Re: Manual Choke linkage hookup problems
[Re: BigAg]
#1922730
09/30/15 08:31 PM
09/30/15 08:31 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Do you have the cable? I used a Dorman Help! Brand manual cable on my 1405 and can dig it out to take pics. There was a brass fitting that slides through #2 in your pic and the inner cable passes through that. You'll need to put a hole in your firewall in line with #1 in your pic. I had the control knob mounted under the dash in easy reach and cable wound over the heater box and out the firewall in line with the carb bracket. I checked around my shop and am pretty sure I gave it away along with the 1405. Check Edelbrock for the carb manual it should have installation tips.
[Re: BigAg]
#1922770
09/30/15 09:15 PM
09/30/15 09:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pretty sure 71 Chargers did not come factory with a manual choke. So you need to route it how you want so that any bends are gentle. You may have to put a hole in, or you may find one you can use.
[Re: ScottSmith_Harms]
#1923033
10/01/15 03:01 AM
10/01/15 03:01 AM
RapidRobert
drill a hole in the firewall & use a black rubber grommett for a professional installation. (could paint it body color also)
#1923397
10/01/15 03:38 PM
10/01/15 03:38 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
This style choke cable "L" end is what your current carb would use. The manual choke of the ebrock have a lever similar to the max wedge setup you show , it would want a straight end on the cable .
[Re: BigAg]
#1923501
10/01/15 05:26 PM
10/01/15 05:26 PM
Supercuda
About to go away
About to go away
up yours
Your schematic doesn't show an electrical hookup for the choke. Looking up a choke thermostat for your 71 Charger w/440 shows that it doesn't have an electrical assist for the choke, just the exhaust cross over heat.
You have a non-stock carb and I suspect a PO added a manual choke to deal with the fact that it's incompatible with the stock choke linkage setup.
You can get a electric choke kit from Edelbrock and use the DBL wire in your schematic to power it. I usually tie into that wire at the ballast resistor, make sure you tie into the 12V side of the ballast.
[Re: BigAg]
#1923584
10/01/15 06:23 PM
10/01/15 06:23 PM
JohnRR
Nothing is ever simple with this car of mine ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) This is sort of a mystery as to why I have this manual choke switch in the car. Could the switch be for something else? I drew a red arrow showing the choke switch. ![](http://i40.photobucket.com/albums/e218/chargerag/IMAG0852_zps855nuwuy.jpg) The firewall has me convinced that the car probably came with an electric choke but looking at the manual it makes it look like it was optional. How exactly does the electric choke wiring plug into the wiring harness? Does to #1 splice mean that they spliced the wire into the electrical harness? Seems weird that it would of come this way from the factory rather then just having a plug for it. I can't see photobucket stuff here on this connection but is this car an original Hemi car ? If not it came with a Thermostatic choke setup not electric.
[Re: BigAg]
#1923615
10/01/15 07:16 PM
10/01/15 07:16 PM
Supercuda
About to go away
About to go away
up yours
It's an emissions thing, early carbs didn't have the solenoid.
It's used to keep the throttle blades from fully closing with the key on. I forget exactly why that was necessary anymore, since I don't run stock carbs either.
[Re: BigAg]
#1924180
10/02/15 02:57 PM
10/02/15 02:57 PM
Supercuda
About to go away
About to go away
up yours
Thanks for clearing that up.
[Re: BigAg]
#1924321
10/02/15 06:11 PM
10/02/15 06:11 PM
JohnRR
Ok that makes a lot of sense. I think I'll buy the electric and hook the positive up the ballast and then the negative to the engine block or carb for ground.
This is the first I have worked with a carb before and surprised and how much time I am spending with it. I am not familiar with the carburetor solenoid. A quick google isn't turning up much on it. Maybe it also goes by a different name? Is this more of a option or a must have for the car to run correct. I suggest you find a keyed 12v source and NOT use the ballast circuit , the voltage on the coil side of the ballast is less than 12v and the choke wants a 12v source. Many people connect it to the coil because they are too lazy to find a proper source.
