Re: Manual Choke linkage hookup problems [Re: dogdays] #1924332
10/02/15 06:28 PM
10/02/15 06:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I did not know the factory ever used a cable for the choke in 1971 on Hemi cars as I thought they were all auto chokes by then ? I take it thats what you are saying Scott right ? That the factory used manual chokes on 71 Hemi's ? Ron
Re: Manual Choke linkage hookup problems [Re: JohnRR] #1924344
10/02/15 06:37 PM
10/02/15 06:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By JohnRR
Originally Posted By BigAg
Ok that makes a lot of sense. I think I'll buy the electric and hook the positive up the ballast and then the negative to the engine block or carb for ground.
This is the first I have worked with a carb before and surprised and how much time I am spending with it. I am not familiar with the carburetor solenoid. A quick google isn't turning up much on it. Maybe it also goes by a different name? Is this more of a option or a must have for the car to run correct.
I suggest you find a keyed 12v source and NOT use the ballast circuit , the voltage on the coil side of the ballast is less than 12v and the choke wants a 12v source. Many people connect it to the coil because they are too lazy to find a proper source.
I suggest you find out where the factory tapped into for the ballast, choke assist and field voltage. Same exact circuit, hence the suggestion and the pointer to make sure he hooked up to the 12V side of the ballast.
Don't be the exception.
Re: Manual Choke linkage hookup problems [Re: Supercuda] #1924350
10/02/15 06:49 PM
10/02/15 06:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do believe the factory tapped into the J2 circuit just before it got to the ballast for the electric and electric assist chokes. To the best of my memory thats where they tapped into to power the choke but it has been alot of years since I worked on them. Ron
Re: Manual Choke linkage hookup problems [Re: Supercuda] #1925474
10/04/15 11:20 AM
10/04/15 11:20 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The factory did a lot of stupid things, especially when it came to underhood wiring .
Mainstream Media is the new Pravda
Re: Manual Choke linkage hookup problems [Re: 383man] #1925534
10/04/15 12:55 PM
10/04/15 12:55 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, in 71 the Hemi cars got a manual choke. The handle was to the left of the air grabber switch on the B bodies, and I think to the right of the steering column on the E bodies. For the OP they are reproducing the factory cable.
Re: Manual Choke linkage hookup problems [Re: BigAg] #1935595
10/20/15 03:22 PM
10/20/15 03:22 PM
BigAg Offline OP
BigAg  Offline OP
All hooked up now with the electrical choke. Need to shorten my ground wire still but all I have left now is to hook up the positive electrical. I saw some recommendations not to use the ballast. Was curious what other 12v suggestions anybody might have that I could connect to and that would look nice. Included a couple pics.
