Re: Trick Flow heads
[Re: rickseeman]
#1928328
10/08/15 01:19 PM
10/08/15 01:19 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Since I don't know anything about a wedge why don't you guys enlighten me. Does this mean you use a bigger cam? I don't like rollers. Would a .590 lift purple shaft work well with these in a 512 BB? Thanks. Purple shaft with stock stamped rockers are the HOT ticket right now.
[Re: AndyF]
#1928330
10/08/15 01:20 PM
10/08/15 01:20 PM
Posts: 5,160 Texas
dannysbee
Texas
I was planning on buying the std. port 440EZs for the 463 i'm putting together, but may now wait to see some more flow numbers on the Trick Flows. Decisions, decisions More flow tests won't change how the heads work; I'll be interested in how they perform on an engine. I'll have dyno numbers in a few weeks. Great Andy looking forward to it.
Getting old just means you were smarter than some and luckier than others.
[Re: Streetwize]
#1928337
10/08/15 01:37 PM
10/08/15 01:37 PM
BradH
I think the only standard port head that tops these As-delivered were the old Chapman Stage VI 260 (which I think JohnRR sent to Dwayne the same time I sent my Chap 265 MW's) And the Chapmans were Raised ports and long valve heads that need special rocker gear. I think they went 360 up around .600-.650, may still be in the Moparts archives. Not sure they were any better than these at .400-.450 though. I can provide some comparative data from Dwayne's current bench (a Saenz 600) tested on the same 4.375" bore: A. My old PRH-ported MP Stage VIs w/ 2.14" intake valves and small 215 cc runners (w/o RB adapters added). On a 10.8:1 CR RB 452 short block using a modified MP M1 intake, my BG "825" carb, 2" headers and a 266 at .050" x .600" x 108 LSA SFT cam, it made around 610 HP & 570 Tq on Dwayne's dyno. Lift -- Int / Exh (no flow tube) .100 --- 69 / 53 .200 -- 143 / 108 .300 -- 213 / 146 .400 -- 262 / 181 .500 -- 293 / 211 .550 -- 305 / 222 .600 -- 307 / 231 .650 -- 307 / 237 .700 -- 307 / 243 B. My Hughes CNC-ported 1st-generation Edelbrock Victors w/ 2.20" intake valves and an estimated 270 cc runner volume (adjusted down about 40 cc for the built-in RB adapters). Like the Chapmans, these have raised ports and need special-offset intake rockers. Lift -- Int / Exh (no flow tube) .100 --- 75 / 58 .200 -- 169 / 109 .300 -- 237 / 157 .400 -- 280 / 201 .500 -- 318 / 229 .550 -- 329 / 239 .600 -- 341 / 246 .650 -- 347 / 253 .700 -- 345 / 256 At the same CR as the MP Stage VIs and the .650" roller version of the SFT mentioned above, I'll take a s.w.a.g. and say I'd expect to see 640+ HP from the Trick Flows on the same RB 452 short block as the Stage VIs were tested, between the different heads and switching to a roller. But it's all just educated(?) guesses until someone puts 'em in service.
[Re: BradH]
#1928340
10/08/15 01:41 PM
10/08/15 01:41 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I ported a set of rpm`s years ago on Pettis`s dyno that went 327-224 iirc... Ummm... I think you mean flow bench, not dyno. My bad, too many blue moons..........
[Re: BradH]
#1928344
10/08/15 01:54 PM
10/08/15 01:54 PM
Posts: 14,494 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Brad, didn't some combination of stuff we tried end up making like 625hp?
The CNC "standard" port Victors had quite a bit bigger port opening as I recall compared to a true std sized head. These TF heads have port openings that look like a std valley pan gasket would seal up okay.
This particular set I have in the shop are going on a pump gas 505 with a solid cam and a 6bbl.
[Re: fast68plymouth]
#1928354
10/08/15 02:06 PM
10/08/15 02:06 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
Here's the Chapman 260 standard Ports ( from the Tech archives)
These are the Chapman CNC'd MP Stage VI 260cc's:
Lift" I/E
.100--71.5/58.2 .200-150.0/118.6 .300-219.4/180.0 .400-278.7/219.4 .500-323.6/233.9 .550-338.9/240.3 .600-352.3/243.5 .650-348.5/246.7 .700-348.5/249.9 .750-348.5/251.5 .800-348.5/253.1
I think up to .450 the TW's are impressively close. 290cfm at only .450 is gonna be killer, you basically only need a very mild .525-.550 lift cam to easily cover 600hp, easy on the RPM/bottom end, easy on springs too
#1928368
10/08/15 02:22 PM
10/08/15 02:22 PM
BradH
Brad, didn't some combination of stuff we tried end up making like 625hp? Yeah, my ported Victor intake, a 1" open spacer and your CFS "dyno mule" Holley made about 625 HP. The 610 HP I referenced was as I ran it in my car (my carb & my ported M1 intake because of hood clearance), so I can correlate that to the car's on-track performance. A modified Victor on the TFs w/ the .650" RX roller... 650+ HP? (EDIT: The standard port location would even allow for running a Victor intake under my T/A hood ) The CNC "standard" port Victors had quite a bit bigger port opening as I recall compared to a true std sized head. These TF heads have port openings that look like a std valley pan gasket would seal up okay.
