Re: Track results (snickering will not hurt my feelings)
[Re: gch]
#1920500
09/27/15 11:27 AM
09/27/15 11:27 AM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
A converter would be beneficial as well as headers.Why such a wide LSA on the cam? It was what was available at the time and several Dakota/Durango owners reported good results. The cam does work far better than the old one via "seat of the pants." Both cams are roller by the way, it was a major factor in running a magnum motor. I would still have expected more with 3.55 gears and a 24.5 slick though.That comes out to 3.91's for actual gear ratio as a guess.
I thought so as well, hell my GTX ran mid 12's on 3.23's with on a 28" tall slick. 440 does make a touch more torque though. Did you play with shift rpm's to see if it help/hurt? I did not as there isn't a tach currently installed in the car, the 44RH was allowed to shift by itself with overdrive in the off position. Shifts are around 4800 rpm which while a touch low with the manifolds killing the exhaust flow there might not be much advantage to shifting higher till the headers are installed. Next outing I'll pop in a shift light and try different rpm points.
"I think its got a hemi"
[Re: TheOtherDodge]
#1920501
09/27/15 11:28 AM
09/27/15 11:28 AM
gdonovan
Oakdale CT
What intake are you running? The stock kegger will limit your rpms to around 4500. If you have the stock one, an M1 would be the first thing I would change. Edelbrock RPM with a 750 Carter Comp series AFB carburetor.
[Re: gdonovan]
#1920521
09/27/15 12:06 PM
09/27/15 12:06 PM
gdonovan
Oakdale CT
Best and last pass of the day was with my son Kyle on board. We had lined up against a 392 Challenger and I took him out on the tree and he never caught up in time even though at the traps he had 15 mph more speed!
Was flipping great!
[Re: gdonovan]
#1920522
09/27/15 12:06 PM
09/27/15 12:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you tried to flash the conv...it sounds like you have a tight stock conv if it wants to pull at idle... the thing with the lock up conv is they dont have the space in them to make a good conv... thats why I changed the pump and input shaft to allow me to use a high stall conv on my Rampage... watch your rpm (when you put a tach in) and see how long it takes to get the rpm up to where the peak torque should be EDIT next I would drop the back of the exhaust to see how bad it is.. could be very restrictive
[Re: MR_P_BODY]
#1920528
09/27/15 12:20 PM
09/27/15 12:20 PM
gdonovan
Oakdale CT
Have you tried to flash the conv...it sounds like you have a tight stock conv if it wants to pull at idle... Yes, I tried a few different ways to launch the car from walking it out the hole to standing on the brakes for dear life while mashing the pedal to flashing it. The car seemed to like flashing it slightly best but there wasn't a huge difference. the thing with the lock up conv is they dont have the space in them to make a good conv... thats why I changed the pump and input shaft to allow me to use a high stall conv on my Rampage...
I'm considering this as well since I stopped using the lockup feature some time ago. Only drops off about 100 rpm or so (tach installed temporarily for testing after getting the trans in) Change the input shaft and get a stouter converter while keeping the overdrive. I'm open to suggestions on brand and specs. The car is on the stout side at 3750 (I'm guessing as it was 3600 even with just me on board and a 904) with my son and a 44RH its just going to be more on the porky side. watch your rpm (when you put a tach in) and see how long it takes to get the rpm up to where the peak torque should be
I'll try and do an in-car video, the car winds up in a hurry hence my surprise at the track results. next I would drop the back of the exhaust to see how bad it is.. could be very restrictive Possible, but with a 2.5" mandrel bent system with an h-pipe and decent mufflers I suspect those tiny 318 outlets with 2"? headpipes are sucking wind first. When I throw the headers on I think I'll take the opportunity to throw some dumps in at the same time.
