Re: MSD Atomic for dual purpose bracket/street car?
[Re: 70AARcuda]
#1924347
10/02/15 06:42 PM
10/02/15 06:42 PM
Posts: 26,003 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My FI Tech Go 4 system was shipped the day after ordering. Same benefits as the MSD atomic, controls ignition and other accessories plus infinitely programmable and no external control box...all internal. I opted for their Command Center combined fuel sump and pump which simplifies the installation a lot...all for about half the price of the Atomic.
[Re: Monte_Smith]
#1924358
10/02/15 06:57 PM
10/02/15 06:57 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
We/Holley have some new plates coming out, that will be like a do it yourself throttle body kit..............Meaning you have a billet plate, that will hold 4 or 8 of the injectors of your choice and you mount it under the throttle body of your choice. HP will only be limited by the size injector you choose, or what your ECU is capable of handling. As good as a direct port.......no......but a pretty simple way to swap something over with a throttle body and not be limited to available aftermarket kits.
As to what Holley will do with MSD and it's line of EFI stuff......I have no idea at this time. All I know is the "Atomic" is a direct competitor with the "Terminator"............so who knows at this time. We also acquire Accel with the purchase. To think we don't need 3 separate EFI companies is likely not a far stretch Monte, Are there major benefits to go with a direct port over a throttle body type unit? I just bought an Indy 400 intake that I need to get drilled for injectors. If the benefits are huge, I may just hold out for a new throttle body kit
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: Criterion]
#1924990
10/03/15 04:27 PM
10/03/15 04:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is how I set up my Holley multi port.. I like the looks and it hides well under the air cleaner.. I was gonna cut the injector bases down .040 but the injectors clear the base by .060(if they touch the base they will make noise when they open and close) EDIT I would have turned the one set of injectors around to the inside but my kick down set up is there
[Re: Criterion]
#1925003
10/03/15 04:52 PM
10/03/15 04:52 PM
John_Kunkel
Rio Linda, CA
In regards to the FiTech unit:
-What pressure is their integrated regulator operating at? And is that pressure fixed? - Can it do PWM or control pump speed? I don't think I've read much, if anything about that. -Last question and I know this is subjective but, are you satisfied with the fit and finish/quality of the product? Not in light of it costing half as much, but as an aftermarket item you're putting on top of your engine.
I'm in the throws of building a budget SBF (gasp!) so this is an appealing option. Fuel pressure from the Command Center is fixed 58 psi, don't know about PWM capability of a different pump setup. http://fitechefi.com/The quality, finish and attention to detail of their products is superb.
[Re: Streetwize]
#1926478
10/05/15 07:33 PM
10/05/15 07:33 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Installed on 55 T Bird Y block to replace stock Holley 4 barrel T Pot carb. Had a really tough year troubleshooting an engine stalling at random times when coming to a stop. Very dangerous on Calyforuna freeways.
One year of dealing with MSD tech being told that I was doing something wrong or it was the engine. Much time spent on their forum where technical problems were endemic. All the time me telling them to fix their software.
After 3 software update/refreshes all now appears well for the most part.
Will now report that starting, idling, fuel economy are much improved compared to the miserable old Holley.
A very strong point on the MSD Atomic,,,no one knows it is there when the hood is up. I've numerous updates to the car,,,AOD 4 speed overdrive automatic,,, Borgeson steering Box,,,etc , and yet car appears stock except for the Vintage AC add on.
[Re: Criterion]
#1928919
10/09/15 11:28 AM
10/09/15 11:28 AM
Posts: 1,544 USA
hudsonhornet7x
USA
I was really interested in the FiTech unit for an upcoming build. I called them on Monday and talked to a couple people there about the product. I then decided to pull the trigger and ordered a GO EFI 4 600hp unit and it arrived at my door the next day. Very pleasant people to deal with and from everything I've seen in the kit, the fit and finish is easily on-par with the MSD and Holley units. I am not found of their clamp-on style of 02 sensor bung and would really have preferred ORB style fittings at the throttle body, but those are my only two gripes. FiTech also make provisions to tune via a laptop if you desire.
If anyone curious about the system is interested, I can also take some detailed images of the packaging and components. I would LOVE to see some detailed photos of the actual product.
[Re: Streetwize]
#1930697
10/12/15 09:18 AM
10/12/15 09:18 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I wondered the same thing, it looks like it would though. You might have to run some 90* fittings off the fuel fittings but looks OK. I would hope that they thought of that.
68 Barracuda Formula S 340
[Re: davenc]
#1930890
10/12/15 03:12 PM
10/12/15 03:12 PM
John_Kunkel
Rio Linda, CA
Will a drop-base air cleaner fit over that throttle body? Yep, that's what I'm running on mine.
[Re: John_Kunkel]
#1931010
10/12/15 07:50 PM
10/12/15 07:50 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I'm in the throws of building a budget SBF (gasp!) so this is an appealing option. Fuel pressure from the Command Center is fixed 58 psi, don't know about PWM capability of a different pump setup. http://fitechefi.com/The quality, finish and attention to detail of their products is superb. From one of the manuals: FUEL PUMP CONTROL: The FiTech ECU for Go EFI systems has a special driver circuit that will drive the fuel pump directly, which means that an external relay is not needed. This driver circuit allows both PWM control (pulse width modulated), and direct internal relay drive of the fuel pump. This allows the voltage to be reduced when the fuel demand is low, such as at idle and light cruise. One thing I am not a fan of is the seemingly limited tunability. Looks like a 3x3 spark table is all you have...and it seems they strongly discourage people to actually fiddle/tune.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Streetwize]
#1932465
10/15/15 06:37 AM
10/15/15 06:37 AM
Sxrxrnr
Northern Calyfornua
Beautiful T bird buddy, very cool install!! Thank you for your kind words. My wife's car, she appreciated the compliment. Here's a shot of the car.
