Re: Track results (snickering will not hurt my feelings)
[Re: MR_P_BODY]
#1920732
09/27/15 05:34 PM
09/27/15 05:34 PM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
Yes there are cars without a tach.. but run a shift light.. if you feel you cant hear/feel the engine then get a tach Ordering an adjustable shift light this week, don't want a tach in the car.
"I think its got a hemi"
[Re: gdonovan]
#1920830
09/27/15 09:05 PM
09/27/15 09:05 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
Could put it in temporarily, find best et/mph, and adjust tranny to shift there automatically.
The 318 manifolds probably need to go.
[Re: BSB67]
#1920831
09/27/15 09:09 PM
09/27/15 09:09 PM
gdonovan
Oakdale CT
The 318 manifolds probably need to go. I have a set of Dougs headers for another project, they are going in tomorrow. Setting the shift points on the 44RH is problematic, no one makes governor weights that I'm aware of for the application. After finding the optimum shift point for manual operation I'll hide the lamp in the dash.
[Re: gdonovan]
#1921215
09/28/15 03:08 PM
09/28/15 03:08 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The OD is heavier than the 904, the covnertor sucks, and the 2" pipe neck stinks too. I saw you run Saturday - it's a nice looking car. But it looks faster than it showed by a long shot. You know it's all about the combo. Yours has some mismatches. Personally I'd go back to the 904, add headers, and raise your shift points to 5500. Are you going to Carl's rental?
[Re: moper]
#1921282
09/28/15 04:34 PM
09/28/15 04:34 PM
gdonovan
Oakdale CT
The OD is heavier than the 904, the covnertor sucks, and the 2" pipe neck stinks too. I saw you run Saturday - it's a nice looking car. But it looks faster than it showed by a long shot. You know it's all about the combo. Yours has some mismatches. Personally I'd go back to the 904, add headers, and raise your shift points to 5500. Are you going to Carl's rental? 1) Removing the overdrive isn't an option, it makes the car very enjoyable at highway speeds. 2) Headers will be in the car by next weekend. 3) shift points are easy once I have a shift light tucked in the car. Lets do the headers and see what shakes loose next.. Converter and input shaft change in the future is a possibility depending on how the car runs in 2 weeks. Track rental I assume? When/where? I was just going to show up on a normal test and tune day.
[Re: gdonovan]
#1921306
09/28/15 05:21 PM
09/28/15 05:21 PM
gdonovan
Oakdale CT
Again just a reminder of the original intent of the car- It was going to be a long distance vehicle you could comfortably cruise long distance in and look fairly stock with a modest amount of power, that is why it had manifolds in the first place.
[Re: moparclown]
#1921420
09/28/15 07:59 PM
09/28/15 07:59 PM
gdonovan
Oakdale CT
Looks like you were in the staging lanes next to me I remember your car when we were waiting for tech, my son didn't get pictures of it though.
[Re: gdonovan]
#1921633
09/29/15 02:03 AM
09/29/15 02:03 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
1) Removing the overdrive isn't an option, it makes the car very enjoyable at highway speeds. 2) Headers will be in the car by next weekend. 3) shift points are easy once I have a shift light tucked in the car. Lets do the headers and see what shakes loose next.. Converter and input shaft change in the future is a possibility depending on how the car runs in 2 weeks. Track rental I assume? When/where? I was just going to show up on a normal test and tune day. [/quote] I played with the A500 OD trans in my Dart when we put it together.(now a 904) It does make for a good fun driver, mine is set up with a 904 input and manuel valve body. I would suggest you doing that, but DON'T buy a off the shelf converter. Have one made for your combo. I would look at a air gap intake that matches your port size on the head http://www.edelbrock.com/automotive/mc/manifolds/chrysler/rpm-air-gap-sb.shtmlThick tube, thick flange headers Like it was said it's about the combo of parts being happy, and playing nice
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1921686
09/29/15 10:10 AM
09/29/15 10:10 AM
gdonovan
Oakdale CT
Already have a Performer RPM, is an airgap version going to bring much to the table?
[Re: mopar dave]
#1921730
09/29/15 12:09 PM
09/29/15 12:09 PM
gdonovan
Oakdale CT
i ran a 112 lobe sep in a w2 headed 408 once and it was a pig off the line. Roller cams seem to be a little more flexible, the car on the street has impressive manners and doesn't feel weak downstairs at all. I'd wager it has better response and low end then the first cam, you could feel it as soon as I went for the first road test. I was shocked, my experience picking a "old school" flat slider cam for an application is almost useless in picking a roller. Tech has certainly changed in the last 30 years as far as cams go. The first pass at the track was on street tires, it was useless as they went up in flames instantly even trying to walk it out the hole. The slicks were on the car 10 minutes later. Plan of attack is headers -> Shift points and then a converter depending on what it runs. If the car runs well into the 13's odds are I'm going to leave it alone at that point as I do have other projects that have been languishing on the back burner. For years. The only reason the Duster was at the track is I have a CSX we just got on the road a few months ago. The CSX was suppose to be at the track but has a random skip we have been unable to isolate yet. Think tracking down a random skip on a 40 year old car is tough? Try a 30 year boosted EFI car that had been abused and neglected for years. PITA. The Duster is JUST quicker than the CSX, due to slicks. The CSX ran 14.5 at 97 mph on street tires with a abused piston failing on its 3rd pass in July.
[Re: gdonovan]
#1923715
10/01/15 09:10 PM
10/01/15 09:10 PM
gdonovan
Oakdale CT
My son and I pulled the manifolds off tonight, the ID on the manifold outlet is a splendid 1.75"
Been sidelined by a cold bug the kids brought home from school, going to be hard pressed to make the track on the 10th but I think we can make it.
[Re: gdonovan]
#1923732
10/01/15 09:44 PM
10/01/15 09:44 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
My first car I raced had a 360 LA 2bbl motor with a 4bbl intake added otherwise totally stock 200,000 miles and all, dual 2" off the 273 manifolds, 2.94 open rear 205-70-14 tires and I could get a 2.00 60ft out of it at 3500LBS, I think you need to improve your 60 FT and headers ain't gonna do much there, 4 HP ain't much. Might be as easy as advancing the cam 3-4 degrees and shifting later will bring up the ET. Something is definately wrong in the 60 ft. That motor even ETd better shifting around 5000.
[Re: gdonovan]
#1923755
10/01/15 10:10 PM
10/01/15 10:10 PM
gdonovan
Oakdale CT
We will find out soon.. I think the manifolds were strangling the engine just as it was starting to get into its sweet spot. Headers and a higher shift point might just do the trick.
FYI CompCams lists the power range on this cam at 1200-5400 rpm. Remember its original application is a Ram/Durango/Dakota. Not sure if that is with a barrel intake or just general recommendation. Kegger is only good for 4500 rpm or so.
It should be a good match for a porky Duster.
If I feel it needs more cam, I can always try a set of 1.7 rockers I have on the shelf.