[Re: Quicktree]
#1920536
09/27/15 12:31 PM
09/27/15 12:31 PM
gdonovan
Oakdale CT
I don't see how in the world you could make SB duster weigh 3600lbs. you couldn't do that if you put 500lbs in the trunk 1974 Duster. Door crash beams, bumpers have extra steel backing front and rear and in the back has bumper shock setup for good measure and that is with a 220 lb driver. Exhaust manifolds don't help either. Later cars have a lot of extra steel due to bumper/crash regulations that went into effect.
[Re: gdonovan]
#1920538
09/27/15 12:36 PM
09/27/15 12:36 PM
Quicktree
I don't see how in the world you could make SB duster weigh 3600lbs. you couldn't do that if you put 500lbs in the trunk 1974. Door beams, bumpers have steel backing and in the rear has bumper shock setup for good measure and that is with a 220 lb driver. I have owned 2-73's and 1-74 none of them weighed over 3200lbs soaking wet
[Re: Quicktree]
#1920549
09/27/15 12:50 PM
09/27/15 12:50 PM
gdonovan
Oakdale CT
I don't see how in the world you could make SB duster weigh 3600lbs. you couldn't do that if you put 500lbs in the trunk 1974. Door beams, bumpers have steel backing and in the rear has bumper shock setup for good measure and that is with a 220 lb driver. I have owned 2-73's and 1-74 none of them weighed over 3200lbs soaking wet 1) 73 is different than 74. 73 doesn't have the steel behind the bumpers nor the rear shock setup nor the front bumper guards (they were optional I think in '73) 2) Car has been on two different scales, 3600 lbs back in 2010 is accurate with the 904 installed with driver. The car is also an a/c car with power steering, disc brakes, bench seat, fold down rear seat and exhaust manifolds. And slicks on steel rims with cast aluminum front wheels. Call it 3380 without driver in 2010 if you like but the car doesn't make it down the track by itself. The car is porky, it is what it is. It didn't get any lighter with my 120 pound son on board nor the swap to 44RH. MPH didn't change a whit with him in the car for three passes so it does point to something else limiting the car.
[Re: gdonovan]
#1920560
09/27/15 01:07 PM
09/27/15 01:07 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
I thought so as well, hell my GTX ran mid 12's on 3.23's with on a 28" tall slick. 440 does make a touch more torque though. Did you play with shift rpm's to see if it help/hurt? I did not as there isn't a tach currently installed in the car, the 44RH was allowed to shift by itself with overdrive in the off position. Shifts are around 4800 rpm which while a touch low with the manifolds killing the exhaust flow there might not be much advantage to shifting higher till the headers are installed. Next outing I'll pop in a shift light and try different rpm points. I definitely think you would gain by raising you shift points to at least 5500 rpm. For a point of reference by 69 dart has run a best of 13.7 at 102mph with the following, 340, stock stroke Stock 2.02 heads Ld4b intake 600 edelbrock carb Stock bottom end, pistons etc. 3.23 open rear Street cooper cobra tires, 215/60/14 My 60 ft is around 2.15 727 with stock convertor that stalls at less than 2000 Cam is a racer brown, hydraulic, non roller, 266 total duration, .220@50, 460 lift, 110 lsa. I shift at about 6000rpm. Everything is very mild so there is no reason you can't pick up significantly from where you are now. I also run stock manifolds and exhaust is original to the car.
[Re: gdonovan]
#1920562
09/27/15 01:14 PM
09/27/15 01:14 PM
gdonovan
Oakdale CT
Question (and this might be a loaded question but take a stab at it)
My friend has a 1970 440 Duster with aluminum heads, power steering, bench seat, 9 inch ford rear, steel wheels, headers, frame connectors, steel bumpers, flat factory hood and a 518 overdrive trans with an ultra-bell, fuel cell and four wheel disc brakes.
Car to guess how much it weighs? It was done on the same scales last rear before he installed 50 pounds of roll bar last week.
He ran 11.1 yesterday with a 1.58 short time, I think the best mph was 121.
[Re: gdonovan]
#1920564
09/27/15 01:14 PM
09/27/15 01:14 PM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
I looked, but can't find the article, but there was a comparison between 340 exhaust manifolds, Magnums, and headers and the conclusion was that the cast irons flowed really well compared to headers.
