Re: Trick Flow heads
[Re: AndyF]
#2193570
11/09/16 11:26 PM
11/09/16 11:26 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
No, I don't have the right equipment to do that. I can shoot video with my iPhone and then do slow motion but I haven't tried it yet. My guess is that the iPhone can't slow down enough to see anything but I could be wrong. The strobe does the work. Just turn the room lights down. Easiest way is using a timing light since it will be synced to the motor, so it will fire at the exact same time every revolution. It'll look like the valves aren't moving, but you will be able to see anomalies like spring oscillation, or various parts deflecting. You'll also be able to video it with just a regular cell phone at normal speed since it will only pick up the split second the timing light fires. If the timing light has that dial on it, you can delay the firing of the light to see the rocker at different amounts of lift. Just think of what the damper looks like when you're setting the timing. I don't know how long you can keep the motor at high revs, but just try it at idle and I think you'll be intrigued. Of course seeing a video with the clear covers would be great, too.
[Re: fast68plymouth]
#2198108
11/17/16 06:39 PM
11/17/16 06:39 PM
Posts: 636 Graz, Austria
DGS
Graz, Austria
Thank you Andy! Why 24 short studs and not 22 like in the TF kits? What's the thread for the studs? 3/8-16 and 3/8-24? Can't find the 2.725 studs online. Do you have a part number?
#2203341
11/27/16 03:13 PM
11/27/16 03:13 PM
Posts: 14,495 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Are you going to back-to-back the 240's and 270's on the other short block?
[Re: AndyF]
#2203455
11/27/16 07:26 PM
11/27/16 07:26 PM
fast68plymouth
So. Burlington, Vt.
I'm not sure about a back-to-back test since that is so much work but I do plan to run the 270 heads on the same 470 inch shortblock with the same camshaft. That's close enough for me.
