Re: 67 Valiant budget built to race 2015
[Re: Tomswheels]
#1743066
01/31/15 05:38 PM
01/31/15 05:38 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
And again the junkyard $150 8.8, out of a 1995 Mustang GT, 3.08 ratio, with the perches welded so that the Hotchkis leafs bolt up nicely...
[Re: Tomswheels]
#1743069
01/31/15 05:47 PM
01/31/15 05:47 PM
Tomswheels
Escondido CA USA
George made some relief cuts in the fenders, welded the lip back on, pushed it out with a pneumatic jack. Note the inches-thick previously applied body filler...
[Re: Tomswheels]
#1743070
01/31/15 06:42 PM
01/31/15 06:42 PM
Tomswheels
Escondido CA USA
You can see how George modified the fender line behind the door as the Fender bulges out around the rear tire. He did similar pneumatic work on the front fenders and gained about 3/4 of an inch up front. In the Rear we have almost 14 inches of rear fender lip to leaf spring clearance. I started thinking about how much more tire we could get in there...
[Re: buconine]
#1743072
01/31/15 09:46 PM
01/31/15 09:46 PM
Tomswheels
Escondido CA USA
stock fuel tank? Looks like the same gas cap i'm running and i'm sloshing gas everywhere...lol.
Thanks for this post!
Funny you should mention that, same problem on first couple laps. Uncontrollable fuel out the cap issues, and since the spare tire well was a bit crusty anyway...
[Re: Tomswheels]
#1743078
02/01/15 02:27 AM
02/01/15 02:27 AM
Tomswheels
Escondido CA USA
The Valiant is still under powered compared to most of these cars, but after a racy alignment, the front grip was much better. I was just starting to play with the Hotchkis/Fox adjustables, at this event. Previously my Barracuda liked a lot of front sway bar but no rear, so I started full stiff on the Valiant front shocks, with both the rear shocks and rear sway bar full soft. Finished third out of thirteen, rear end still felt a bit loose.
[Re: Tomswheels]
#1743079
02/01/15 11:26 AM
02/01/15 11:26 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Great thread and nice car!
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1743080
02/02/15 02:58 AM
02/02/15 02:58 AM
Tomswheels
Escondido CA USA
Thanks, hope this isn't boring anyone, just want to share what I've learned so far. Next event was another CAM battle at our local SCCA. I tried some different used tires (265/35/18 Dunlop Z2) and tried midway between firm and soft on rear shocks.
[Re: Tomswheels]
#1743081
02/02/15 03:02 AM
02/02/15 03:02 AM
Tomswheels
Escondido CA USA
Oversteer felt better, I think the car liked the stiffer setting on the shocks. I also think the Dunlops are just a touch stickier than the same size Falken RT615 k, though both tires perform better cool, neither like a lot of abuse. At this event the junkyard 8.8 started acting up and the limited slip was going away early and often. Finished 2nd out of 12 muscle cars, just a half second off 1st...
[Re: Tomswheels]
#1743082
02/02/15 02:56 PM
02/02/15 02:56 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Tom -- very nice sharing your progress, etc.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1743083
02/02/15 07:00 PM
02/02/15 07:00 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I like these kind of topics and not boring at all. Only thing I'm (still) wondering about is why you've been running with the bare front on the car? Whenever I see pics of the car it always seems to me like you've been in a frontal crash a day before and decided run it unrepaired anyway. I does however make the car more easily recognizable though.. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: BigBlockMopar]
#1743084
02/02/15 07:02 PM
02/02/15 07:02 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
Its a real car now, and trust me, you'll recognize it when you see it ![](/ubbthreads/images/graemlins/smile.gif)
