Re: Power Steering Gear Box Brace #4447405 BACK IN STOCK [Re: LilRed7879] #2361753
08/29/17 02:44 PM
08/29/17 02:44 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Thanks for info.
Larry
Facts are stubborn things.
Re: Power Steering Gear Box Brace #4447405 BACK IN STOCK [Re: LilRed7879] #2364106
09/02/17 03:24 PM
09/02/17 03:24 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I received my brace, now just need to buy hardware.
It reads this: "Customers have used on 4x4's as well as W350 by using longer bolts. One customer sent the following information: "I bought your steering box brace for my daughters 93 w350, not knowing it was for 2wd applications....I had it, so I figured I'd try modifying it... I got longer bolts obviously, bolting through the factory box plate, the rail, and your bracket... amazing difference in bumpsteer"!
Anyone know how much longer I need the bolts to be? Want to have the right hardware on hand. Truck is at mechanics shop and I can't take measurements. Instructions for 2wd state I need this:
4 - 7/16"- 14 x 1 3/4" Grade "8" bolts
6 - 7/16" Grade "8" Lock Washers
6 - 7/16" Grade "8" Flat Washers
2 - 7/16" Grade "8" Nuts,
Thanks. Larry
Re: Power Steering Gear Box Brace #4447405 BACK IN STOCK [Re: LilRed7879] #2364112
09/02/17 03:48 PM
09/02/17 03:48 PM
Guitar Jones Offline
I installed my brace yesterday. Mine is a 2WD diesel. I had to grind a little half moon on the top of the plate just behind the forward most bolt hole for frame clearance. Not a big deal and it's only about the radius of a quarter.
I did not have to drill the front cross support though as it was already slotted there. I couldn't find 1.75" long bolts so I used 2" bolts and they fit just fine.
Thanks for getting these made again!
Re: Power Steering Gear Box Brace #4447405 BACK IN STOCK [Re: LilRed7879] #2364171
09/02/17 06:19 PM
09/02/17 06:19 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
4wd requires different length and I don't know if 2" long enough. I guess I'm going to wait and hope when mechanic is ready I'm not at work and available to run to hardware store and get what he needs. I just don't want to buy ones that are too long, if that's possible.
Re: Power Steering Gear Box Brace #4447405 BACK IN STOCK [Re: LilRed7879] #2405477
11/18/17 03:27 PM
11/18/17 03:27 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Just wanted to let people know I can confirm fits well on 4WD too. Now installed on my 1979 Power Wagon 150 up . Just a couple of extra high grade bolts from the hardware store. Love it!