If it's a stock Magnum bottom end, these things are barely 9:1 compression, so, I think low compression is the bottle-neck.
Otherwise, the HP Calculator shows you at 250 at the back wheels, which sounds about right for what you've done to it. You've picked up about 70hp from a stock Magnum which is pretty good if you ask me.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1920579
09/27/15 01:42 PM
09/27/15 01:42 PM
gdonovan
Oakdale CT
Dyno results with a 300 hp crate engine- http://www.hotrod.com/how-to/engine/mopp-0307-mopar-crate-engine-exhaust/318 manifolds- 311 hp, 403 torque. 340 manifolds- 315 hp, 409 torque. Hooker headers- 319 hp, 424 torque. I'm tossing away at least 20 ft/pounds and they did testing with 2.25" pipe off the manifolds, I think I have 1 7/8" or 2" (what ever the stock 318 pipe is) The manifolds were suppose to be temporary but ended up being on the car for 5 years as I have been tied up with other projects.
[Re: gdonovan]
#1920595
09/27/15 01:58 PM
09/27/15 01:58 PM
gdonovan
Oakdale CT
FYI- I don't dispute shift points being a factor on ET, just so I am being clear. I did consider shifting manually but with no tach did not feel comfortable running through "by ear" and should have had no to little impact on mph on the big end.
Matter of fact adding my 120 lb son to the car, a different automatic, a different cam or a different carburetor had zero impact on MPH.
The car ran 95 mph in 2010 and ran 95 mph in 2015.
I was really tempted to wind out first to see if I could improve the short time but decided to play around with different launch techniques first.
So the bottleneck on mph is in the exhaust, the compression or somewhere else. I'm inclined to think the exhaust as I have run 115 mph with an 8:1 440 in a GTX.
Could be in the stock 340 air cleaner with rear flapper, but I suspect if that was a bad bottleneck people would have noticed by now.
[Re: gdonovan]
#1920721
09/27/15 05:16 PM
09/27/15 05:16 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
Possible, but with a 2.5" mandrel bent system with an h-pipe and decent mufflers I suspect those tiny 318 outlets with 2"? headpipes are sucking wind first. When I throw the headers on I think I'll take the opportunity to throw some dumps in at the same time. Your terminology is confusing. Do you have a 2.5" mandrel bent system (which includes the "head pipe"), or is the system 2". Or are you saying that you have 318 manifolds that have a 2" outlet? A good hp manifold system can easily support more power than you are making. I always recommend changing mufflers frequently, as they can be serious power suckers, especially older ones that might have an internal failure. And Shift rpm matters a lot and will effect mph. You need a tach. It is frankly a little silly to be spending money chasing hp and you are running the car without a tach.
[Re: BSB67]
#1920726
09/27/15 05:21 PM
09/27/15 05:21 PM
gdonovan
Oakdale CT
Off the manifolds is 2" and then opens up to 2.5" at the bellhousing. The plan was to install 340 manifolds and to run the 318 units till then. It is frankly a little silly to be spending money chasing hp and you are running the car without a tach. The point of the car is it is a stab and steer vehicle, there are plenty of people running cars without tachs for one reason or another. Going back in 2 weeks, timeslip will tell the tale. Will try different shift points after a shakedown pass or two.
[Re: gdonovan]
#1920727
09/27/15 05:26 PM
09/27/15 05:26 PM
MR_P_BODY
Off the manifolds is 2" and then opens up to 2.5" at the bellhousing. It is frankly a little silly to be spending money chasing hp and you are running the car without a tach. The point of the car is it is a stab and steer vehicle, there are plenty of people running cars without tachs for one reason or another. Going back in 2 weeks, timeslip will tell the tale. Will try different shift points after a shakedown pass or two. Yes there are cars without a tach.. but run a shift light.. if you feel you cant hear/feel the engine then get a tach
