Re: 1250 dominator too much for my motor?
[Re: sshemi]
#1930103
10/11/15 12:27 PM
10/11/15 12:27 PM
Posts: 304 Florida
Mark Whitener
It's not about HP, it's about induction velocity in the RPM range it runs in. Some heads and intakes are better than others, they maintain a relatively even velocity throughout the port. The 358 would work with a GOOD 1250, one with boosters that atomize the fuel well. Using fuel that vaporizes well will also help, like Q16 or C25. Being in Sweden I would lean toward a 1050, cooler temps there will make it harder to vaporize fuels.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: 70RT Charger]
#1930153
10/11/15 01:44 PM
10/11/15 01:44 PM
Posts: 31,076 Oregon
AndyF
Quick rule of thumb is HP x 1.4 = CFM. So you need to be making about 900 hp before you need 1250 cfm. Just how true is this? If it is I see ALOT of guys running way to big of a carb. 530 HP builds with 950 carbs. By that math figure it should be running a 750. If you used a 750 instead would you still have 530 HP? The formula is just simple math. An engine burns fuel to make power and the fuel needs air to burn. It takes 1/2 lb of gas per hour to make 1 hp and it takes 12.5 lbs of air for each lb of gas. So with a little bit of math you can figure out how many cubic feet of air is required to produce one horsepower. The size of the carb is a slightly different question than how much air the engine needs. How much air is a math question. The carb size depends on a bunch of other things such as throttle response and ability to vaporize the fuel.
[Re: sshemi]
#1930272
10/11/15 05:02 PM
10/11/15 05:02 PM
Posts: 4,457 Washington
madscientist
Washington
Yup .5 BSFC and I'd call it a pig with a capital P-I-G.
[Re: sshemi]
#1931634
10/13/15 08:53 PM
10/13/15 08:53 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
As I said before those 1250 Holley's just have to much throttle blade for MOST ON HERE.
We run a splayed valve SB Chebbie with a 2.35 throttle blade. So engine size means nothing to be brutally honest.
[Re: madscientist]
#1932060
10/14/15 03:41 PM
10/14/15 03:41 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Yup .5 BSFC and I'd call it a pig with a capital P-I-G. While that IS true in most cases.........for most basic calculations a .5 brake is still a decent number to use. It gets you in the ball park
[Re: Monte_Smith]
#1932141
10/14/15 05:50 PM
10/14/15 05:50 PM
madscientist
Washington
Yup .5 BSFC and I'd call it a pig with a capital P-I-G. While that IS true in most cases.........for most basic calculations a .5 brake is still a decent number to use. It gets you in the ball park Your right Monte...if I was calculating fuel system requirements I would use .5 BSFC just to do the quick math. I was suggesting that on the dyno .5 BSFC would be junk and I still stand by that. I have had my stuff go under .42 most of the time and highly prepped stuff go under .40 and I am by no means cutting edge. I'm trying to find a dyno closer to me, but I will dyno my junk here in the next month or so and I will post it up. If the BSFC is near .5 I will stop and fix it. I can't for the life of me figure .5 being the "rule" for even bracket crap after about 1995 or so (maybe earlier).