Right; Hughes' "standard" CNC job still opens the entry to 2.40" x 1.30"; not MW, but definitely bigger than a standard valley tray port size. (EDIT: Found something that says the TF port entry is 2.270″ x 1.230... is this what you measured, too?) This particular set I have in the shop are going on a pump gas 505 with a solid cam and a 6bbl. Bet my ol' 440 6BBL RR would have loved that engine!
[Re: BradH]
#1928378
10/08/15 02:36 PM
10/08/15 02:36 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I was planning on buying the std. port 440EZs for the 463 i'm putting together, but may now wait to see some more flow numbers on the Trick Flows. Decisions, decisions More flow tests won't change how the heads work; I'll be interested in how they perform on an engine. I agree, but just want to see what the numbers may be after a little hand work. I'm wanting something in the 320-325cfm at .600".
72 Plymouth Roadrunner 11.08@123.25
[Re: AndyF]
#1928385
10/08/15 02:44 PM
10/08/15 02:44 PM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I was planning on buying the std. port 440EZs for the 463 i'm putting together, but may now wait to see some more flow numbers on the Trick Flows. Decisions, decisions More flow tests won't change how the heads work; I'll be interested in how they perform on an engine. I'll have dyno numbers in a few weeks. I hate to say this Andy but your DYNO numbers never show up in track times. Something in your corrections must be accrue. LOVE your products and use them but MOST dyno numbers are way out in left field almost as bad as the rag racing magazines. Hopefully track times will be posted early spring.
[Re: pittsburghracer]
#1928506
10/08/15 06:14 PM
10/08/15 06:14 PM
Posts: 31,018 Oregon
AndyF
I was planning on buying the std. port 440EZs for the 463 i'm putting together, but may now wait to see some more flow numbers on the Trick Flows. Decisions, decisions More flow tests won't change how the heads work; I'll be interested in how they perform on an engine. I'll have dyno numbers in a few weeks. I hate to say this Andy but your DYNO numbers never show up in track times. Something in your corrections must be accrue. LOVE your products and use them but MOST dyno numbers are way out in left field almost as bad as the rag racing magazines. Hopefully track times will be posted early spring. You don't have a clue what you're talking about. The dyno that I use sends a lot of engines to the track and the track times back up the dyno numbers. You live a couple of thousand miles away from me and don't know anything about the dyno that I test on or the engine shop involved.
[Re: B Dartman]
#1928879
10/09/15 10:01 AM
10/09/15 10:01 AM
Posts: 4,669 Wichita
GY3
Wichita
Call Trick flow and let us know please LOL - Yup, was going to call Friday Uh oh! Bill stepping it up a notch...
[Re: B Dartman]
#1928920
10/09/15 11:28 AM
10/09/15 11:28 AM
BradH
Are the Trick Flows available w/stock straight plug design? Or are they all angled plugs? I'd say to expect they're ALL angle-plug because it goes w/ how the chamber was designed.
[Re: 70VcodeCoronetRT]
#1928924
10/09/15 11:32 AM
10/09/15 11:32 AM
BradH
Someone needs to remake the Chapman heads. You mean that still need RB adapters and sell for $2500+ each bare? I don't think so... They really missed the market for those. Edelbrock could have nailed it w/ the Victors, only they didn't get it "right" either. At least you can still buy Victors and they priced them reasonably.
[Re: Roughbird72]
#1928931
10/09/15 11:48 AM
10/09/15 11:48 AM
BradH
I was planning on buying the std. port 440EZs for the 463 i'm putting together, but may now wait to see some more flow numbers on the Trick Flows. Decisions, decisions More flow tests won't change how the heads work; I'll be interested in how they perform on an engine. I agree, but just want to see what the numbers may be after a little hand work. I'm wanting something in the 320-325cfm at .600". According to Trick Flow, they already are.
[Re: BradH]
#1928951
10/09/15 12:17 PM
10/09/15 12:17 PM
Roughbird72
#1929705
10/10/15 05:40 PM
10/10/15 05:40 PM
fast68plymouth
So. Burlington, Vt.
It seems every time a new product comes on the market there is always something about it that makes you scratch your head..... Like these harmless looking little squares cast into the decks of these new TF heads
