Page 7 of 7 1 2 3 4 5 6 7
Re: K frame strength [Re: feets] #1952743
11/17/15 01:29 AM
11/17/15 01:29 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Any updates on the test comparisons?
Carl Kessel
Re: K frame strength [Re: CKessel] #1952902
11/17/15 12:08 PM
11/17/15 12:08 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Nobody wants to let me play with their products.
- Stu Harmon
Re: K frame strength [Re: feets] #1953434
11/18/15 01:29 AM
11/18/15 01:29 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Very interesting! I guess I'll deduce my own theory from the lack of wanting to play on a level playing field. OE reinforced it is for me then! Thanks for trying to attempt the testing.
Carl Kessel
Re: K frame strength [Re: feets] #1954661
11/20/15 12:48 AM
11/20/15 12:48 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I got my QA1 K frame this week.
It's "Beefy" and that's coming from a guy who built a stretched one ton jeep on 40's in my garage. I see two places of concern.
The tabs for the strut bars are a little meh.. Time will tell on these, but I am not going to be tracking my car every weekend.
My other concern is the slots for mounting. If it looks sketchy while doing install, I plan to make dowel locators that pass through the K-Frame and into newly drilled locating holes for alignment and security of the frame.
As far as perallelalallellealalgramming.
I don't see it as an issue unless you wreck the car real hard. It's a solid setup there.
Those are just my impressions as I pulled it out of the box.
