Re: anyone ever lighten lower control arms?
[Re: moparx]
#1925938
10/05/15 12:37 AM
10/05/15 12:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
mr. p body, i'm not a big fan of pickle forks, although i have used them before. it seems every time i've used them, the boot got tore up no matter how careful i was using it. any other suggestions ? Oh well.... when I was working on the pre proto F-body front suspension I had to pull about 12 ball joints a day so I could set up for another front end(this was the transverse bars).. yeah once in a while I would tear a boot.. but not often... I HAD to make sure the fork was under the boot.. on both sides of it.. I actually cut the angle down on my pickle fork so it went in on a easier angle EDIT plus I always put grease on the fork so it slides on the boot
[Re: sixpackgut]
#1925975
10/05/15 01:27 AM
10/05/15 01:27 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Nice Steff. That is what I have been thinking also
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: STEFF]
#1926131
10/05/15 11:36 AM
10/05/15 11:36 AM
Posts: 22,696 Bitopia
jcc
Bitopia
My comment on your lightening, IMO there is one glaring point where a failure might occur, (EVERY item has a failure point) its on the second LCA pictured, on the top of the LCA (which in use is the bottom), approx 2"? to the left of the pivot point, right above where the adjuster loads against the arm. That area is in tension under load, with the removed flanges in this area. I think this one area is overlightened relative to the rest of the arm, and simply adding back minimum flanges on both sides, or boxing the two sides together would reduce the stress concentration. Is it a big deal, not likely. This mod maybe already in the cards as I have no idea if this a progress pic or completion.
And weights before and after would make for good discussion.
[Re: STEFF]
#1926169
10/05/15 12:26 PM
10/05/15 12:26 PM
jcc
Bitopia
That's good, but it would be the area I looked at first when doing regular check overs.
[Re: jcc]
#1926220
10/05/15 01:50 PM
10/05/15 01:50 PM
sixpackgut
Charleston
here is a pic of my stock shock towers. Do you guys that have done a front coil think they will be strong enough for coilovers?
[Re: sixpackgut]
#1926223
10/05/15 01:53 PM
10/05/15 01:53 PM
sixpackgut
Charleston
also thinking about hole sawing my frame connectors. I have a 12 point cage in the car anyway and was thinking the heavy 2x2 square tubing is just adding weight
[Re: sixpackgut]
#1926472
10/05/15 07:26 PM
10/05/15 07:26 PM
sixpackgut
Charleston
Here is what Im thinking. If I go coil over, i can hack my lower control arms like Steff did. Maybe even more. I lose the weight of the t bars, the adjuster bolt and tab thing, cut out the lever. Maybe take a good look at the spindles for weight reduction.
Magnumforce sells coilover kits for to much money to use in the stock shock mount.
[Re: fullmetaljacket]
#1926528
10/05/15 08:49 PM
10/05/15 08:49 PM
sixpackgut
Charleston
1Lb 11oz so far and more to come when i cut that huge lump of steel the torsion bar goes into
[Re: sixpackgut]
#1926578
10/05/15 10:06 PM
10/05/15 10:06 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
here is a pic of my stock shock towers. Do you guys that have done a front coil think they will be strong enough for coilovers? Ray you could delete all your front end pinch welds on the frame. Time consuming, but I'll bet there's some weight to be lost. Matt
[Re: Monte_Smith]
#1926709
10/06/15 12:12 AM
10/06/15 12:12 AM
sixpackgut
Charleston
Thanks Monte but I have no money or I should say no money Im willing to spend on the car. I think another crash is in our immediate future. Anyway...
FMJ, how much do those ti bolts cost? Cuz I just lost almost a lb on one spindle
Oh and i am ditching the torsion bars
[Re: sixpackgut]
#1926718
10/06/15 12:27 AM
10/06/15 12:27 AM
fullmetaljacket
I got a quote a while back for $25.00 per bolt. That is of course, titanium units, not Aluminum. But it only shaves about a 1/4 Lb.per spindle since Titanium is only about a 1/4 lighter than steel. Only good if you're chasing ounces.
