was a comparison with same short block two sets of heads, Trick Flow and Edelbrock or Indy. This is the question that deserves an answer - so Dwayne what would be your initial thoughts when comparing these 3 heads and which one would have the most potential out of the box and worked over? Russ
[Re: BradH]
#1933143
10/16/15 11:50 AM
10/16/15 11:50 AM
Posts: 1,237 North Central, Indiana
Roughbird72
A Flowbench never has been, nor ever will be a Dynomometer. And as I am quite sure we all know, it is just a "tool" to measure gains or losses in one particular area. A dyno never has been, nor ever will be, a drag strip. It, too, is a tool to measure gains & losses which may (or may not) translate into real-world performance changes as installed in a given vehcile. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
72 Plymouth Roadrunner 11.08@123.25
[Re: BradH]
#1933173
10/16/15 12:30 PM
10/16/15 12:30 PM
Posts: 5,167 CT
GTX MATT
CT
Don't lie to us Brad, we know you want a set
[Re: GY3]
#1933206
10/16/15 01:37 PM
10/16/15 01:37 PM
BradH
Don't lie to us Brad, we know you want a set Does he really need another set of dust collectors? Yes, I do. ![drool drool](/ubbthreads/images/graemlins/custom/drool.gif) And, no I don't. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - I won't lie: I'd already priced it out to see what it would cost to change directions and finish putting my RB 452 back together w/ TFs, and save all my Victor stuff for my fresh RB 451 short block. Because I've switched to a solid roller, and with having bought offset-intake pushrod lifters and the offset-intake rocker arm setup for the Victors, I couldn't do it cheaply enough to justify trying them out. Especially knowing they're still not in the same league as my CNC'd Victors, it would just be a nice "proof of concept" before putting the other parts I've already paid for into service. So, unless somebody(s) else wants to pony up a set of heads, rockers & roller lifters to see what they can do on The MoPig, it ain't happening on my dime! ![tonguue tonguue](/ubbthreads/images/graemlins/custom/tonguue.gif)
[Re: fast68plymouth]
#1933221
10/16/15 02:09 PM
10/16/15 02:09 PM
Posts: 5,167 CT
GTX MATT
CT
I hear you Brad, these look interesting to me, I'm just running a set of lowly OOTB (essentially) stealths, but the question is do I send them to modern for 1K and get them CNCed or pony up extra and start with the Trick Flows. Flow will be similar but a bigger port with the CNCed Stealth (not exactly sure how much bigger), will have to wait and see, and really investigate the options and the ceiling on the Trick Flows. Plus I may need another set of pushrods. And the money spent at Modern gives me a good VJ, which is sounds like the Trick Flows can use a better valve job like all of the other OOTB heads? I need plenty of other stuff for my car before I even get there though. I know you've invested WAY MORE in that Victor setup how are you doing getting past all of the hurdles?
[Re: GTX MATT]
#1933224
10/16/15 02:13 PM
10/16/15 02:13 PM
Posts: 4,704 Wichita
GY3
Wichita
I hear you Brad, these look interesting to me, I'm just running a set of lowly OOTB (essentially) stealths, but the question is do I send them to modern for 1K and get them CNCed or pony up extra and start with the Trick Flows. Flow will be similar but a bigger port with the CNCed Stealth (not exactly sure how much bigger), will have to wait and see, and really investigate the options and the ceiling on the Trick Flows. Plus I may need another set of pushrods. And the money spent at Modern gives me a good VJ, which is sounds like the Trick Flows can use a better valve job like all of the other OOTB heads? I need plenty of other stuff for my car before I even get there though. I know you've invested WAY MORE in that Victor setup how are you doing getting past all of the hurdles? Contact Modern for the actual price, but if you already have good springs and retainers the price is less than $1k. I just had mine done...
#1933226
10/16/15 02:20 PM
10/16/15 02:20 PM
Posts: 5,167 CT
GTX MATT
CT
I did send an email, but I didn't make mention of the springs or retainers but I have changed them already. Will have to follow up thanks!
[Re: dogdays]
#1933831
10/17/15 04:44 PM
10/17/15 04:44 PM
Posts: 345 Nebraska
451Cuda
Nebraska
I predict that the market will soon be flooded with used Stealth heads, that'll be good for me and my aspirations.
R. I'd definitely throw a used set on my 383 mule, so that makes 2 of us
[Re: AndyF]
#1935070
10/19/15 06:19 PM
10/19/15 06:19 PM
fast68plymouth
So. Burlington, Vt.
Dwayne, have you taken a look at how much valve lift a guy can run with these heads? It looks to me that .750 is easy right out the box with a spring change. Not sure if they'll go 0.800 lift or not but it looks really close. I think a set of Manley 221420 springs will fit in there and they should go 0.800 lift at 2.00 installed height. Andy, the roller springs that come on those heads would likely be suitable for just about any roller cam I would use with them. If I were putting something together that I thought needed an .800 lift cam, I would just use bigger heads. That Manley spring is like 900lbs open. I can't see myself opting to run that much spring with a normal shaft set up that only has five 3/8" studs holding it in place, and that much span between the studs. I have no doubt that it won't be long and someone will put a set of these heads on something and run .800 or more lift, and make good power in the process. I just don't feel like that was the type of build these heads were targeting. I'm sure 700hp+will be easy enough to make with a pretty simple 505rb combo and a cam that would work okay with the supplied roller springs........ And that's more along the lines of what I feel is the main type of build these heads were intended for.
[Re: dogdays]
#1935093
10/19/15 06:57 PM
10/19/15 06:57 PM
BradH
R. Only if Stealth users that swore they wanted to keep the "stock look" are willing to give that up. I expect you'll see some Edelbrock Performer RPM heads show up for sale, too.
[Re: BradH]
#1935293
10/19/15 11:36 PM
10/19/15 11:36 PM
Posts: 3,168 Wichita Kansas
B Dartman
Wichita Kansas
Summit has them listed with steel or Ti retainers. Info I found from "way back" says there are four different spring & retainer combinations, so the purchaser needs to determine which spring option fits their application: TFS-61617801-C00 1.460″ dual valve springs TFS-61617802-C00 1.550″ dual valve springs TFS-6161T783-C00 1.550″ dual valve springs w/ ti retainers TFS-6161T784-C00 1.560″ dual valve springs w/ ti retainers I know the 1.560" is intended for a solid roller up to .700" lift, but don't know what the others are spec'd for. I'm close to ordering and have spoken to both Summit and Trick Flow Tech Lines. Both came back with same selection recommendations based on current engine build, valve train, and intended use provided. Give them a call as they were glad to be of help in making the right choice. ....and thanks for all the advice in the post
