Re: Edelbrock victor sb
[Re: 1967dartgt]
#1922742
09/30/15 08:45 PM
09/30/15 08:45 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Indy heads can have way more potential than W2 heads. Way more.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1922760
09/30/15 09:02 PM
09/30/15 09:02 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Indy heads can have way more potential than W2 heads. Way more. My Indy 360-2's that Brett ported flow 337 @ .650. I think they were based off the W-2 head.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: MattW]
#1922796
09/30/15 09:38 PM
09/30/15 09:38 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The reason for my statements are the fact that 5.7 Hemi are cheap and plentiful. The heads flow tons and parts are available.
Matt
Just curious how much one of these engines would cost to run 9.60's in a 2800 pound car like mine. I have 7500 dollars in my R3 with a solid lifter cam engine.
[Re: pittsburghracer]
#1922826
09/30/15 09:57 PM
09/30/15 09:57 PM
B3422W5
Portage,michigan
Matt
Just curious how much one of these engines would cost to run 9.60's in a 2800 pound car like mine. I have 7500 dollars in my R3 with a solid lifter cam engine. Ask 340 Rick here on the board. His car goes 9.60's at 3100 pounds with the new hemi and mild compression around 11 to 1.
[Re: B3422W5]
#1922838
09/30/15 10:08 PM
09/30/15 10:08 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't even get me started on how much a competitive Super Stock engine costs and how few runs they get on them. I had a Friend in PA sell everything he owned and he moved to Florida. There he got hooked up helping a Super Stock team and they let him learn some of the secretes and hone is "grinding skills". And this was back when the cars were a lot slower than they are now.
[Re: 1967dartgt]
#1922860
09/30/15 10:35 PM
09/30/15 10:35 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I think the most expensive thing with the new hemi is initially getting it in the car, oil pan, headers, intake (EFI or carb are very expensive unless a stock one can get it done for you)... Heads can be had cheap as in $500 for used eagles that flow 330 CFM OOTB, stock rockers seem to take some abuse, blocks are good for anything most would do, stroker kits are only a tad more than a forged LA kit, cams are a simple re-grind away from big performance.
Once you get it in and running you can turn up the wick pretty easily/cheaply.
An off the shelf early 5.7 can be had around $1000-$2000 depdngin on seller and miles. Get the eagle top end (intake and heads) later for 12 to 1 compression that will run on pump gas and a cam regrind and the sky is the limit with a #2800lb ride. Just know going in you got to spend some $$$ to get it actually in and running.
I don't see how someone could replicate your engine for $7500 without far above average home porting and some un-realistic deal on an R3 block. Your at $6000 for pro ported heads and R3 then add rotating stuff, intake, machine work, valve train... for $1500?
[Re: CJD AUTOMOTIVE]
#1922948
10/01/15 12:04 AM
10/01/15 12:04 AM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
I don't understand the stock look. Had a customer that we put Eddie Hemi heads and dual quad intake on (it's an air gap). Painted it all. So the stock people right off know it's not stock and the performance people see paint and keep walking. So my question is, what are you trying to achieve looking stock, and why?
I just don't like to advertise, that's all. I'm into what the F.A.S.T. guys are doing so that's the direction I want to go. You have a photo of that Hemi before it went out? Rob C: Craig has pretty much answered your question for me: "It's more than weight. Aluminum dissipates heat at a far better rate than iron, allowing roughly a point more compression on the same octane. So it's weight and power/efficiency." And, I'll add: when you have x number of dollars set aside for cylinder heads you just take all the advantages of aluminum.
Mo' Farts
Moderated by "tbagger".
